Question about Generac Generator 5989 2,700 PSI 2.3 GPM Gas Pressure Washer
I can not find how much oil to use in the Generac Pressure washer 2700.
There is no sightglass, dipstick, any measurements on the outside or anything in the manual to indicate how much oil to put in.
    New Friend:
  • 3 Answers
The only thing i can suggest put your pressure washer on level surface and start fill the oil when gets to the right level the oil start coming out
Posted on Apr 21, 2013
3 Suggested Answers
bustech17
  • 38 Answers
SOURCE: how much oil do you put in the pump for a generac pressure washer model # 01676?
Check and see if there is a sight glass on the side of the pump. If there is, just fill it until the oil shows up about half way in the sight glass.
Posted on Sep 23, 2012
  • 6468 Answers
SOURCE: generac pressure washer will not run unless trigger is pulled
the pressure regulator is stuck inside the pump
Posted on Oct 15, 2012
How to check oil
Hi mick,depending on what make and model your bike is,they usually have a dipstick or an oil sightglass ,either way have the bike uptight on level ground with the tyres on the ground .if its. sightglass just look into it and see if the oil is visible and if so ajust the level by adding or draining some oil.the ssightglass is usually below the oil filler cap.if its. dipstick while upright undo the dipstick and clean it then put it back in its hole but Dont screw it in just lift it back out and again adjust the level as needed ther is usually a high and low mark on the dipstick shaft.
Dec 06, 2015 | Motorcycles
My 2700 psi Generac pressure washer will not start.
Just pull out plug w cable on and crank engine..shud see fire. If not then bad connect or magneto. I think u let engine set w ethanol gas n now carb is gummed. Always drain tank n float. U will need an outboard chemical at a boat shop to fix. Or carb needs overhaul
Jun 16, 2015 | Generac 2500 PSI Residential Pressure...
Length oil dipstick
That measurement is not found in any book, outside of the factory where it was made.
However, look around at parking lots in the daytime, and find a car just like it, and politely ask the driver if you could please measure their dipstick.
Be blessed.
May 22, 2014 | Nissan Hardbody Cars & Trucks
What of oil to change on the 2700 PSI Brigg & Stratton enigine? On a "Generac pressure washer" and also what type of oil and how to change the oil on the pressure washer pump.
id your engine model and consult the briggs site........
the oil in the pump is filled during assembly so it doesn't have a nice pair of fill and drain plugs
briggs :
http://www.briggsandstratton.com/eu/en/
Jun 25, 2013 | Garden
No sight glass on my Generac Pressure washer nothing to tell me how much oil to use
TAKE YOUR PINKY FINGER AND TAKE AND PLACE IT IN THE OIL FILL YOU BE ABLE TO TOUCH HE OIL THERE IS ALSO A SLIT INSIDE THE OIL FILL INSIDE OF OIL FILL .FILL THE OIL FILL TO THE POINT THAT THA IT COVERS THE TOP THE SLIT BUT DONT OVER FILL THE MOTOR THE OIL SHOULD JUST COVER THE SLIT I HOPE THAT THIS WILL HELP YOU
Apr 19, 2013 | Generac Generator 5989 2,700 PSI 2.3 GPM...
Pressure washer surges
This could be your unloader valve taking in account the engine isn't surging. Does the engine run smooth? Do you have at least 50 psi water pressure feeding the pump? Inlet screen clogged? ALL tips act same way or no change?
Sep 08, 2012 | Generac 2700 PSI 2.3 GPM Gas Pressure...
What is the correct transmission oil level?
you measure the trans level by pulling the trans dipstick with the car warmed up (after a short drive), on level ground, engine running-it should read within the 'hash marks' on the dipstick to be considered correct
Mar 10, 2011 | Toyota Corolla Cars & Trucks
Pump oil change, how much oil
There should be a drain plug (bolt) at the bottom of the pump to drain the oil. Undo bolt and drain the oil. Replace bolt and fill pump with new oil. Look for a sightglass on the side of the pump. Fill so the oil level is in the centre of sightglass.
Jan 29, 2011 | Northstar Pressure Washer 2800 PSI
Oil in sightglass on pump is low, what type of oil goes in it.
In the absence of any instruction manual, you can safely go with any good quality SAE 30 motor oil.
Jan 22, 2011 | Northstar Professional Series Pressure...
What type of gas does it take
Is this a big power washer as shown in the photograph?
Is there a separate place to put oil for engine and pump?
If your engine has a place to put oil, then the engine takes ordinary gasoline
If you have a small engine like a weed-eater or chain-saw, and there is not a separate reservoir for oil, then you mix 2-cycle engine oil with the gas in a 40:1 ratio
Pressure washer oil:
Pump fills about half-way up with SAE20 or SAE30 non-detergent motor oil
Engine fills half way up dipstick with 10-W-30 motor oil
Oct 15, 2010 | Mi T M WP-2700-4MHB Pressure Washer
Generac Generator 5989 2,700 PSI 2.3 GPM Gas Pressure Washer Logo
199 people viewed this question
Top Generac Electrical Supplies Experts
Craig Butler
Craig Butler
dennys23601
Don  Farrell
Don Farrell
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
