Question about Cooktops
HV160TC ILVE is beeping all of the time and stops for a moment then beeps again
It shows the letter U and 4 onthe top 2 bottons, Can you help me fix this problem
Cooktop makes a series of 10 beeps every 3-4 minutes.
Sadly when you do not include the make,and model, NOONE can help try calling a repairman
Dec 03, 2015 | Cooktops
What is the solution if my oven beeps?
Hello friend, thank you for your inquiry!
I understand that your door is locked and you have error "F5E1" showing on your range. I would perform a reset on your appliance which can be done by flipping the household circuit breaker off for roughly ten minutes. If that does not correct the issue and you continue to receive the error "F5E1" I would contact a professional to come out and repair your appliance because it could be an issue within your UIB (user interface board) or main control panel. Hopefully this helps. -Matt
Sep 15, 2014 | Frigidaire Stove/Oven/Range Glass Main Top...
Code and beeping. Keeps happening and stops briefly when I push cancel but then starts beeping again
Call repair. They will know what the code is and can fix it. And if you are warranted, they'll do it free. Stoves are too complicated these days and they simply don't have to be. If you are hungry you want to cook and eat, not program some more. Please also look in your owners manual. I bet it will tell you what -F2 means.
Mar 18, 2013 | Cooktops
My cook top is beeping nonstop ! i overboiled some whater and it fell on the cooktop. now it is beeping all the time ! what should i do?
You need to contact your dealer. Tell them to fix it or replace it. Boil over water should not affect an induction stove top.
Jan 09, 2012 | De Dietrich Cooktops
Trying to set time, got stuck on wrong time, can't bake my turkey F90 displays when I press bake and a loud steady beep comes on until I press Stop. so I need 2 questions answered thanks
According to your service manual page 9 an F-90 is maximum oven door unlock time exceeded.
Here is your SERVICE MANUAL
This video shows how to check the door locking mechanism:
This shows how the electric oven high voltage portion of your oven works:
Jan 01, 2011 | Kenmore Cooktops
Large element stopped working/that hot surface light stays on
I have the same problem with mine. Do you have any answer yet?
Jul 20, 2010 | GE 30 in. Profile JP938SCSS Electric...
Wont turn on, LED just blinking
Couldent find any help, pushed the small switch until display reacted then touched the touch fields one by one in order from top left until the display showed nine. Then beep it all worked again !
Gggenau offered a rep at 400-500 eur for this ! Shame on them !
S:DOlberg
Jan 15, 2009 | Gaggenau 28 in. CK 171 Electric Cooktop
Got a diplomat ceramic hob with no instructions
If the KEY lock is on (key botton flashes when switched on) ... touch AND HOLD the lock symbol for AT LEAST TWO seconds until it beeps, then hold the on/off button for AT LEAST 2 SECS.
If the CHILD lock is on ([L] on all displays when switched on), then:
1)Hold the on switch for TWO secs min (unit swtiches on) ...then
2) touch AND HOLD the + AND - for AT LEAST 2 secs
3) touch the - button once again.
Jan 14, 2009 | Cooktops
Keeps beeping
My thermador keeps beeping and F1 stays on...what's happening and how do I get it to STOP!
Oct 08, 2007 | Cooktops
Cooktops Logo
57 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
