Question about Generac Generator 5989 2,700 PSI 2.3 GPM Gas Pressure Washer
No sight glass on my Generac Pressure washer nothing to tell me how much oil to use
There is no dipstick, sight glass, no indicatior or anything to tell me how much oil to put in. There is just a plug in the top and no markings on the outside. The owners manual does not address this issue either.
    Habit-Forming:
  • 78 Answers
TAKE YOUR PINKY FINGER AND TAKE AND PLACE IT IN THE OIL FILL YOU BE ABLE TO TOUCH HE OIL THERE IS ALSO A SLIT INSIDE THE OIL FILL INSIDE OF OIL FILL .FILL THE OIL FILL TO THE POINT THAT THA IT COVERS THE TOP THE SLIT BUT DONT OVER FILL THE MOTOR THE OIL SHOULD JUST COVER THE SLIT I HOPE THAT THIS WILL HELP YOU
Posted on May 22, 2014
4 Suggested Answers
  • 142 Answers
SOURCE: My Generac Primepact 50 RV generator has no AC output.
Check the exciting field wires and fuses.
Posted on Jun 04, 2010
bustech17
  • 38 Answers
SOURCE: how much oil do you put in the pump for a generac pressure washer model # 01676?
Check and see if there is a sight glass on the side of the pump. If there is, just fill it until the oil shows up about half way in the sight glass.
Posted on Sep 23, 2012
  • 6468 Answers
SOURCE: generac pressure washer will not run unless trigger is pulled
the pressure regulator is stuck inside the pump
Posted on Oct 15, 2012
Oil seeping from Comet BXD 2525 pump
out the drain plug ? Sight glass window ? Under the pump where the crankcase meets the pump head?
tighten plug, replace oring on sight glass or replace low pressure seals if near the pump
Dec 09, 2013 | Comet BXD 2525 G Pressure Washer Pump
How much oil does the Anrovi. RkV 4g36 take
rkv pump half of sight glass on back cover any excess can cause over flow if back cover has no sight glass then you will have to use the dipstick do as follow fill pump crankcase while inserting the dipstick til it stops without screwing it in then remove the dipstick and place the end to the pump casing if you see oil your okay cause by the time you fully insert the stick its gonna show where it should be and again half the sight glass:):)best oil to use is 30w non-detergent oil
Jun 18, 2013 | Honda Pressure Washer PSI 3000
I can not find how much oil to use in the Generac Pressure washer 2700.
the only thing i can suggest put your pressure washer on level surface and start fill the oil when gets to the right level the oil start coming out
Apr 19, 2013 | Generac Generator 5989 2,700 PSI 2.3 GPM...
How much oil do you put in the pump for a generac pressure washer model # 01676?
Sep 23, 2012 | Generac Generator 5989 2,700 PSI 2.3 GPM...
Pressure washer pump has no sight glass. How much oil should I put in?
If the oil filler is on the side of the pump, that will be the level to fill it to. If the filler is at the top there may be a dipstick on the plug, or else refer to the handbook.
Jan 22, 2011 | Craftsman Garden
What oil to use in the power washer water pump
Oil used in engine is SAE30, I would suggest adding bit of Nulon or similiar Teflon based before even first run as it will extend life of the engine, This is air cooled Honda and therefore overheat easy.
Oil used in pump is Universal Tractor Transmission Oil.
Except two, all pumps are equiped with sight glass, fill as indicated on sight glass or dipstick.
To extend life of your equipment, change oil in both, engine and pump after 50hrs.
If you live in colder climates, where freezing is possible, do not forget to drain pump and high pressure hose from water to avoid winter damage.
Hope this will help keep your equipment in top notch for years to come:-)
Jun 22, 2010 | Northstar Pressure Washer 3000 PSI
I have a NorthStar M157471A. What weight oil goes in the pump?
I just answered that question on another thread... will repeat:
Jul 11, 2010 | Northstar Pressure Washer 3000 PSI
What type of oil should be used to lubricate the pump
any antifoaming oil but alot of people use multigrade their oil goes creamy as if its full of water but it is just oil that is foam and the air in it takes forever to to come out there are a number of anti foaming oils available use one of those
Aug 04, 2009 | Electric Kranzle Professional 1600 PSI...
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
May 17, 2009 | Briggs & Stratton Garden
Can't find dip stick to check oil on suzuki motorcycle c90t
There is no dipstick on suzuki . Stand beside your bike and look on the bottom right side of your crankcase . look for a little site glass window . That is how you
check . if the oil is half way up the glass when you stand bike straight up . . change every 3000, plus filter
Apr 14, 2009 | 2005 Suzuki Boulevard C90T
Generac Generator 5989 2,700 PSI 2.3 GPM Gas Pressure Washer Logo
110 people viewed this question
Top Generac Electrical Supplies Experts
 Kenneth
Kenneth
Don  Farrell
Don Farrell
Ottoniel
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
