How to move print head in Epson WF 7520 to instal CISS
  • 357 Answers
SOURCE: EPSON STYLUS C90 CISS INCOMPATIBLE CARTRIDGE!!
The cartridge may be defective, as I seen this numerous times, try buying another cartridge from a diffrent retailer and make sure the tape is removed before installing the cartridge.
If this works, you can contact Epson if it is there OEM cartridge that is defective for a refund or replacement.
Good Luck.
Posted on Feb 26, 2009
SOURCE: epson r290 printer no printing now
how to install and R290 printer & print
Posted on Jun 13, 2009
aicaxz
  • 511 Answers
SOURCE: Hi my epson r285 with ciss is leaving ink blotches
It might be caused by waste ink at bottom plate around head sprayer. For some CISS (bottle) design, ink will flow to head, and then flow to pad, when printer off. So, you must close respiratory hole at bottle when printer is not used. For cleaning, turn off printer (unplug power) when head is not in parking position. Move head to center. Put wet tissue (with cleaner or hot water) at top of pad (at head cleaning mechanics). Move head to parking position. So bottom plate contact with tissue. Wait for 10 minutes, repeat 3 times. Check nozzle.
Posted on Jun 21, 2009
  • 5 Answers
SOURCE: Epson Tx100 does not recognize my ink!
there is a chip re-setter located just above the cartridges. it is actually a small button switch. if that does not work, try to remove the cartridges. just lift them (1 by 1) slightly then put it back again
Posted on Aug 21, 2009
SOURCE: Epson CX5500 with CISS ink supply not printing
Ive replaced all the cartridges on my epson 5500 but still nothing prints. Any help gratefully received
Posted on Jun 22, 2010
Purchased the ciss ink system for my epson wf-3540. the ink tubing keeps getting pinched and the ink isn't flowing continuously.
I installed a CISS system in my WF-3640 which is very similar to the 3520. I just leave the top open and put a small piece of white eraser in the slot where the cover peg would go into. That way the printer thinks the top is closed. Yo can print, scan, copy, fax, etc., with the top open.
Oct 05, 2015 | Epson WorkForce WF-3540 All-in-One InkJet...
Does not print one color (yellow)
i have the same printer,i had to clean the heads 14 times to get yellow to finally work
Jun 20, 2015 | Epson WorkForce WF-7520 Wide Format...
Correct setting for Epson Workforce 7520 printing on gloss paper
You need to start with photo glossy paper that's designed for an Epson printer. HP paper may not work well, and some other papers don't work either. Try some Epson paper, and that should work fine.
You can also try other paper settings, such as "transparency" or "matte paper", as the paper setting governs how much ink is laid down. I think getting the right paper is really what you need, though. Ink "puddling" is a common Epson complaint, and it's almost always the paper.
Nov 02, 2014 | Epson WorkForce WF-7520 Wide Format...
Epson wf 7520 "scanning negatives"
I also Have a Epson WF 7520 and I cannot scan any film I've tried every thin here listed I called Epson Support and they said this all in one can't do negatives but it has a slot for it don't understand how you all can Please need help
Apr 12, 2014 | Epson Office Equipment & Supplies
Epson WF - 7520
My EPSON 7520 printer can't print the 1m banner I buy for that purpose, it's new, I design the banner & set up to print, before print when I check for preview it's divided for 4 portion. how can I fixe it? the last size the printer it takes 27cm * 42cm long, but I need to print 27cm * 100cm what can I do? I need help.
Jul 07, 2013 | Office Equipment & Supplies
Ink is not visible on paper
First NEVER raise the tanks of a CISS above the height of the printer otherwise all that is going to happen is that the ink will syphon out and end up getting everywhere.
As you have not used the printer in a long time there wil be dried ink in the print heads 3x head cleaning is nowhere near good enough to clear the blockages.
One thing I would do as you have a set of OEM carts is the following presuming you have the equipment.
Drill a small hole in the top of each cart and extract as much ink as ps=ossible with a syringe (you can put it in the ciss ink tanks) and replace with head cleaning solution. Reseal the ink carts (if clean selotape will do) insert carts and do 5x head clean, leave 24hrs and do 5x head clean again. This will allow the head cleaning solution to get right insine of the print head, soften the dried ink and then flush it through..
A lot of messing about I know but you've just shelled out a few bob for a CISS so it's worth it.
NB
Make sure you keep the CISS carts above the tanks whilst outside of the printer.
Aug 24, 2009 | Epson Stylus C88 InkJet Photo Printer
Hi my epson r285 with ciss is leaving ink blotches all over my print outs, predominantly black, but less frequent with the other colours. This is only a new printer. Head cleaning, noxzzle cleaning and...
Jun 21, 2009 | Epson Stylus Photo 1290 InkJet Printer
107 people viewed this question
jasbo
jasbo
