Question about Garden
Honda 2218 gets slow after it warms up.
I have a Honda 2218. It seems to lose drive after 20-30 minutes. Suspect hydrostatic. Also seems to have beter drive depending on which slope I am on. If the left hand side of the mower is downhill it is worse than if the right hand side is lower. It has only 300 hours on it. All belts and pulleys replaced. I suspect the oil level but can this be topped up. No obvious leeks. Thanks
  • 376 Answers
SOURCE: My Sears 917.272911 Lawn Tractor is eating mower drive belts
There's a couple of things that could be causing this. First, make sure the idler pulleys and blade pulleys spin freely. Second make sure the belt is behind the belt keepers on the two idler pulleys. There is only one on the left idler, but TWO on the right idler. I suspect that is your problem. Anyway, once the belt is on, engage the blades, with engine OFF, and inspect the belt routing, making sure it's not over or under something it shouldn't be.
Posted on Jul 02, 2009
  • 376 Answers
SOURCE: Huskee jerks while going forward
Go to... http://mtdparts.arinet.com/scripts/EmpartISAPI.dll?MF&App=MTD&TF=Empartweb&Lang=EN&searchDB=MTD&loginID=MTDCon&LoginPWD=&xmlPostDest=http://www.buymtdonline.com/webapp/wcs/stores/servlet/processShoppingCart_10101_19502_-1_19502 Enter the brand (Huskee) and model number, not the one you listed, but the one under the seat... hit search and click on illustrated parts, then click on Mower Deck. That will show you the routing and belt number.
Posted on Jul 06, 2009
  • 77 Answers
SOURCE: Strange noise from deck of Toro LX426
The engine wont have an impact with the deck because its belt driven. It sure sounds like you have a bad set of spindle bearings,just turning it by hand you wont hear any noise it has to be going fast to hear it. The noise may be coming from your clutch instead of the deck,and it sounds like the deck. Have these things checked out.
Posted on Aug 09, 2009
mickey813
  • 472 Answers
SOURCE: Riding Mower Variable Speed Pulley Locked Up. How to remove belts
ya it can be freed up with some W-D40 if you pah the cluch down then try to get the belt off i can get you a new pulley let me know
Posted on Oct 15, 2009
SOURCE: I have a cub cadet lt 1050 mower and I need to
I just replaced mine today and let me tell you it was a pain in the ****, Had to remove the deck, steering attachment on the underside,and the electric PTO. Took about two hours.
Posted on Apr 01, 2010
1998 Ford Escort runs normal about 20 miles,then loses speed and slows down to crawl. If I shut down a few minutes and start again,it runs normal a few miles and the same thing.
Do you have any codes in the ECM ? Have you checked for any vacuum leaks ? Can you add more detail information as to when it first began to have issues and what have you done to correct this problem.
Jul 19, 2017 | Ford Cars & Trucks
Mower quits running when going at a incline or uphill.
Check the gas level.
ride on stalls on incline - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Jun 16, 2009 - When its at a certain angle the engine will stall -or- run terribly ... a little water in ..... I am still perplexed by the uphill/slope mower going down. Craftsman Lawn Tractor Stalls Going Downhill
Apr 4, 2010
Old Wheel Horse Problems
May 21, 2008
Hydrostatic Drive Problems??
May 30, 2006
Problem with garden tractor fuel filter
Jul 2, 2005
More results from forums2.gardenweb.com
Sep 25, 2015 | Garden
Transmission loses power when pulling disk changed hydraulic filter motor was rebuilt year ago why im i lose power in transmission? ?
If this is a hydrostatic transmission on a lawnmower type garden tractor some power loss is expected. That just the nature of hydrostatic transmissions.
Severe slippage may not be the transmission itself but would the drive belt. These wear out over time along with the idler pulleys; especially the plastic v-idler pulleys. As the idler pulleys wear out is the same as lengthening the drive belt to a point where it slips. Even a new belt will if these pulleys are worn enough.
Apr 17, 2015 | Garden
Forward is slow
need to change hydrostatic fliud and filterthat will take care of it
Oct 02, 2014 | Husqvarna "YTH26V54 54"" Briggs And...
What causes cr 85 to lose spark after 5-10 minutes
I would first suspect the stator. you need to have an ohm meter and ohm out the stator when it is warm...its possible for the cdi to be bad but not typically when it heats.
Jul 13, 2014 | 2005 Honda FSC 600 S
My Craftsman lawn tractor with 19 horse B & S Twin with hydrostatic transmission loses speed and power in forward and reverse as it warms up. Within 20 minutes reverse will be gone and forward mo
more than likely your low on transmission fluid. I heard alot of this pertaining to hydrostatic transmissions on yards with inclines. I would check your fluid level .
May 14, 2014 | Craftsman Garden
My Husqvarna riding mower is just a few years old. It now has problems driving uphill. What would cause the mower to operate normally on flat surfaces, but make it struggle to go gradually up a slig
A hydrostatic transaxle could be low on fluid, or have leaky pump or motor. Check the fluid level. If it is not hydro, check belt from the engine to the transaxle for tightness or slippage.
Dec 19, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Hydrostatic drive gear YTH 1542
for not charging pull the cover off the top of the engine look for damaged wires mice love to eat them going slow i would check the belt for oil or see if its tight
Mar 28, 2012 | Husqvarna Garden
Garden Logo
142 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
