Question about Minka Aire F602-BNCH Gyro? Fan
Minka gyro fan noise, my fan has a popping sound at the same point in each full rotation.
Pops at the same place on each rotation of the fan. Otherwise well balanced and smooth running.
    Genius:
  • Minka Master
  • 1,617 Answers
I'd take it back and get a replacement. It has a lifetime motor warranty. I used to sale Minka Aire but always had motor problems.
Posted on Apr 19, 2013
4 Suggested Answers
  • 6 Answers
SOURCE: minka aire f602
There are tiny dip switches on the remote as well as on the receiver. Make sure they are set to the same sequence. The receiver is the black box that all the wires connect to in the ceiling.
Posted on Jun 11, 2009
  • 6 Answers
SOURCE: Noise from one of the fans on gyro fan
Either the fan blades are hitting the cage, or the cage itself is rattling from the fan inside being unbalanced. Try tightening the large brown peg on the back of the fan head, and try tightening any other small screws that you see holding the fan head or cage in place.
Balancing the individual fan blades would be tricky because they spin at such a high RPM, but it could be done by using a strong epoxy to stick the correct amount of weight on the blades that need it. Figuring how much weight to put on which blades would be the hard part.
RyanFanMan
  • 342 Answers
SOURCE: cannot figure out how to
there is a band around the cage that you have to remove that takes some paitence but that should fix it
Posted on Jan 01, 2011
When the fan rotates it makes a loud noise. Sounds like it needs oil. Where can I put lubricating oil?
Simply disassemble where its possible and find the place of the bearings most its short right behind the propellor where the shafts come out the motor if it is hard to find for an accessible place spraying wd40 with the hose pipe on the canister behind the propellors can may be help do not use sewing machine oil because of the time being it accelerates faster dirt in the sliding bush of the shafts.
Apr 25, 2016 | Minka Lavery Minka-Aire F502-Bcw,...
Minka f502 is noisy - how do you tighten the screws that attach the fan blade to the motor hub?
With a screw driver? And perhaps you also clean all blades. Sorry if you already did that.
Mar 16, 2015 | Minka Aire Ceiling Fans Gyro Traditional...
Fans work but won't rotate
Probably needs a new receiver. Call Minka Aire
Oct 06, 2014 | Minka Aire F602-BNCH Gyro? Fan
Minka aire gyro fan quit oprating
Contact Minka Aire @ 1-800-307-3267. You might have to ship it back to Minka for repair or replacement depending how old it is. fanman9952@aol.com
Feb 28, 2014 | Minka Dryers
Gyro fan quit rotating
You need to call Minka Aire at 1-800-307-3267
Aug 22, 2013 | Minka Aire Ceiling Fan
360 rotation
Call 1-800-307-3267 Minka aire. I think you need a new receiver.
Jul 24, 2013 | Minka Aire F602-BNCH Gyro? Fan
1st two speeds not working
If the fans rotate on high, then they can rotate on low. So it's either the remote or the receiver that's not succeeding in adjusting the speed. You might try changing the dip switch settings to a different combination and see if that helps. Otherwise, my first guess is that it's the receiver since it has the "brains" of the unit. Also, with electronics it sometimes helps to completely remove all sources of electricity for a minute in order to reset everything. That would mean turning off the circuit that powers the fan for a minute then flipping it back on.
Apr 27, 2009 | Minka Aire F602-BNCH Gyro? Fan
Minka aire f602
Nov 02, 2008 | Minka Aire F602-BNCH Gyro? Fan
Minka Aire F602-BNCH Gyro? Fan Logo
308 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
