3d affect at corners - Televison & Video
  • 3,459 Answers
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on Projection TV sets and a fairly simple DIY fix.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution<3d affect at corners - 47a7bc4.png src="http://i.fixya.net/uploads/images/47a7bc4.png" alt="47a7bc4.png" class="h_mi" />CONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from TvRepairKits.com
Their kits include a step by step instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.3d affect at corners - 7c190d8.jpg>BEFORE
Set after fluid change. Notice how bright the colors are now. Everthing look3d affect at corners - a798d23.jpg sharp again.
AFTER
724bcba.pngSolution #2 - CRT FLUID FIX
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Posted on Apr 19, 2013
3d turn off
Hello Abhilash Patil,
You can adjust your 3D settings by entering the NVidia control panel which you will find in the System Tray in the bottom right hand corner of the screen.
I hope this helps.
Kind regards,
Ron.
Jan 02, 2014 | Dell Computers & Internet
I have a RCA d52w20 that's giving me a 3d affect
The part if near the flyback will kill the convergence adjustment being seen in the menu.
Set has issues (three similar parts) for bad solder connections at the flyback and a kit is available for the protect part (includes that part and a filter cap and diode with instructions-----------
Not a easy set to work on in many ways............
May 20, 2012 | RCA Televison & Video
EPSON home cinema 8350 the picture keeps cutting out and displays in left hand corner hdmi1 not supported but comes back on sound is not affected at all how can I fox it from continuously flashing during...
You might need a good, expensive HDMI cable - they come in various grades. 1080P and 3D require the most expensive, shielded HDMI cable. When the input detects noise on the cable, they unit resets, and can get stuck in a loop if there is a lot of electrical noise..
Jan 14, 2012 | Epson Televison & Video
How do plug it to tv
the connection should be in the lower right hand corner on the back of the TV
Dec 04, 2010 | Sony TMRBR100 3D Sync Transmitter for 3D...
Fixed coolant now picture looks great but cornrs look 3d
You need to replace Both of your convergence ICs they are Big Black ICs will have Part number on them
STK392-150 Call Mats Electronics 1-800-628-1118
Nov 12, 2009 | Philips 46PP9302 46" Rear Projection...
3d effects
it will cost between $300-$700 to fix the convergence a new board was needed.... dumped the Zenith got a RCA LCD 40inch
Jun 22, 2009 | Zenith R57W46 57" Rear Projection...
3D affect
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 21, 2008 | Zenith R57W46 57" Rear Projection...
3d affect
have the dm board checked
Sep 08, 2008 | Zenith R57W46 57" Rear Projection...
3d picture
multicolored 3d effect is a problem with what is known as convegence... ussally there are two large chips (ic) that blow. gennerally they have to be replaced mabe some fuses and resistors..
May 02, 2008 | Samsung HCL4715W 47" Rear Projection...
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
