Question about Honda 25cc 4-cycle Mini Tiller
There is oil on the spark plug in my new honda mini tiller (less than a month old). What might have caused this, and how do I fix it? Tiller won't start
It had problems starting after just a few days, but now it will almost never start, and when it does, it won't run at idle speed and eventually cuts out at full power.
Id say if its that new I would return it .Otherwise was it ever stored upside down or was it laying on its side
Its unlikely its a air filter issue with that low of use but you may want to check there to see if the oil is being siphoned up thru the breather line in the air cleaner area. lf the engine had been ran dry initially then there could have been damage done to the cylinder walls and the oil could be passing what is left to the piston rings,if this is the cause the unit would need to be overhauled .
Posted on Apr 20, 2013
4 Suggested Answers
  • 3 Answers
SOURCE: My Honda mini tiller with a GX 31 engine starts
Clutch or transmission, a common problem with FG 100 series Honda.
Posted on Jun 05, 2010
  • 16 Answers
SOURCE: I have a Honda mini tiller FG-100. Haven't used
You need to check your engine oil on a very level surface.
Its all too easy to over fill these engines with oil and the results can spell disaster if not rectified. On a level surface, with the machine level (not tipped forward) the oil should just be reaching the top of the threads for the bung. Any more than that and you have to much in.
This symptom can also be caused of incorrect storage .ie the machine being left on its side allowing oil to fill the exhaust box.
Check your oil level first then run the machine until the left over oil in the exhaust box has been burnt off. I would then advise either replacing the spark plug with a new one or cleaning your existing one and checking / replacing your air filter
Posted on Oct 13, 2009
  • 6468 Answers
SOURCE: the tillers start working and right away stops, the tiller still runs just the tillers don't
check the shear pins on the tine shafts
Posted on Aug 07, 2012
Runs and starts great but won't idle
Hi, Emmett and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Leaking accelerator pump.
4. Loose low-speed jet.
5. Plugged low-speed jet.
6. Contaminated or plugged low-speed circuit.
7. Enrichner valve is not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have nice a day.
Motorcycle Message Board Motorcycle USA
2 stroke dirt bike problem Won stay running Please help motorcycles
Honda 650 Won Idle
http://www.sportbikeworld.com/forums/179-atv-dirtbikes/30570-bike-runs-fine-wont-idle.html
Mar 21, 2016 | Motorcycles
1998 cbr 900rr won't start
Make sure you didn't close the gap on the plug when you install it
Feb 06, 2013 | Honda Motorcycles
Car starts but won't idle until I accelerate
has base idle speed and kurb idle speed. allows engine to close throttle opening when shutting down to stop pre-ignition or engine running on
Nov 14, 2012 | 1988 Chevrolet Camaro
1993 mercury villager check engine on with code 32 and 34. repair manual says the code 32 doesn't bring the check engine light on but the 34 does. code 34 says problem with the egr valve solenoid or...
After awhile these idle screws don't have a lot of effect, the throttle body & injectors are also probably dirty. The 1.5 turns out from a soft seat is a starting point. Go another 1 to 1.5 turns out to find the sweet spot. Pour a can of Seafoam in with about 1/2 tank of gasoline. That will help clean the injectors & combustion chambers. Clean the throttle body with throttle body cleaner, make sure there is no carbon around the edges of the butterfly and where it seats.
The knocking on starts is most likely from worn bearings. It will knock until oil pressure builds up & is circulating through the journals. I hope this helps.
Sep 24, 2011 | 1993 Mercury Villager
2001 tahoe 5.3 stalls in a slow hard turn to lft or rt. Service eng light on. checked power steering(good). found that wife didnt put gas cap on correctly. been loose for a few days while driving. just...
What codes do you have?
You have a service engine lamp on
Have to start there
Also the turning thing, tells you something,maybe
The idling won't do a thing
The EVAP System may not run a monitor for days
& you have to drive under certain conditions for it to run
Sep 20, 2011 | Chevrolet Tahoe Cars & Trucks
'04 Kymco Venox won't start. Bought it a few months ago from someone w. about 20,000 miles on it. Always runs good/never had a problem w. it 'til yesterday. Ran outta gas on the road...put more...
Hi Mrcherry99, for this situation I would call my local dealer or reputable shop's service department and inquire about any possible quick fix. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if possible, and give you a written estimate of repairs and answer any specific questions you may have about your issue. Good luck and have a nice day.
May 18, 2011 | 2005 Kymco Venox 250
Honda 25cc 4-cycle Mini Tiller Logo
254 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
