Question about Akai PTH5498 54" Rear Projection HDTV-Ready Television
I need a screen protecter for a old model 56'
  • 111 Answers
Cost a bundle, if available. Suggest you go to the City dump or local tv disposal station or local repair shops and ask for a Junker screen. They usually have them in the back. Work out a price, even if it's bigger, you can cut it down, be careful. Good Luck, Be Safe..
Posted on Mar 11, 2009
What is the flow rate (GPM) of an Executive 56 Waterway pump Model PF-50-2N22F?
Waterway Executive 56 Spa Pump, 5 HP, 230V
Waterway Executive 56 Frame spa pump wet end
assembled to a 56 frame, 5hp, 2-speed 230V spa motor
This Spa pump has a 2-1/2 inch intake and a 2 inch discharge for plumbing
(but measures 3-1/2 inch and 3 inch- see bottom of this page)Manufacturer Part No. 3722021-13 Other Part No. PF-50-2N22C
Features:
  • Executive spa pump wet end designed specifically for 56-frame spa motors
  • Two double shielded ball bearings with moisture resistant grease for quieter operation and longer life
  • Two speed spa motors have four sets of insulated windings for increased efficiency
  • 56 frame spa motor for added strength, cooler operating temperature and longer motor life
  • Large 2-1/2 inch intake for improved flow performance and reduced noise
  • Large 6-1/2" diameter wet end for higher head pressure
  • Split capacitor, (start and run) for less energy consumption
  • Thermally protected to extend life expectancy of hot tub motor
  • Highly versatile wet end can be rotated every 90 degrees
  • Viton seals
  • Three year manufacture's warranty on spa motor and spa pump wet end
Jun 05, 2015 | Waterway Garden
My Tv started with flashing red/orange colors. Then later the screen turned red/orange and the TV shut off. When I attempt to turn it on again, the screen stayes red for a few minutes then shuts off.
The problem based on the model number is in or around the red picture tube---the bright red screen causes the set to draw too much current and the shutdown circuit detects this and turns set off--self protection.
Each picture tube (3) has a IC chip on the board connected to it--shorted chip or bad picture tube.
Shop repair in most cases.
Dec 02, 2012 | RCA HD56W58 56" TV
My son just broke our screen. Where can I get a replacement screen?
jhornedvd,
Go to http://www.encompass.com and log in as a guest. Put your model number in the search engine. Locate the three parts to the screen which you will need and order them. I have a tip at http://www.fixya.com/support/r6210638-replace_broken_projection_tv_screen which will help with the removal of the old screen and replacement of the new screen.
Thanks for using FixYa and for the great rating.
hardrocko
Jun 24, 2011 | JVC AV-56WP74 56" Rear Projection...
56" screen dlp Samsung
You can find a new Samsung replacement Lenticular screen and fresnel screen for a model # HL-P5663W from a major Samsung distributor at the following links:
Samsung HL-P5663W Replacement Part Fresnel Screen
Samsung HL-P5663W Replacement Part Lenticular Screen
Feb 12, 2009 | Samsung DLP HL-P5663W 56" TV
Toshiba tw56x81 rear projection tv "protection fault"
Try unplugging and waiting about 2 min. Then retry. There is a self protection circuit which is what is stopping the unit from coming on, but it can be triggered by many things. [Units this old are famous for the capacitors (electrolyte dries out and then they blow), but that is just the most common problem. I would look the capacitors over and see if they give any indication of being "blown" (discoloring, etc.) and replace them if they do.
Jan 04, 2009 | Toshiba TW56X81 56" Rear Projection...
Broken/Cracked front screen
Pls provide model number of the unit.
This unit is a projection or DLP unit?
Dals123
Oct 09, 2008 | RCA P56950 56" Rear Projection Television
Fuzzy blob on JVC Model # HD-56G787
my bulb went out in my 56" jvc hd-56g787 and i need to change it! i have a new buld how do i get to the bulb to change it?????????? thx jimmy
May 26, 2008 | JVC HD56FH96 56" Television
Hdmi Issue
Most new HDMI DVD players use High-bandwidth Digital Content Protection (HDCP)on the HDMI output.If you try to play this on an older TV that is not compliant with these new standards it will not work.This standard came out late in 2004 that is why your older player still works. There is also a service bulletin from JVC about upgrading the software on your TV for HDMI compatiblity issues.If you want a pdf file of the bulletin I can send it to you.
Sep 11, 2007 | JVC HD-56G886 56" Rear Projection HDTV
Akai PTH5498 54" Rear Projection HDTV-Ready Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
