Question about Toshiba Satellite M35-S359 Notebook
Location of motherboard part number on toshiba m-35 s3592 satellite laptop
  • Toshiba Master
  • 7,627 Answers
studio2054
  • 33 Answers
SOURCE: toshiba satellite laptop drivers
Click here to download: http://cdgenp01.csd.toshiba.com/content/support/downloads/sl20modemx.exe
More drivers here: http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modItemList.jsp?moid=1272270&rpn=PSL20U&ct=DL&BV_SessionID=@@@@1082861316.1225660061@@@@&BV_EngineID=ccceadefiieldejcgfkceghdgngdgnj.0
Posted on Nov 02, 2008
  • 112 Answers
SOURCE: I need audio drivers for my laptop
Have you tried the Toshiba web page? under support and drivers?
Posted on Mar 07, 2009
SOURCE: Trying to locate the cmos battery for Toshiba Satellite L25-S121 laptop?
On the Toshiba Satellite L25 S1217 Laptop, the battery is indeed to the left of the wifi card. I was having a problem with a bios password and had spent a considerable amount of time looking. However Instead of taking the whole laptop apart, I removed the wireless card and used a precision flathead to maneuver the connector out of it's socket. after a few seconds I booted the laptop, with the battery still disconnected , and no password prompt! using the same screw driver, I was able to get the connector back into it's socket, and put the wireless card back in. it runs fine now. the trick is to only pull the connector out only enough so that it's not making the connection, if you pull it too far you will have a tougher time guiding it back into the socket. I hope this helps a lot of people with the same problem.
Posted on Apr 30, 2009
  • 121 Answers
SOURCE: Toshiba Satellite L305-S5900. No power indicator light.
sorry there is no fuse that i know of on the satellites it sounds like a motherboard issue see if it can be warranty repaired by the manufacturer
Posted on Nov 25, 2009
  • 265 Answers
SOURCE: I would just like to know the location of the bios
Hi ,
why do you need to know this , its somthing that you should not have to touch , I have the same unit you do so I can tell you its under the cover on the bottom side of your laptop .....it will be marked bios on the chip ..........goodluck Roy
Posted on Jul 19, 2011
Satellite - LED light on with AC power cord but blank screen and doesn't turn on
video card is the number 1 issue for Toshiba satellite models, need to reheat the mounting of the video card.
avoid disassembling the unit, what I did was.
*blow dryer (for the hair)
1.use the blow dryer to heat up the side of your Toshiba, point at the exhaust, located on the left side, do this for 35 seconds.
2.after using the blower, turn on the power button again and see what happens =D
hopefully it will work.
NOTE:
I had the same problem and it solved the issue.
Jul 09, 2014 | Toshiba Computers & Internet
Replacing dvd/rw in a toshiba
Post the model number of the Toshiba Satellite Notebook PC
This can be found on the Bottom of the laptop.
Optical drives for laptops usually just slide out to remove, or silde in. There is an Interface 'block' on the motherboard they plug into.
Usually just one Philips head screw, on the bottom of the laptop; is what holds them in.
Awaiting model number, to give more specific info
While waiting, one example,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/remove-laptop-motherboard-1.htm
Step 5
Regards,
joecoolvette
Apr 28, 2013 | Toshiba Satellite Computers & Internet
I need to know if the mother board from the p205d-s7436 is compadable for the s7438 model
Satellite P205d-s7436 motherboard,
http://www.sparepartswarehouse.com/Toshiba,Laptop,Part,K000056150.aspx
Satellite P205d-s7438 motherboard,
Same part number used for both laptop models.
Satellite P205d-s7436 specifications,
http://www.cnet.com/laptops/toshiba-satellite-p205d-s7436/4505-3121_7-33428376.html
Satellite P205d-s7438 specifications,
http://www.cnet.com/laptops/toshiba-satellite-p205d-s7438/4505-3121_7-32658635.html
Just by comparison of the specs the data suggests only a Processor change, Ram Memory amount, and Harddrive size.
Uses a Socket S1 processor socket on both model's motherboards,
http://en.wikipedia.org/wiki/List_of_AMD_mobile_microprocessors#.22Tyler.22_.2865_nm.29
Both models use an AMD 690V graphics chipset, (ATI Mobility Radeon X1200)
http://en.wikipedia.org/wiki/AMD_690_chipset_series
The answer is Yes.
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
Regards,
joecoolvette
Sep 15, 2012 | Toshiba Satellite P205D-S7438 Notebook
How to make the screen brighter on a toshiba satellite m35-s3592 with XP
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Jun 30, 2012 | Lifetime Toshiba Satellite M35S3592...
Where do I find the part number for the motherboard
Look near the memory slots. You will see labels. Also look all inside the board for labels. Write down the numbers you see on your motherboard. Then get on Ebay and look for motherboards for your laptop. The board on ebay will have model numbers on them, look for a number that matches what you wrote down.
Below is a link to the motherboards I found on eBay for Toshiba Satellite A100.
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=Toshiba+Satellite+A100+motherboard&_sacat=See-All-Categories
Below is a link for the A105 motherboards
http://www.ebay.com/sch/i.html?_nkw=Toshiba+Satellite+A105+motherboard&_sacat=0&_odkw=Toshiba+Satellite+A100+motherboard&_osacat=0&_from=R40
May 13, 2012 | Toshiba Satellite A100 A105 Series Laptop...
Need to know what motherboard is in a toshiba satellite p505d s8007
It's designed by Toshiba but manufactured by HannStar the part number for the motherboard is DA0TZ2MB8X0 (where "X" is the revision code) you will need to disassemble your laptop to see which revision you need, it can be A,B,C...), so far i have seen up to revision "D"
The bios chip is located close to the center in the top section of the motherboard and there is a "U1" mark close to the chip, the chip manufacturer is Windbond part number is 25X80VSIG.
Nov 12, 2011 | Toshiba Satellite P505D-S8007 Laptop
Need a new motherboard and I do not know its name and specs
Hi.
If you need a motherboard for the Toshiba Satellite Pro L300 then please click on the link below for an idea of how much a motherboard will cost. You can search for the laptop motherboard using the model number.
http://cgi.ebay.co.uk/TOSHIBA-SATELLITE-PRO-L300-21F--MOTHERBOARD-V000138330_W0QQitemZ320701576368QQcmdZViewItem
Regards.
Jun 07, 2011 | Toshiba Satellite Pro L300 Notebook
TOSHIBA SATELLITE P35. Where is the motherboard part number located?? Thanks, Jim J.
On most laptops (including toshiba laptops), the part number is written beneath the Ram compartment. Open the Memory Compartment, remove the Ram, then you'll see a sticker with barcode and tag like this:
or
In you case, the Part number should be K000018150. This is the part number of your laptop's motherboard.
Not every laptop has visible part number, on some machines, it's not visible unless everything is dismantled and removed from the motherboard.
Here's a link for you (Click here).
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Dec 01, 2010 | Computers & Internet
Open Questions:
See all Toshiba Satellite M35-S359 Notebook Questions
Toshiba Satellite M35-S359 Notebook Logo
65 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
