Question about Haier Convertible Bottom Drawer French Door Refrigerator - PRCS25EDA
Water not despensing - Haier Convertible Bottom Drawer French Door Refrigerator - PRCS25EDA
    Problem Solver:
  • 6 Answers
WATER VALVE OFF/FILTER DUTY OR ITS ON ICE MODE CHANGE TO WATER DESPENCE
Posted on Apr 19, 2013
Why water is not coming out of the line to the freg
First check to make sure the water valve from th water supply is on (usually under your sink), Second, hold the water despenser switch ON. You should hear a "Hum" sound, that's the Electric water valve in the "open" position. The air will have to be purged through the water line, Filter, And the water collection tank inside the frig. The water tank keeps about agallon of water Cold for the water despenser, and will supply cold water to the ice maker, so the ice maker can freeze the cold water much faster for your ice. When holding the Water despenser, and you do NOT hear the hum sound, there is NOT power to the water selenoid. Check the connections to be ure they are tight and secure. A volt meter can also be used to check the voltage. WARNING the voltage is around 120 volts A.C., Do NOT TOUCH with bare hands!
Jun 20, 2014 | KitchenAid KSCS25FKSS Side by Side...
Water dispenser does not work. However, the ice maker does work so there is water availabe. Could this be a pump problem, if yes how do I replace.
It is not your pump, because despenser and ice maker both get water from the same pump.
Water despenser is activated by a small plunger when you press your water glass against it
to release the water. This is your problem, bad plunger.
Feb 03, 2011 | Amana ARS266ZBS Side by Side Refrigerator
I am having problems with the ice maker. The water freezes but it will not roll over. I have to pull the ice off of the tray the ice is made.
check to see if water despenser is despensing water slow that normal. replace water filter . it will work ok
hope it can help u
Jan 12, 2011 | Electrolux E23CS75DSS Stainless Steel
No water flow to ice maker or water despenser...water lines are clear the filter is clear..could problem be water inlet valve ( dual valve controls water flow to ice maker and water despenser.
Its odd that both parts of the valve went bad at the same time. Personally sounds as if your water filter is clogged up and needs to be changed. I would do that first, before trying to change the water valve itself.
Dec 08, 2010 | Whirlpool Refrigerators
My GE GSS25VFPAWW side by side refrig. wil not despense water.
I turned off the unit for an hour with the door open and the ciller tubes thawed. the water started wotking again.
Dec 26, 2009 | GE GSS25VFPWW Side by Side Refrigerator
Water just keeps pouring out of the top of the ice despenser
I would say your water valve in the freezer is locked in the open postion or has broken.
Jun 07, 2009 | GE GSH22SGRSS Side by Side Refrigerator
My fridge is a side by side whirlpool, and it has a water despenser. The water despenser and ice maker isn't flowing, there is no water, no ice. Im not sure the model #.
check your water supply is ok and replace your water filter if it has one this should solve you problem if not then its poss you have bad water solenoids but not likely. peyton
Jan 19, 2009 | Whirlpool ED2FHSS Side by Side...
GE LXS18JFBLB-2 MODEL WITH BRITA WATER DESPENSER ON DOOR
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
Jul 09, 2008 | Refrigerators
Haier Convertible Bottom Drawer French Door Refrigerator - PRCS25EDA Logo
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
