Question about Pierre Cardin Watches
Pierre cardin women - how to adjust watch band
SOURCE: Watch Band Adjustment
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
Tools:
  • 1 push pin like you use on bulletin boards with a plastic head
  • 1 small hammer like a tack hammer
  • 1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
  • 1 small block of wood
Try to pick a well lit table in a room where you will not be interrupted.
Procedure:
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
Posted on Jan 09, 2008
slp11508
  • 43 Answers
SOURCE: adjust expandable watch bands- Timex watch
Most expandable watch bands aren't sizable. IF it is sizable you will be able to tell when you stretch the bracelet out. If it looks like you can unlatch the links when you stretch it out then you might be in luck, but like I said, most are not sizable.
Posted on Jan 05, 2009
escapement
  • 2334 Answers
SOURCE: How to adjust Skagen watch band.
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 10, 2009
  • 12 Answers
SOURCE: Adjust-a-Casio-S-1087DY-Watch-Band
On most brands, there are pins that form hinges for the links of strap. You need to push them out to remove links. Usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
http://www.amazon.co.uk/Watch-bracelet-link-adjuster-remover/dp/B001ZKIL2S/ref=sr_1_1?ie=UTF8&s=watch&qid=1254695541&sr=8-1
which should help you to remove the link pins safely without scratching.
Posted on Oct 04, 2009
escapement
  • 2334 Answers
SOURCE: I want to change the watch battery in my Pierre
This is exactly where to pry up.
Posted on Jan 10, 2010
I have forgotten my password for my luggage lock (Pierre Cardin), what should I do?
if its not a padlock you can cut off
ask a local locksmith
or
find the closest Pierre Cardin repair agent to you
Contact Pierre Cardin
Nov 05, 2016 | Watches
I have a 2-tone pierre cardin diamond watch and the gold already faded. was it a fake?
Gold does not "fade" but if it is very thin plating, then it may wear off.
This make tends to be expensive; if you did not pay a high price for it, then it seem likely be a fake.
Jul 07, 2011 | Pierre Cardin Gold Tone Bracelet...
Help! I own a Pierre Cardin wrist watch I wear it every day and have doneso for many yearsbut, the case has coroded and needs replacement. The number on the reverse is D265. Can you help to...
mcdevito75 Here, Hello Graham, yes the case of your Pierre Cardin watch can be fixed, Best Bet is to look for a small watch repair shop in your area, they can send your watch out for replateing. They may have to send your watch to Pierre cardin for this service.
Aug 06, 2010 | Pierre Cardin Watches
How do you put the back back on after changing the batery
mcdevito75 here, Most of the time the back cover simply snaps back on, Look for any markings on the cover and caseing, such as a tab, a cut out in the cover that matches the case, specially a cutout in the cover for the stem (winder) Line everything up and with 2 fingers from each hans sqeeze the cover shut. If you still can"t visit a small watch repair shop in your area.
Jul 15, 2010 | Pierre Cardin Women's Diamond Silvertone...
I need a spare part to my Pierre Cardin watch. Is there a retailer in Finland or Sweden that I can contact?
mcdevito75 here, You can try to contact online at Pierre Cardin watch.com Most likely you"ll have to send the watch to Pierre Cardin or you may be able to order the part you need.
Jun 30, 2010 | Pierre Cardin Pierre Cadin Swiss Women's...
Pierre cardin running fast
Not enough information. Mechanical or Quartz for starters. Runs fast probably means it needs cleaning and service. Probably not a watch worth doing that with. They use cheap movements that can easily replaced but jewelers are too lazy or expensive to take a cheap watch to. These use cheapo movements.
Nov 15, 2008 | Pierre Cardin Watches
Watches Logo
242 people viewed this question
Top Pierre Cardin Watches Experts
Ansel Alberto
Ansel Alberto
Steve P
Steve P
Are you a Pierre Cardin Watch Expert? Answer questions, earn points and help others
