Question about ViewSonic N4285p 42 in. LCD TV
How to stop scrolling menu
This past week as Im watching tv, it will suddenly scroll thru the input menu on its own without stopping and change the default input to "tv".
Avery 1770, keeps beeping and number one keeps repeating as if someone is constantly pressing number one.then it could stop for six weeks then just start again.is ther anyway of stopping this?
I think this has been answered very fully by Dazzy B - his answer is below :-
The zero capture is out of the 2percent tolerance so the cell is either faulty or requires zeroing. Open the unit and press and hold the micro switch on the left of the board. The display flashes s. Press the zero key to change to flashing E. Press store to scroll to zero balance. Press semi auto tare. This captures zero without clearing the span calibration. The display will scroll around for a short period when complete press store.. Release the micro switch and scale will go thru warm up routine then display zero. Hope this helps, regs Darren.
Oct 13, 2016 | Watches
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers ยท Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
Dec 25, 2015 | Vizio Televison & Video
TV scrolls through inputs and menu after turning on. Will not stay on any input.
Main system control memory IC is faulty. Replace it. Contact any service technician. http://electronicshelponline.blogspot.com/
Mar 25, 2015 | Televison & Video
Sharp tv keeps changing the source channel on its own
you may fave a faulty switch in the key controller, may best advice is replace it
Part numbers:
KC792
XC792WJ
Fred
Jun 18, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Toshiba tv 40rv525u has started to change channels
My TV 40RV525U changing channels, menus itself for few months ( I use antenna).
my son tried to stop the channel scrolling by enter weird number into the channel to stop it scrolling such as 555, 777..
later, it turn on off by itself and unable to hold on a channel
I call Toshiba customer service and they ask money $25 for troubleshooting but I denied since I do not want to waste money and time.
Now, I found how to fix it myself.
In my case, something was wrong with the signal comes from the button control on the left side of the TV.
What I did
unplug the power cord.
Remove back cover.
Look into the motherboard ( biggest green at the center).
First, I disconnect a connector on the motherboard come from the IR board that receive the wireless signal control ( meaning the remote is disable).
I turn on the TV, press on Menu button on the TV side. Menu is still scrolling.
I turn off TV, disconnect power cord and connect the IR connector back to the motherboard.
I then disconnect the nearby connector that comes from the side control buttons.
Turn on the TV by remote, press menu button on the remote to check. The menu stays.
DONE.
I use electric tape to seal off the connector and let it hanging there.
Close the TV back panel
I have been watching TV for 3 nights without menus/channels scrolling.
NO AVAILABLE red message when watching DVD is no longer existed.
Hope this help someone else.
Jan 20, 2012 | Toshiba 40RV525U 40 in. LCD TV
Hi! My Toshiba 40RV525u TV has a problem, it turns off or on by itself. I checked the auto power off settings, the time is not set (it is 00:00). This happens very randomly. Now I just plug out in the...
My TV 40RV525U changing channels, menus itself for few months.
later, it turn on off by itself and unable to hold on a channel ( I use antenna)
What I did
Remove back cover.
DONE.
Jan 14, 2011 | Toshiba 40RV525U 40 in. LCD TV
Receiver will not switch to tv/dvd , the sound works fine when watching dvd's or video but will not switch back.
can you scroll thru the inputs with the remote,and/or the input knob on the receiver.have you set up your inputs via the on screen menu?
Jul 06, 2010 | Pioneer VSX-815-K Receiver
Mitsubishi WS-65611 tv channels cannot stop scrolling
Check to make sure the channel down button is not stuck. If it is not the button is probably defective. Mits has had a lot of problems with the buttons.
Jan 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Toshiba 36a40
Double check that the Demonstration in the menu is not set to on. This will cause it to keep scrolling thru.....
Jun 10, 2008 | Toshiba 36A43 36" TV
Turn tv on, and it scrolls through the channels
Had the same problem, channels would not stop scrolling.
It was as though someone had there finger on the channel up button.
Disconnected the sixth wire, starting with the black wire on the wiring harness for the front buttons, on/off, ch. up/down, vol. up/down, etc.
It works fine, no more unwanted channel surfing!!
Aug 29, 2007 | GE 32GT740 32" TV
ViewSonic N4285p 42 in. LCD TV Logo
41 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
