Question about Gateway GM5472 PC Desktop
Replacing a power switch on a gateway tower
The switch is broken and wont press in
  • Gateway Master
  • 5,660 Answers
The plastic front of your computer is the Front Panel
http://support.gateway.com/s/PC/R/1009566/1009566nv.shtml
Slip this off to access the Power On Button assembly, which has the Power On switch inside it,
Outside view,
http://support.gateway.com/s/CASES/GERSHWIN/8016200R/8016200Rmv.shtml
Rear View,
http://support.gateway.com/s/CASES/GERSHWIN/8016199R/8016199Rrv.shtml
-> FOLLOW Anti-Static Procedures -> BEFORE reaching inside, your unplugged from power, computer.
If you do not know, post back in a Comment
Now look at the Rear view of the Front Panel again.
The LEFT Side Panel removes.
Looking at the Rear view of the Front Panel; note that the LEFT side of the Front Panel, is towards the Bottom.
See the three TABS sticking up along this edge?
One at the Bottom, one in the Middle, and one at the Top.
Flat plastic TABS formed out of the Front Panel itself.
Another point of view.......
The metal framework you see that the CD/DVD drive/s are in, is the Optical Drive Bay.
Look at the Optical Drive Bay, and towards the Top/FRONT.
See that flat TAB sticking in from the Front Panel?
Now come down to the Middle of the Front Panel.
See how out at the bottom of the Optical Drive Bay, there is a TAB sticking in from the Front Panel?
See the TAB at the Bottom?
They hook on the metal framework of the computer case.
They go through SLOTS in the metal framework.
The Tabs are pressed to the Inside of the computer case, OR to the outside of the computer case.
This action brings a hooked end on the end of the TAB, to the Middle of the slotted hole it\'s in, and then the Tab is free.
Suggest start with the Bottom TAB, press on it when hooked end is free of slot; then do the same for the Middle TAB.
Now perform this on the Top TAB.
The TABS are pressed to the inside, or to the outside, and pressure is put against them towards the Front Panel.
Push on the Tabs, to push the Front Panel away from the computer case.
Once all three TABS are free, the Front Panel will swing out, and remove.
Power On switch is mounted to this metal case,
http://support.gateway.com/s/CASES/GERSHWIN/8016038R/8016038Rmv.shtml
Me?
I would open that case, and take the Power On switch itself, out.
Then see if I could find a replacement, or one that I could live with,
http://www.ebay.com/sch/i.html?_nkw=atx+power+switch
Direct link to Hardware Reference Guide,
http://support.gateway.com/s/Manuals/Desktops/8512041.pdf
Let\'s see if it works.
If not here is the Gateway Support page for it.
http://support.gateway.com/s/PC/R/1009566/1009566ul.shtml
8512041 - Gateway Hardware Reference Guide (5-Bay uATX Case)
Go to Pages 37, and 38. (Top of Adobe Reader in page number box)
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Apr 19, 2013
2 Suggested Answers
  • 194 Answers
SOURCE: gateway computer 310 series wont power up when
It sounds to me like the power switch is plugged into the motherboard incorrectly. I would need to know the type of motherboard you have to get you the proper schematic for hooking up the power switch and reset switch to the board. If you have the manual to the motherboard, there should be a detailed picture showing you how it is to be hooked up. Please let me know the motherboard model for further assistance.
Good Luck,
NOLA Tech
Posted on Jan 29, 2010
Gateway 500C: Dead. green PSU lite doesn't lite when pressing test switch
Hi Don
first thing to check would be all power leads and fuse to clear those areas from the list. Providing all of these are correct, it looks like either your power button has gone faulty of the power supply itself. I am not familiar with this particular machine, is it a normal tower sized machine? if so then a psu replacement is relatively cheap and easy, just make sure that the replacement has all of the connections that you require.
Feb 17, 2013 | Gateway Computers & Internet
Wont power up
My wont turn on too, There is a orange light on the tower, Green on the left, Battery ovel, If I push the restart button, also switch the power supply switch in the back, also unplug from it, Sometimes does it, Do ou know whats causing this to happen, Please let me know Thanks
Jan 26, 2013 | Asrock K10N78M Motherboard
My tower doesn't turn off
You may have to replace the power button switch could be faulty. John
Apr 23, 2012 | Gateway Computers & Internet
Gateway computer 310 series wont power up when
Good Luck,
NOLA Tech
Jan 29, 2010 | Gateway 310 S PC Desktop
Gateway Model 0019401806 Tower - Power button fell into case
there are tabs inside the case that you depress to pull the front cover off. once pulled off you should be able to replace the switch.
hope this helped
please rate well.
Mar 06, 2009 | Sony PCV-RS620G PC Desktop
Gateway 503gr power switch
if you are a practical person, the power on switch is the crudest item ever on a pc. The switch simply completes a circuit. If you look on you motherboard at the front panel connector cables, you will see the two that go to the power on switch. remove them, flash a small screw driver across the terminals and it will come to life
Nov 03, 2008 | Gateway (4000474) Motherboard
Black Screen
Look in the back of the Gateway where you currently have the video cable connected. If there are two connectors, (Side by Side) there than disconnect & re-connect to the other. Your display should come up. Don't be fooled. Most Pc's that have no display on their monitor is not a monitor problem but a computer problem.
Feb 08, 2008 | Sony VAIO VGC-V617G PC Desktop
Gateway GM5472 PC Desktop Logo
112 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
