Question about Faultless Naples Polished Brass Lever Privacy LYE701B-F
Faultless door handle problem
Bolt won't pyll back
Drivers door won't open from outside
remove door panel,peel back water barrier on top left side,remove 10mm bolt on back of door handle,in top of door jam remove 10mm bolt and Phillips screw right below bolt,carefully pull out door handle and remove rod from it,contact Volu parts in Atlanta Ga at 1-888-280-4057 and order white plastic pivot arm,they will know what you need. remove metal drift pin from handle by squeezing with pliers lightly!!! and pulling remember most handle parts are plastic and old be careful. the only door handle new is OEM and over 100.00 and you have to paint to match car.
Jan 26, 2013 | 1998 Volvo V90
Door won't latch
go to the other side take one of the bolts out and get more the same size.
Dec 04, 2012 | 2004 Pontiac Grand Am
How to remove sliding door inside panel of Mazda MPV
1. Work with slider in open position. It helps if you are on a slight incline so that door stays in fully-open position and won't slam shut on your fingers.
2. Remove inner handles and door panel:
a) Inner handle. Remove the inner handle first. You can't see it too easily but a wire clip about the same thickness as a large paper clip holds the handle to its shaft. It's shaped like an upside down "U" so it needs to be pushed straight up. Press the panel outward around the handle and you can just see the clip. Use a small thin screwdriver to locate the bottom tips of the clip and push it up. You may have to alternate from side to side but it will pop off. Grab it with a pair of needlenose pliers if you have to. The door handle willl now slide off - just pull it towards you.
b) Power window switch. Remove power window button by squeezing hidden tabs along the sides of the button. Again, you may have to push the panel outward a little and pry the switch to see the tabs. Wiggle it a little and the button will release. Pull it out and unplug the wiring harness.
c) Door panel. There are several plastic buttons which hold the panel on at the bottom and up the sides. Use a plastic putty knife to get behind panel and pop it out of the holes.
3. Once all trim fasteners are released, grab the door panel at the bottom and pull straight up to release it at the top. You may have to give it a quick upward tug to get it to release. Push the power window button wires through the mounting hole. Look at the panel buttons to make sure that all of them came off with the panel. If not, remove the remaining ones from the door and put them in their respective slots on the door panel. (Trying to re-attach the panel without the buttons installed on the panel will be frustrating.)
4. Outer handle removal.
a) Unclip the handle lock button / bar by turning the small tab and pulling the bar out of its slot. Hard to describe here but you'll figure it out once you see it.
b) Remove three bolts which hold the handle on the door. Note that one bolt is accessible from the outside of the door along the front jamb.
Replace handle and reverse the steps above.
Notes: Check the locking mechanism and make sure the door opens and closes before you reassemble the panel. Remember to orient the inner handle the right way before you re-attach its spring clip. (I've attached it upside down and it won't work!!!) . Also, be sure to feed the power window wiring harness back through the mounting hole before putting the panel back on.
Nov 06, 2012 | 2000 Mazda MPV
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
1999 Hyundia accent door handles won't work
Go to ebay I bought two new outer handles and two inners for my '97 accent. They are five bucks a piece you can't beat it and free shipping. Take the inner panel apart if you're going to change them yourself. You have the mirror guard that pops right off with a flathead screwdriver, then unscrew every philips-head bolt on the panel there should be roughly four screws. Then once you remove the panel, two 10 mm bolts for the handle which are inside the door are what hold the handle on. Good Luck! http://www.ebay.com/sch/Car-Truck-Parts-/6030/i.html?_nkw=1997+Hyundai+Accent+door+handle
Aug 04, 2012 | 1999 Hyundai Accent
Changed door handle but door still won't open from inside
which door is it cos rear doors have a kiddy lock-when you work the handle can you feel any resistance,as if the handle is actually connected or is it 'floating' ?
Jul 06, 2012 | 1998 Toyota Corolla
97 Mercury Mountaineer driver side door won't open. Outside handle flops around; inside handle won't open door
Try a slim jim first, down the side of the window. Or AAA or locksmith. If no luck, remove the seat first. Find the screws and bolts around the door handle and arm rest. Most Ford's have screws around the outer side of the panel. I don't believe your's does. The panel lifts or pops off. Once the panel is off, you can reach down and open the door. Just a note. I have done some to where the panel came out in pieces.
Mar 14, 2012 | 1997 Mercury Mountaineer
Passenger side window motor replacement
Installing Passenger Side Power Window:
First of all there are only 2 - 9/32 bolts that hold the door panel on. One is located right behind the door handle in plain sight. The second is the one that eluded me and I ended up breaking the hook off the back of the panel...it's located under the switch panel. It's a snap to remove; just pry around on it and it comes right up. Once again; these are the ONLY 2 bolts holding the panel to the door. Snap the cover off that goes around the door opening handle and also the little triangular piece that's where the wing windows used to be on the older trucks. Also pull the plastic part that's over the door lock. Then gently lift straight up just a little and pull out towards you. The panel will come right out where you can then unplug the speaker wire and remove the bulb assembly from the door light at the bottom. 1 - 3/8 bolt holds the door handle on; remove the handle and set aside. Then strip the plastic off being careful not to tear it since this will be reused. This is to keep moisture out and road noise down. My problem was a broken cable so I could move my window up and down by hand, but you may have to plug the switch in to move yours to the right position. I think it's about 1/4 inch down where you can see the 2 - 3/8 bolts that hold the window to the regulator. Loosen these bolts then gently break the window free. Pull it all the way up and tape it there so it doesn't fall and break while you are removing the old unit and installing the new one. There are 6 - 3/8 bolts that hold the assembly in place and it's pretty easy to figure out which ones they are. Take these out and work the unit out through the large hole at the bottom. The new one goes in pretty much the same way only in reverse. After I got the 6 - 3/8 bolts back in place I plugged the window switch in and rolled the unit all the way up being careful to make sure the clamps were going to line up with the window. They did, so I took the tape off and slowly lowered the window where I could tighten the 2 clamps down on the glass. Put the plastic back on, then the door handle. Plug the speaker wire back in and put the light back in at the bottom of the door, then set the panel back in the holes. Mine wasn't hard at all. Reinstall the 2 - 9/32 bolts then plug the switch assembly in and snap back in place. Replace the rest of the plastic covers and you should be pretty much finished.
Oct 18, 2011 | 2001 GMC Jimmy
Someone tried to break into my 07 chevy tahoe ltz they ended up breaking the rt rear door handle off ive got the new handle and already have the door panel off and the bolts out ready to replace it but...
{: ) Yes there is a rod. Check if it could have fallen somewhere inside the door. I have for you a diagram, although this is for the driver door, the configuration is much similar. The rear door uses a shorter rod and doesn't have much bends compared to the front doors. If the handle you bought doesn't come with this rod, so is the doorlatch. So the rod will come separate.
Check also from the picture below, and inspect the orange clip for damage. Since it was forcefully opened, it's possible the clip won't grip properly on the threaded edge of the rod.
Jul 21, 2011 | 2007 Chevrolet Tahoe
2002 Nissan Altima Exterior Door Handle
Look at the inside of the door directly behind the door handle. There should be a hole about 15 mm wide.
Just enough to get a small socket through.
Make sure the window is up.
Feb 03, 2009 | 2003 Nissan Altima
Faultless Naples Polished Brass Lever Privacy LYE701B-F Logo
Top Faultless Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Faultless Hardware and Accessory Expert? Answer questions, earn points and help others
