Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My garage door starts to raise then stops
My garage door stops about a foot and a half from the grond on the way up. i changed the gear on the sprcket because it was badly warn. it worked for two days and now does not work.
  • blueextc3221
    blueextc3221 May 11, 2010
    Try adjusting the WORK potentiometer on the back of the drive motor housing.
    The spring may be worn, and increasing this adjustment will allow the opener to do a little more of the work.
  • 504 Answers
Sounds like you may have a broken spring check for a gap in the spring above the door.
If you have a broken spring call in a pro this is not a repair for DIY. There are way too many safety issues and details to do this without training.
Hope this helps
Posted on May 29, 2010
I replace the internal gears on my Craftsman 1/2 HP opener. after re-assembling it. i tested the opener the door raised only half way and would stop. it would start down but stop also. it would go only...
Make sure you put the black cup back on the end of the motor shaft and that it is pressed all the way on. Make sure the RPM sensor is plugged in. If neither of these are the issue, then you probably did not have the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen that coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
Feb 20, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door only raises about two inches then stops.
Check the door springs and also remove the cover from the motor unit and check the drive gear. The door spring could be broken or the drive gear may be stripped.
The sensors only work when the door is closing.
Jun 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: garage door opener only runs for a foot or two and...
Check to make sure you don't have a broken door spring and also remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor and may be stripped.
May 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage door only goes up hjalf way and it
Check for broken door springs or a bad drive gear. Remove the cover from the motor unit and check the gear. It is white nylon and is just in front of the motor.
Mar 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Sears model 41A4315-7A garage door opener will not raise the door. Yesterda I used the remote and It raised the door half way then stopped. A second push on the remote then lowered it. Then the remote...
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor and it will be obvious if it is bad. The part number is 41A2817 and is available at any good door opener service company. It comes with instructions.
Jan 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door had a stripped gear so I
if the stops are not wrong.
they tell it how far to go up and down.
then I think the safety sensor is misaligned.
make sure the light on one side is pointed at the receiver on the other. maybe it is dirty or blocked.
good luck!
Jan 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door goes up about a foot and stops
The sensors have nothing to do with your door opening. First thing to check are the door springs. One may be broken. Next remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It may be stripped.
Jun 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens about one foot and remains there.
Check the door springs. You could have a broken spring. Also remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It is possibly stripped. This is a good time to release the door from the opener and operate it by hand to see just how heavy it has become.
Jun 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Quantam #3212 garage door opener stops beabout 1 foot from top
There are two limit adjustments on the opener. usually the screw show which way to turn if the door needs to be lowered more or raised more. Turn them only about a1/4 turn with each adjustment.
Jan 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
199 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
