Question about Venturer PLV36220S1 22 in. LCD TV
Tivo remote codes for venturers tv - Venturer PLV36220S1 22 in. LCD TV
    Top Expert:
  • Venturer Master
  • 75,178 Answers
These are the codes to check. 004/ 005/ 009. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Posted on Apr 19, 2013
Tip
DirectTV RC65 Remote Manual
Tivo DirectTV RC65 Remote Control Manual
Have you lost your TIVO Direct TV RC65 Remote Control Manual?
Would you like a digital, searchable, pdf version for reference on your computer?
The TIVO Direct TV RC65 Remote Control Manual is available for download here.
In it, you will explanations of is buttons and features, and directions for setting the remote up for use as a Universal Remote, controlling all your other AV components.
Directions for entering DVR programming codes are here.
Instructions for using the RC65 Code Search function to find remote codes are here.
I hope that helps.
on Apr 02, 2010 | Tivo DirectTV Remote Remote Control
Suddenlink tivo apex tv code
Hi- My name is Shannon and I am with Suddenlink. The SL-TiVo remote can be programmed to control the TV and one other A/V device using these steps:
1)
From TiVo Central, select Settings & Messages > Settings > Remote, CableCARD, & Devices > Remote Control.
2) Highlight Part 1: TV power, volume, and mute and press SELECT.
3) The DVR displays a list of television brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your TV brand and then press SELECT.
4) The TV Remote Codes screen appears. Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the TV.
5) If also programming to control volume & mute on an A/V receiver for surround sound; Highlight Part 2: A/V volume and mute and press SELECT.
6) The DVR displays a list of audio/video receiver brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your receiver brand and then press SELECT.
7) The AV Remote Codes screen appears.
Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the receiver.
The TiVo remote will now turn the TV on/off and switch inputs and adjust the volume and mute the audio on the receiver.
If you have any questions, feel free to email me at shannon-AT-suddenlink-DOT-com. Thanks!
Nov 23, 2012 | Televison & Video
I need code for RCA TV for Tivo remote
Go to http://support.tivo.com/app/answers/detail/a_id/294/kw/code%20search/c/105/r_id/100041 and under Programming TV Power, Volume and Mute, click on "show the steps".
Follow the instructions given.
The RCA remote codes are 0163, 0001, 0004, 0006, 0011, 0029, 0030, 0057, 0071, 0133, 0145, 0106, 0171, 0231, 0232, and 2210.
Try each of these codes one at a time (as per instructions) until you find one that works.
This link also gives instructions on what to do if none of the above codes work.
If this helps, please give a rating!
Oct 09, 2009 | Tivo Series2 TCD649080 Video Recorder
Programming my TiVo remote to control my Proview TV
  1. Cover the end of the TiVo remote control with your hand.
  2. Hold down the TiVo and TV POWER buttons simultaneously until the red light on the remote control remains on.
  3. Remove your hand from the end of the TiVo remote control.
  4. Enter code 0999.
After you enter the code, the red light will flash three times and then remain on.
  1. Press CHANNEL UP once every two seconds. This will test hundreds of codes, one by one.
IMPORTANT: Do not go any faster than this or you may skip over a code that works.
  1. If you press CHANNEL UP and your TV turns off, press ENTER to select the code. Press the TV POWER button to test the code. If your TV turns on, you have successfully programmed the remote
Jun 11, 2009 | Tivo Series 2 Remote Control
Polaroid TV remote control codes for Tivo
As I understand it, Polaroid TV's sometimes work with the Mitsubishi codes. You may give this a try. You may also e-mail Polaroid direct at www.polaroidelectronics.com contact page to find out what codes should be used (may match a different manufacturer)
Jan 27, 2009 | Polaroid 4226TLMB 42 in. LCD TV
Need to program a directv philips series 2 remote
tivo button is the Directv button (tivo home) at the top of the remote. if u have the new directv remote, the tivo home button is the menu button. remote needs to be on satellite. to program codes.
Dec 20, 2008 | Philips DSR708R DirecTV / TiVo DTV...
Tivo DirecTV Remote-Program AKAI LCT2721AD
Try this: On the Tivo remote press and hold the TV Power button and the Directv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
Dec 09, 2007 | Tivo DirectTV Remote Remote Control
TIVO Remote
Your tv doesn't accept the code. The tivo remote uses the code that is programmed in it to control your tv. Go through settings and tell it you want to program your remote for your tv and follow the on screen instructions.
Oct 08, 2007 | Tivo DirectTV Remote Remote Control
Venturer PLV36220S1 22 in. LCD TV Logo
96 people viewed this question
Top Venturer Televison & Video Experts
john milligan
Are you a Venturer Televison and Video Expert? Answer questions, earn points and help others
