Question about Delta Machinery Delta 22-610 RC-63D 24-3/4" x 9 3/8" Planer
How to controll snipe - Delta Machinery Delta 22-610 RC-63D 24-3/4" x 9 3/8" Planer
  • brehmgci
    brehmgci Apr 19, 2013
    need toget rid of the snipe, how do i do it
  • 959 Answers
Feed the wood into the planer at an upward... or is downward ... growth ring dirrection.
Posted on Apr 19, 2013
Any ideas why the raised line appears to and how to prevent it from happening at all?
You have a chip in your blades. This is most often caused by a nail, screw or small stone imbedded in the wood. The only remedy is to have the blades sharpened.
Snipe is a depression cut on the end of the wood as it passes the blade. This is caused by the incorrect height of the blades in relation to the table. You will find many videos in You Tube on how to set up your planer.
Jun 08, 2017 | Crafts & Hobbies
Why does it snipe?
Contact the place where you bought it and ask them, or ask the manufacturer.
Aug 19, 2014 | Craftsman 1212 in Thickness Planer
The infeed roller is uneven and it snipes the boards
Sniping is common, try feeding waste stock in before or after your good wood, whichever end is getting sniped. The planer will not notice the end of your wood, and cut it flat.
Oct 03, 2013 | Powermatic 1120003 PM15 Planer/Molder
Sniping
You get sniping with all planers and it will always be the length from the cutter head to the second feed roller. Until the board goes under the second roller it is almost impossible to feed it through and not get some sniping. The same applies to the outfeed side also. Better made (more expensive) planers, table extensions and holding up on the end of the board until the other end is under the second feed roller will reduce sniping somewhat but you'll always have some sniping.
Mar 03, 2013 | Delta TP305 12 - 1/2" Portable Planer
Severe sniping with planer
You will always have snipe at the end of planed boards equal to the distance from your infeed and outfeed rollers. It's severity is determined by how much the board sags or dropps behind the planer until the second roller catches the board. Some planers have extended tables to help with this. What you can do is hold the board up as much as possible and still let the infeed roller move the board smoothly until the board contacts the outfeed roller.
Jan 30, 2013 | Craftsman 12 amp 12-1/2" Bench Planer...
Baygenie problem with daylight saving time and no bid.
you might try changing the time on your computer to compensate it
if only for a short time
hope it helps
Dec 25, 2011 | Computers & Internet
While playing a online shooter games like modern warfare or James bond. My PlayStation is real bad at sniping around while I try to move around and shoot poeoke. Why
A lot of people have sniping problems either yor not using it properly or you've just not customise it the way you want or you're using a bad sniper. If you're good at sniping then you're bound to get a lot of good thins for your sniper everytime you play with sniper
Dec 27, 2010 | Sony Playstation 3 (PS3) Console
How do I Get rid of snipe?
Your intake side of the jointer is not high enough. You can run a test using tape to see. Hope this helps. Remember to vote if it helps. Thanks. Here is the link to a youtube video that will explain it. Its called Dealing with snipe on a planer / jointer / thicknesser
Dec 22, 2010 | Grizzly G0452 6" Jointer
Snipe on a planer
if both tables are parallel with each other, then i would bring the outfeed table up just a tad at a time this is usual the problem.
May 15, 2010 | Masonry Tools
Snipe
could be the way you are feeding/removing the board. snipe is actually the sound the board makes when its end passes over the cutter. the inboard table should be slightly lower than the rear table. pressure and movement must be maintained when feeding the board the entire length of the joiner table.
Oct 20, 2009 | Powermatic Masonry Tools
Delta Machinery Delta 22-610 RC-63D 24-3/4" x 9 3/8" Planer Logo
85 people viewed this question
Top Delta Machinery Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Delta Machinery Craft and Hobby Expert? Answer questions, earn points and help others
