Question about GE 106591 Coffee Maker
Why is my coffee maker not working
I tried to make a coffee this morning, and I have push the start button but nothing happens. Could you let me know why. Thanks
  • Anonymous Mar 11, 2009
    made a fresh pot of coffee. it doesn't work.piece of ****.
I will assume the outlet is working and there is no timer that is set to turn the coffee maker on later. There are a few possibilities 1- the switch is defective 2 - there is a temperature sensor in contact with the heating element that is defective 3- the element itself is defective. these parts are all internal and may not be easily accessible without proper tools. All the components can be checked with an ohm meter. Also check for loose or broken wiring connections.
Posted on Mar 11, 2009
Keurig coffee maker won't stop, end up with 4 cups all at once
Timer section and valves open due to incorrect assignments. Replace or repair.
Sep 16, 2012 | Keurig B100 Coffee Maker
Senseo coffee maker not working
I am having the same problem, was working fine then one morning it did this and then would not open.
I hope someone has a solution.
Feb 17, 2010 | Philips Senseo HD-7810 Coffee Maker
Coffee maker doesnt work
I can't get my coffee to brew. I pushed the on button and even tried to program it! no coffee. Can someone help me please?
Nov 20, 2008 | Coffee Makers & Espresso Machines
Broken
I was told from the tech support to push both 1cup and 2cup buttons down at the same time to flush, hold until all water drained out. Have not tried it yet, don't know if this will fix it.
Also, she told me if it doesn't solve, look behind the water reservoir and push the little button lightly, tried a little harder if still didn't work. I had the same problem with my brand new senseo supreme. I'll try it tonight.
Aug 04, 2008 | Coffee Makers & Espresso Machines
Keeps flashing 12:00
I just kept plugging and unplugging the coffee pot. Eventually, the clock stopped blinking, the buttons worked, and all was well.
Jul 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
GE 106591 Coffee Maker Logo
1,333 people viewed this question
Top GE Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Eric Taylor
Are you a GE Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
