Question about Elmo Projectors Office Equipment & Supplies
Everything is on but nothing is projected on the screen
My hitachi big screen has red shadows on picture how do i fix it
What you described sounds like a convergence problem. When convergence has failed the colors will commonly look 3D,warped, etc. This tips page here on Fixya has more details.
Jan 27, 2013 | Hitachi 43FWX20B 43" Rear Projection...
Color is wrong mostly yellow screen I tried adjusting everything and still nothing what else can I do and isz it worth calling a repair man
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Mar 02, 2011 | Hitachi 50UX57B 50" Rear Projection...
Dark image and convergence problems
It may be the closed captioning it happened with mine. I simply turned off the CC on the TV.
Apr 08, 2010 | Sony KP-53HS30 53" Rear Projection...
No picture/power
It is fixable. Contact the service center for assitance.
Apr 06, 2010 | Hitachi 50UX58B 50" Rear Projection...
Philips projection HDTV 51PP9200D/37. Convergence problem
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 13, 2009 | Philips 51PP9200D Television
VS-45603 we have power but nothing else will show up on screen.
I would suspect bad solder connections on the convergence IC's caused one to short out a blow one or more pico fuses, thus causing the set to go into shutdown so as to stop further damage to the set. The TV will need to be seen by a profesional to confirm or deny this.
Dec 17, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Magnavox rj8510 ak03 out of focus?
Thats your focus/ screen control block good luck on finding one.
Oct 12, 2008 | Philips Magnavox 51MP392H Rear Projection...
JVC HD-70FH96 both HDMI problems
Have you been using a flashlight behind the TV. These TV's have a sensor that shuts off the unit when the rear cover is removed (by sensing light). You may have tripped this. I think you can fix this in the service menu somehow but I can't remember.
Oct 10, 2008 | JVC HD-70FH96 70" Rear Projection HDTV
22 people viewed this question
Top Elmo Projectors Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Elmo Projectors Office Equipment and Supply Expert? Answer questions, earn points and help others
