Question about KitchenAid Dishwashers
Sump pump gasket
How in install
  • KitchenAid Master
  • 3,247 Answers
Please provide model number.
Posted on Apr 19, 2013
How do I set old pump to remove and install in another Toyota same motor
remove all of the sump bolts
use a paint scraper or flat blade to break the adhesive sealant used in engine assembly
remove the sump
get a sump gasket kit and clean the sump and block
use loctite red and install the sump and gasket
Oct 24, 2017 | Toyota Cars & Trucks
My toyota avanza was mixing oil and water then we changed the gasket and the oil pump, now we hv put in the oil then now it doesnt take the oil to the cylinder head what could be wrong
I am not familiar with working on this particular make/model but others I have done I usually prime the oil pump before installation. Other than that, if the oil pump is in the sump, make sure the gasket between the pump body and the engine is good otherwise the pump will be sucking air. Cheers
Oct 09, 2017 | Toyota Cars & Trucks
1997 Nissan Altima oil pan has a dent on the bottom. Can it restrict oil flow. Should it be replaced? Does it require a gasket or gasket maker?
depends on where the dent is and how deep
bad dents can restrict oil flow to the pump because
it blocks off the pick up for the oil pump
breaks the pick up tube at the pump connection allowing for air into the lubrication process
alters the correct oil level on the dip stick making for less oil in use
it the sump is of pressed metal construction , it can be hammered back into shape BUT the major problem here is that it also deforms the sealing edge of the sump and oil leakage from the gasket will be a problem
With so many engines in the wreckers /junk yards a replacement undamaged sump is the best option
Jun 01, 2017 | The Video Game Consoles & Games
What can possible be the cause? I have a Renault Master II diesel 2003. New engine block, new top, new oil pump.But, engine loose oil pressure when warm, about 0,5 bar measured.
possible air leak from a badly installed gasket at the top of the pump pickup tube in the sump
it has been known that a rag has been left in the sump during overhaul and can be blocking pickup
(rag is left on the crank shaft or big ends when the block is inverted during assembly and the sump is put on over it )
Jun 19, 2016 | Renault Cars & Trucks
How do I replace a dishwasher sump pump gasket?
Would love to help but need manufacture and model #
Jan 28, 2015 | Dishwashers
GE dishwasher leaks in middle - bottom - what part do I need
you would need to replace the sump or rather the sump gasket but they dont usually sell the sump gasket without u buying a new sump and most of the time you pay more for just the sump then if you were to buy the sump and motor together as a kit you can find the parts at marcone appliance parts and they will mail you the parts directly before ordering the sump make sure you check the drain pump also it is located in the same area but when you usually have a leak it comes from the sump or the sump gasket but you'll have t crawl under and visually inspect where your leak is coming from please remember to rank this opinion on how it helped with your appliance situation and if i can answeer any further questions please message me back thanks again
rickead1
Sep 02, 2010 | Dishwashers
I AM LOOKING WHERE IS THE OIL PUMP IN 2003 KIA SEDONA ENGINE
take the sump off and you will find it ,to get the sump off you will need to remove the engine
Jun 27, 2010 | 2003 Kia Sedona
Replace oil pump on a 1993 jetta celebration 3
The oil pump is located into a sump.Loose all the screws around the sump but the first drain the oil.You need also new sump gasket.
Apr 23, 2010 | 1993 Volkswagen Jetta
Dishwashers Logo
80 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
