Question about Kenmore Dryers
Kenmore Front Load Dryer w/steam error code E64 I believe this unit is made by LG.
Kenmore Front Load Dryer, w/steam error code E64, blackish mark on back inside of tub looks like it got too hot. Screen appeared plugged from the apparent paraffin on dryer sheets...I cleaned until it looks like new - and cleaned out trap beneath the dryer screen - to no avail. I am still getting an E64 error code and would like to know what that indicates.
  • 78 Answers
SOURCE: My outdoor dryer vent leaves
i'm sorry, but that happens with all dryer vents. you might consider rerouting the vent to another location. while you're at it the vent hose needs to be cleaned out, they tend to clog up and decrease drying efficiancy.
Posted on May 03, 2008
reg501
  • 413 Answers
SOURCE: lint trapped inside dryer housing
SHUT OFF POWER AND GAS
1. Begin by opening the door removing the two screws on the left side of the door opening.
2. Then remove the screws that secure the door hinges to the cabinet. Lift off the door (may take some wiggling)
3. Grasp the outer top sides of the front panel and pull toward you.
4. Lower the front panel and lift off.
5. At each top corner remove the screw and latch that hold down the top.
6. You should be able to do the rest from here.
Posted on Jun 14, 2008
SOURCE: Kenmore Oasis dryer F40 error code
I had this same issue. My dryer would run and heat up but then stop and give me the f40. I measured all thermisters and everything was in range. The tech sheet stated that I needed to buy a new control board and I did. Same problem.
The solution was a loose connection on for p4. I took needle nose pliers and squeezed the connector to make it fit tight on the board and everything is working now.
Bottom line, expensive dryer with cheap connectors.
Posted on Apr 21, 2009
  • 57 Answers
SOURCE: Kenmore electric dryer, 600 series, runs but does not heat.
check you're thermostats for continuity, they are normally 3 thermostats, reset stats have a button on them please press, if not thermostat its your heating element
Posted on Jun 20, 2009
blueextc3221
  • 15935 Answers
SOURCE: How do I take the front panel off my kenmore elite
The E1 displayed indicates the thermistor is open and needs to be replaced.
The connections can be loose but the most likely cause of an E1 error is a bad thermistor.
The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
If you're comfortable and confident in your do-it-yourself skills and have access to a volt/ohm meter you can check and replace this part yourself.
The thermistor is available from the following: www.searspartsdirect.com
Enter your model # in the appropriate box to get a full parts break-down and diagrams.
To access the thermistor see the image below.
Remember to unplug the dryer from power first.
The thermistor will have a black and red/white wire on it.
You can check continuity across it with the meter and if the circuit is open then the thermistor needs to be replaced.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
The thermistor -may- check ok when cool and freak out when warm!
http://media.fotki.com/1_p,wkrsfrgsskrbttbxgtqsskgwtqkq,vi/wbsdwtgwgxwrgbbgsgs/1/1303472/5961857/image6767img-or.gif
HE3 Dryer: http://media.fotki.com/1_p,wbfbgrrwtrrkfttxgtqsskgwtqkq,vi/kgwgwwwdkxkfkkgwgqs/1/1303472/5961857/image7127img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
What is wrong with a code e64
It probably requires a technician to test it.
You haven't identified the manufacturer and model, but it is likely the following result of a Google.com search suggests a problem:
https://www.justanswer.com/appliance/7f3w8-frigidaire-dryer-e64-error-code-dryer-will.html
Why Am Getting Error Code E64 On My Frigidaire Dryer
Mar 19, 2018 | Dryers
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
I am getting a error code E64 on Frigidaire affinity model# FASE7021NW0 It still get hot but keeps cutting off, what should I do
Hello friend, that's a great question!
From my understanding your Frigidaire Affinity dryer is displaying an error code of "E64". An "E64" error code stands for the heater circuit is open. This could be a possible problem with your heater, wiring harness, or even a miscommunication within your dryer. In order to clear out any miscommunication you can perform a reset on your dryer and to do that you need to unplug the power cord for at least ten minutes. If this does not help to resolve your issue I would recommend having a professional technician out diagnose and repair your dryer to help avoid any future issues or unnecessary part purchases. Hopefully this information is helpful. -Matt
Mar 02, 2015 | Frigidaire Dryers
E64 error code electrolux dryer
You have not specified Tumble dryer model so I can not say for certain that my answer is correct. Fault codes can sometimes vary depending on the platforms appliances because today some manufacturers release new models twice a year and thay have the absolutlly right to make changes and improve the efficiency of new appliances (also change fault codes).
E64 - Heater thermostat
  • Thermostat faulty (replace heater unit)
  • Heater unit faulty
  • Wiring faulty
  • Electronic board faulty.
Dado
Aug 09, 2014 | Electrolux Dryers
Kenmore front load model 40272900 e codes (control Error)
If the washer's full model number is 79640272900, then the unit was made by LG. Looking up LG front-load washing machine error codes will give the available codes. Here is one listing: http://www.appliancefactoryparts.com/blog/2010/02/washing-machine-fault-codes/#LG . Some of these codes are also available in the manual in the Trouble-shooting section. Manage My Life has the manual as a PDF here: http://www.managemylife.com/mmh/owner_manuals/17952/KENMORE-Residential-Washers-L0910072?brand_name_search=79640272900 .
I hope this helps.
Sep 21, 2013 | Computers & Internet
MY FRIGIDAIRE AFFINITY FRONT LOAD DRYER THE PROBLEM IS IT WILL START DRYING BUT AFTER ABOUT 2-5 MINUTES A BUZZ SOUND WILL COME ON WITH THE E64
Hello Marcheller, thank you for your question! Typically error code E64 is an indication that the heater circuit is in the open position. This is not a simple DIY job; I would highly recommend consulting a professional to move forward accurately. The certified technician will need to check the heater coils and connections for open circuits. Depending on the diagnosis the heater or wiring may need replacing.
Aug 15, 2013 | Frigidaire Affinity ATF7000ES Front Load...
Dryers Logo
189 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
