Question about Maytag 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White
How to remove the ice drawer/unit to empty current ice in a maytag side by side
Model # M202766GEW
  • Wilda Deel Apr 20, 2013
    Figured it out myself. Thanks
docjohn174
  • 943 Answers
SOURCE: Ice forming on the a shelf in my refrigerator
Hi .Thanks For The Question. You Probably Have A Drain Problem, From The Freezer TO The Back Of The Fridge. Pull Fridge Away From Wall ,Remove Back Panel Clean All Coils. Locate Drain Hose From Freezer. Clean Tube. And Fridge Is A Bit Too Cold
Posted on Oct 03, 2008
Maytag317
  • 1136 Answers
SOURCE: My ice maker on my Maytag MFI2568AEB stopped.
Hi, You can use a hair dryer to thaw the inlet tube out. Some mofeld will aloow you to remove the inlet tube from behind the refrigerator. If yours can be removed, this would be the easiest way.
If the tube plugs up again, you should replace the inlet valve. Thhey sometimes will drip a little causing the inlet tube to freeze.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 14, 2009
SOURCE: Water on floor from freezer side of Maytag side by side unit.
Yes I just had that happen to me. An appliance guy came over for my stove and I asked him if he could tell me why I wake up everyday to a puddle. He told me to take the baskets out unscrew the three screws and pull the panel off, then pour some hot water in it and use a turkey baster to blast the drain hole with. It worked. Sears repair man couldn't even figure that out when it was under warranty. Took me 15 minutes. Good Luck
Connie Marie
Posted on Aug 14, 2009
woodchuck789
  • 4059 Answers
SOURCE: hi we have a maytag
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer
Posted on Dec 16, 2009
Testimonial: "we are very pleased with the advise my husband is working as i type this it was just what you said it was thank you"
heatman101
  • 43501 Answers
SOURCE: Maytag side-by-side refrigerator ice-maker inoperative
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Jun 04, 2010
Occasional puddle of water on the floor that is coming from the freezer area
All refrigerators have a drain. This is for when your unit goes into a defrost mode. You do not have to empty your drain pan because the water evaporates by the heat of the compressor. If you have a side by side unit. Open your freezer door and remove the lower drawer down by your feet. If it is frozen in there by ice or if when you remove it there is ice on the bottom. It is your drain that is clogged. Any other questions. You can click contact Apco Now..
Apr 04, 2013 | Maytag Refrigerators
Maytag mfd2560hes how to replace defrost thermostat
The service manual 16025629 is here: (7.46 mb)
http://appliancedigest.com/index.php?/files/file/498-16025629-maytag-amana-bottom-mount-refrigerator-service-manual
You will have to register to download the manual.
Freezer Back Panel
NOTE: Freezer compartment should now be empty and
walls should be clear of anything that will
obstruct removal of back panel.
1. Loosen screws that mount icemaker to freezer
compartment walls.
2. Pull icemaker gently away from wall of compartment.
As you do so, work fill cup free of fill tube. Unplug
icemaker electrical connector and remove icemaker
from unit.
3. (Pull out Drawer only) Loosen and remove screws
that hold 2 basket glides in place at left and right
sides of compartment.
4. If unit has no icemaker pry with flatblade icemaker
connection cover. Remove cover.
5. Remove hex head screws that hold back panel and
remove panel.
6. Squeeze tabs on ice maker plug to release it from
back panel
Defrost Terminator (Thermostat)
1. Terminator is fastened to evaporator tubing with a
spring clip.
2. Snap terminator off tubing and cut wires to terminator.
3. Remove terminator from unit.
That is word for word.
See parts list diagram here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170924&diagram_id=28480593#d28480593
This may help with screws but the defrost thermostat is item 32 and not shown on the diagram. Once you hav ethe access panel off loof fok the thermostat. It will have 2 wires and tough metal clip on it.
Thanks for choosing FixYa,
Kelly
Jul 20, 2011 | Maytag MFD2560HES Bottom Freezer French...
I have model # EW23CS65GS1. It seems there is no way to remove the drawers to clean under them and behind them????? There is nothing in the manual. I've had the fridge for 2 years and the filth is...
Our Electrolux drawers (on tracks) are removed by pinching the small tabs together whilst pulling up on the emptied drawers; this is done with the drawers in the open position - one side, then the other.
Oct 31, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Our side by side electrolux refrigerator will not disperse cubed ice, only crushed. everything else works fine. Model number PRLS267ZAB8
Pull the ice drawer out and look for the small, metal "arm" that sticks out of the back of the outside of the drawer. Empty all the ice out and make sure this arm swivels freely. Sometimes it can get stuck.
Aug 29, 2010 | Electrolux Icon Professional Ice Maker...
Maytag Model MZD2768GE
I've got the same problem with my 2nd drawer. Did you figure out the problem with your top drawer?
Oct 06, 2009 | Refrigerators
My ice maker on my Maytag MFI2568AEB stopped. Everything mechanical seems fine. After removing the ice tray (drawer) I can still feel ice up in the unit. I cannot remove this unit, even though I pull back...
Vic
Jun 14, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
MY Maytag Wide by Side freezes in the produce drawers.
When a unit freezes in the lower drawers this is usually due to a thermistor which is not functioning properly. If you can provide your model number I can try to locate your schematic to your unit showing the thermistor that you would replace to alleviate this issue. I will await your reply as to the complete model number of your unit.
p.s if you had ice up the top of the unit as well then you would look at the damper door otherwise known as the diffuser door in some units or the control for the door as the problem area in your unit.
Thank you,
Rick
Jan 21, 2009 | Maytag 26 cu. ft. Wide-By-Side...
Aug 23, 2008 | Maytag MSD2656G Side by Side Refrigerator
Maytag Oven model MES5752BAW when using the bottom drawer it works hard to close and goes off track and one side is higher than the other. Please help on how to fix this problem this oven was bought Aug....
remove drawer entirely. and one side at a time try reinstalling the rear wheel over he fixed (mounted wheel on unit. one side at atime with drawer empty, always easier.its gonna take some fiddling but it'll go. if it falls off track regularly then its possible that the lower frame of unit has bent and might need a little "persuasion" to line up correctly
Mar 08, 2008 | Kitchen Ranges
Maytag 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White Logo
26 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
