Can't open a certain website
I am trying to go to a website that works on every other computer i try. on my laptop I have tried to open it in Chrome, Firefox, and Explorer. It needs Silverlight to run, which I have installed, but it seems to not be able to see that the site exists.
  • 7,627 Answers
What website?
Posted on Apr 19, 2013
  • 17 Answers
SOURCE: Problem With Internet Connection
Did you install the correct drivers that came with the computer? Vista-Ready? How does it look when connecting with other websites
Posted on Nov 11, 2007
dvdcdlaser
  • 1285 Answers
SOURCE: My Acer Aspire One netbook
have you downloaded any thing recent? this may be the cause ......... all I can suggest is restore the systems far back as the beginning of December last year.......(when everything was probably running smooth)
good luck
note try opera
http://www.opera.com/download/
Posted on Jan 19, 2011
JaxPlanet
  • 922 Answers
SOURCE: I cant seem to access
Reset Internet Explorer. http://support.microsoft.com/kb/923737
If that doesn't work the problem is likely to be Facebook's website which you cannot fix.
If this helps please vote for my solution.
Posted on Feb 01, 2011
Slasher_X
  • 767 Answers
SOURCE: Having a network problem. I have tried several
So Internet Explorer 8 or 9 works but no other internet browsers?
Posted on Mar 22, 2011
  • 422 Answers
SOURCE: I'm using IBM ThinkPad R51
yes. police can come up to your apartment (serious!)
use a proxy
Posted on Jun 12, 2011
Evite website keeps freezing up. Both in chrome and explorer. works on another computer just fine. popups have been allowed. cookies and cache are cleared. It seems to freeze up when it's trying to...
Fixing Hardware or Software Issues
  • If the freeze happens every time a certain hardware device is plugged in or switched on, the device itself might be to blame. Check the manufacturer's website for updated drivers for the device, and download and install them to erase any bugs that might exist in your version. Similarly, if the freeze only happens when using one particular application, that program might also be the root cause. Check the developer's website for updates. If the problem persists, uninstall and reinstall the program. This process replaces any software files or settings that may have been damaged or deleted.
Overwhelming a PC's processor or memory by requests can also lead to the computer freezing up. If the issue occurs when large files or complex applications are being handled, shut down any running application or background utilities you don't need for the project you're working on. This frees up CPU time and RAM space. Within individual programs, avoid opening up multiple files or websites at the same time. If the problem persists and if opening multiple large files simultaneously can't be avoided, consider a hardware upgrade
Please follow this instruction.
God bless you
May 25, 2013 | Computers & Internet
When I connect My Samsung VP-D77i Camcorder to my Laptop I always get a message saying "cant open camera device". My Laptop does not have a fire wire port but only with USB ports. It has Windows 7 Pre
First, try attaching the camcorder via usb cable with the camera OFF, then turning it on. This may trigger Windows to activate the driver scanner and activate the driver. If you've been attaching with camcorder off, try attaching with it on, to see if that activates driver installation.
If that doesn't work, you may have a low-power usb plug; often the usb ports in the back of the computer put out more juice than the handy ones on the front. You may also need a shorter and more robust usb cable; I've found with various cameras and phones that certain usb cables work fine for recharging but won't necessarily provide adequate data transfer.
Jul 03, 2012 | Samsung VP-D77i Mini DV Digital Camcorder
My smpk4083 wont charge
It can be 1 of 4 things. 1: the way your charging it. 2: the cable. 3: the battery. 4: the conection on your device.
1: Try charging it different ways. (Different wall outlet, laptop, computer, etc.) (Note: some laptops and/or computers might not have a strong enough charge to recharge certain devices. You'd have to adjust the power setting in the control panel or the manufacturers setings.)
2: Try using a different cable. (If you don't have one try wigleing both ends to see if you get a charge.)
3. Try another battery. (Most people overcharge batteries thus shortening the recharging capabilities.)
4. Check to see if any of the pins are messed up or missing on where you plug the wire into your device. (If any are missing you can open it up and replace the part.) Sometimes people end up pushing them in by accident when they conect there charger, so the wire doesn't make a good conection after a while (another case where wiggleing the wire could work).
Oct 04, 2011 | Audio Players & Recorders
Mediasmart webcam is not working on my HP Pavilion dv6 laptop. I went to device manager and it said that it's working properly. I've tried opening it through websites, and it crashes. When I open...
NO OS stated, XP you know its dead right if XP, why not tell ?
help near impossible lacking that key fact
what cam , the one built in?
the USB ports must work on HP or the cam will fail.
no many HP laptops, yeah, 2 drivers just work the USB port and cam both.
What OS?
the drivers are at HP.
run the HP assistant yet.http://h18021.www1.hp.com/helpandsupport/hp-self-support.html
load the drivers yet, from HP and nobody else
oops its retired now, legacy.
no support page, try the assistant and pray.
finding drivers for old PC is getting hard with this silly 10 year rule.
there is a hard way to get them.
lots of steps, ask.
Jan 05, 2018 | HP Pavilion dv6000z Notebook
When trying to access certain websites I'm disallowed, with a message that states "content blocked." I've turned off the search filters, still cannot access the sites.
Try dowloading Opera Mini Browser for your phone and using that, as that may aloow you to get around whatever is blocking certain websites. If that does not work, contact your network provider as it may be down to them.
Jun 02, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
My computer hangs when I am try to open.
You've mentioned the make and model of the laptop, which is great. However you haven't mentioned what exactly is "hanging", are you trying to open a certain program, or is it not working when you're trying to boot, etc
Please give as much information about the problem as possible, it helps us help you
May 19, 2011 | Toshiba Satellite L500 Series Notebook
I cannot load up petville anymore what is the problem
There are certain problems why you can't load petville. One possible is your Adobe Flash Player. Try to update it to a new version. 2nd one. Is the cookies stored in your computer. Try to removed it by deleting all cookies and internet history. Clean unneeded files from your hard drive. Download this great little program called CCleaner. It gets rid of a lot of files that are just clogging up your hard drive including your browser cache and cookies. It's safe and it works! You may probably have unwanted programs. This programs prevent you from opening or playing your petville. It is best recommended to uninstall it. Restart your computer. I have been working with and repairing computers for over 15 years now and it still amazes me how simply restarting a computer can do so much.
May 15, 2011 | Computers & Internet
I just bought my dell laptop less than three months ago and the sound is not working anymore. how do i fix this? It is not on mute. the volume it up. I've checked everything. I've restarted the...
Hi whitco0313,
A corrupted or missing audio driver can cause this problem. You can try to do a System restore back to the earliest date that it worked fine. If this doesn't help, you need to check out Dell website and download the audio driver compatible for your laptop model and operating system version.
I hope this helps, please inform me if this resolves your problem or not to check for other resolution that we could try. Thank you.
May 12, 2011 | Dell Computers & Internet
Boutht new Acer4738 laptop recently. I tried to install Bluetooth driver which came along with driver CD . However, I'm getting No Bluetooth device was detected error. Also, Fn+F3 also not working.
Your computer may not actually have Bluetooth capability. Bluetooth is one of those features that is "on certain models only", according to Acer's site. My daughter's Aspire has a Bluetooth switch on it, and Bluetooth drivers on the CD, but no Bluetooth card is installed. I discovered this when I opened her computer to see why the Bluetooth wasn't working. I've found this to be true for several other models since. This strikes me as misleading and possibly false advertising, but I'm not an attorney.
The only way I have ever found to be sure if the computer has Bluetooth is to open it up and look on the board. Depending on how new "new" is, your computer might still be under warranty so you probably shouldn't bother. Instead, you can try contacting the retailer where you purchased the machine and see if they offer warranty service. Or follow the process given in your manual or on Acer's site for obtaining service. Then if your model does have Bluetooth installed they can fix it, or you'll know for sure it wasn't installed. Then you can buy a USB Bluetooth adapter.
Apr 24, 2011 | Computers & Internet
Nov 05, 2007 | Sony VAIO VGN-TXN25N/B PC Notebook
Computers & Internet Logo
David Payne
David Payne
