Question about Apple iMac G5 Desktop
What can I do to stop by iMac G5 LCD screen from being pixelated and getting dark blue and pink horizontal lines across it?
My screen looks pixelated and no matter what I click on whether I am opening a new program or trying to view a graphic or accessing the internet, my screen is not clear, and is discolored?
  • 331 Answers
This very likely a failure in the LCD screen. If you are seeing thin or wide bands, vertical or horizontal across the screen, then you will need to have the unit serviced to repair or replace the screen. If the unit has been dropped or struck (hard) it is possible the connector cable for the screen has come loose, but this is not usually the issue. If the unit is still under warranty, get it serviced. If it is not under warranty, there are several good web sites that provide Do-It-Your-Self instructional videos as well as parts, both new and refurbished and used. If you google your specific model and "screen replacement", you will see a number of results appear that would be of use.
Posted on Apr 26, 2013
fire sine
  • 382 Answers
SOURCE: Screen Changes and Comupter freezes
It may be possible that the power supply, display and or logicbpard may be having issues. Apple recommends resetting the pram and nvram. If issue persists reset SMU. YOur machine is 6 months outside of the original warranty, but if you purchased the 3 year extension plan, you may want to take action on it.
http://search.info.apple.com/index.html?q=imac%20g5%20reset%20pram&lr=lang_en&search=Go&type=
http://search.info.apple.com/index.html?q=imac+g5+reset+smu&type=&search=Search&lr=lang_en&search=Go
Keep me posted.
Posted on Nov 11, 2007
  • 40 Answers
SOURCE: G5 Graphics Card Freezes or begins to show lines on display
Since you are able to see your mouse pointer move, the display is refreshing so the problem is with something other than the graphics card. Generally software / OS related.
So assuming you aren't experiencing a hardware failure try the following...
Boot from the CD the computer shipped with.
Insert CD and restart the computer holding the "c" key
Your computer should boot from the CD
If so run disk utility from the CD and repair the disk as well as permissions. If there are any errors repair again.
If this is successful your computer "should" be repaired. If it is still freezing, use your CD to perform a Archive and install which should keep all your personal settings and installed software intact.
Cheers
Posted on Mar 02, 2009
  • 3 Answers
SOURCE: iMac G5
If it isn't the power supply, some of the early G5 imacs had a capacitor failure issue...mine just died, in fact. It was just shutting off by itself, even turned on once by itself....but tonight, when it shut down, it would not restart. I opened it up and looked and sure enough, 11 bulging/leaking capacitors. My local service center says there are two options: 1. new mother board-aprox $500 or replacing the capacitors- between $170-200. Until Dec 15, 2008..this was apparently covered under a special warranty extension program Apple had....typical!
Posted on Mar 07, 2009
damien729
  • 221 Answers
SOURCE: My Apple IMac G5, 2GHz 512 MD DDR SDRAM (Sr.No. W85399C8SDY)developed a couple of white lines on the screen a few months ago. These have now spread to cover almost the entire LCD display. What is the
Hi, it seems like a motherboard problem (hardware), you will probably need to bring the mac to an AASP. Before, you can try the Apple Hardware Test, or resetting the PRAM (Hold the cmd, alt, p and r keys)
Posted on May 29, 2009
Macs R We
  • 481 Answers
SOURCE: imac g5 17 gets some power but no display
Assuming you have the model with four diagnostic LEDs, the lack of LED-3 indicates that the computer and the LCD display are NOT communicating. This LED should be ON when the computer is turned on and video signal is being generated.
The first solution is to reset the PRAM (hold command-option-P-R after the boot chime until you hear another boot chime). If video does not appear, then power down the computer and reset the SMU by pressing the SMU button ONCE ONLY. (The SMU button is located just south of the fan housing and is the button further away from the fan; the other button is a power button.) If this does not fix the video, the next step is to remove the optical drive. If this does not fix the video, put everything back together and attach an external display using the dongle supplied with the unit. If the external display fails to work, you have a logic board problem; otherwise, you have an LCD panel, inverter, or cable problem.
Posted on Apr 02, 2010
Dark screen problem
The tcon Board or the LCD panel is faulty. You have to replace the Tcon Board to confirm whether it was Tcon or the LCD panel.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 18, 2016 | Sony Bravia LED KDL-55HX751, 55, FullHD,...
Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line?
Black square on the screen Vizio Gallevia 47" 1080p - Fixya
www.fixya.com/support/t355299-black_square_screen_vizio_gallevia_47
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
bad screens display vertical lines with a white background ...
https://www.ifixit.com/.../bad+screens+display+vertical+lines+with+...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 ‎pixel
Broken LG LCD TV Capacitor Black Screen My Wont Turn ...
? 6:27
https://www.youtube.com/watch?v=EbGiXqBAvvo
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal ‎pink ‎pixel ‎line
Jan 05, 2016 | LG Televison & Video
A fine vertical blue line running through imac screen
How long is a piece of string? is the kind of question you've asked. I've a sneaking suspicion you'll get sick and tired of it before it finally goes.
Jun 03, 2010 | Apple iMac G5 Desktop
Black line (strip of pixels not working) horizontal across screen
If a whole line of pixels is dark, you've got a bad transistor in what's called a "Passive Matrix" display. For your future purchasing decisions, while an "Active Matrix" display costs a little more, it has individual transistors for each pixel, rather than one per row and column, so when a transistor goes bad, it only turns one pixel black rather than a whole row or column.
Sep 12, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
Horizontal (dashed) line across screen
On the KDFE55A20 this sounds like a bad Q-Box. I would get an estimate from a Sony authorized servicer as this part may be quite expensive. On the 55A10 model this may be the B-Block and is also quite expensive. Getting an on-sit estimate would be the first step I suggest. Again go with an authorized Sony servicer. Call Sony or go to Sony.com for customer service. Good Luck
Nov 21, 2007 | Sony KDF-E55A20 55 in. LCD Television
Keep me posted.
Nov 10, 2007 | Apple iMac G5 Desktop
Screen just flashes horizontal pink & blue horizontal lines when you turn it on
It sounds as though you may have a faulty lcd. Replace lcd(screen) and see if it solves the problem
Sep 25, 2007 | Vivitar ViviCam 5385 Digital Camera
IMac Monitor
What type of monitor is this? If it is an LCD screen, you may have some dead pixels. Please reply with some more details about your specific monitor.
Sep 05, 2007 | Apple iMac G5 Desktop
Apple iMac G5 Desktop Logo
159 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
