Question about 3M VISUAL SYSTEMS DIVISION Office Equipment & Supplies
Need 78-8099-9038-1 bulb - 3M VISUAL SYSTEMS DIVISION Office Equipment & Supplies
Tail light is out..do i need a fuse or bulb?
If just 1 tail light out it is your bulb, check for corrosion in bulb holder aswel, when you fit any rear bulb give the bulb holders and plugs a spray with wd40, stops moisture & prevents corrosion.
Mar 11, 2015 | Cars & Trucks
Tip
Brake Lights Dull or Flickering - All Cars
Dull or Dim Brake Light Repair: If your car has a dull or dim brake light it is dangerous to you and other drivers. A dim brake light is a mystery to most people because the bulb is working, just not correctly. First confirm a new and correct brake light bulb has been installed. Next, turn the ignition key to the "on" position and have a helper depress the brake pedal. With the bulb installed touch a grounded test light to the outer bulb holder ring. If the bulb brightness changes the bulb socket ground has high resistance and needs to be repaired or replaced.
Flickering Brake Light Bulb Repair: A flickering brake light bulb can be very distracting and annoying. A brake light flickers because the power or ground is being obstructed momentarily. The most common cause for this condition is a loose fitting bulb socket. To check for this condition remove the brake light bulb in question, while a helper hold their foot on the brake pedal move the bulb around slightly in the socket. If the bulb flickers replace or repair the bulb socket as needed to regain proper brake light bulb operation. If the brake light bulb socket tests ok wiggle the brake light fuse and wiring at the brake light bulb socket, brake light switch and turn signal switch (American cars). If the brake light bulb flickers repair the component or wiring as needed.
Preferred Procedure: Always replace brake light bulbs with manufacturers recommend replacement bulbs. If you cannot find the correct replacement bulb part number consult an auto parts store for additional manufacturer information.
Common Problems
When brake light bulbs are replaced with the incorrect bulb causing no or dim brake light operation
If the brake lights stay on continuously it could mean the brake light switch has failed or an adjustment is needed.
on Dec 18, 2009 | Honda Civic Cars & Trucks
How do i replace the odometer cluster on a 2001 Buick Century? Odometer only light up if i hit dashboard, Then it goes out.
You dont need to replace the cluster you just need to replace the bulbs, by hitting it the bulb filment thats bad make a connection, if you remove the cluster and look at the rear of it you will see the bulbs, there are many bulbs some for the battery light and oil light, so use a flash light and when you remove a bulb shine light through the hole and see if it the correct bulb or if its a symbol bulb, most of the time the lighting bulbs use a diffrent color socket, what you do is untwist the socket then it pulls out and the bulb is on it, you then pull bulb out of socket and install new bulb on socket and twist back in, you dont need to replace the whole cluster and the bulbs are sold at any parts place, take one out and match it up it should be part # 194 bulb.
Dec 12, 2010 | 2001 Buick Century
I need to know what bulbs I need fo rthe GE
main bulb is ge part # AP2006861 and is a 60 watt common light bulb/the dispenser bulb is a g.e. part # of AP3884244 and you should be able to get these at a grocery store or ace hardware
Oct 04, 2009 | GE GSL25JFPBS Side by Side Refrigerator
2000 beetle bulb for heater control
yes you can. You will need a pair of pliers a thin rag one that is not to bulky. and a piece of vacuum line. like the vacuum line on your car. small. well first you need the replacement bulb get at dealership it is small. that will be the size of vacuum line you need. with the pliers carefully pull off your fan speed knob you will see the bulb back in the hole. take the vacuum line push onto the bulb twist line and pull it should pull the bulb out. then put new bulb lightly into vacuum line look at the slots where the bulb goes you will need to line up the bulb should be straight up and down. push bulb in you will feel slight click then reverse the way you turned the vacuum line to pull out just the line. and you should be good make sure the bulb lights up before you put the knob back on. good luck
Sep 12, 2009 | 1999 Volkswagen New Jetta
I need to change a dead bulb in my headlights and I dont have the owner manual.
96 sable, only ino I have. should be similar. Please rate, thanks
  1. sth~us~en~file=ani_caut.gif~gen~ref.gif WARNING: THE REPLACEABLE HALOGEN HEADLAMP BULB CONTAINS GAS UNDER PRESSURE. THE HALOGEN HEADLAMP BULB MAY SHATTER IF THE GLASS ENVELOPE IS SCRATCHED OR THE HALOGEN HEADLAMP BULB IS DROPPED. HANDLE HALOGEN HEADLAMP BULB CAREFULLY. GRASP HALOGEN HEADLAMP BULB ONLY BY ITS PLASTIC BASE. AVOID TOUCHING GLASS ENVELOPE. KEEP HALOGEN HEADLAMP BULB OUT OF REACH OF CHILDREN.
    NOTE: A properly aimed headlamp (13008) assembly normally need not be re-aimed after installation of bulb. A burned out headlamp bulb and retainer (13N021) should not be removed from the headlamp until just before a replacement headlamp bulb and retainer is to be installed. Removal of a headlamp bulb and retainer for an extended period of time may allow contaminants (dust, moisture, smoke) to enter the headlamp and affect the performance of the headlamp. When servicing the headlamp bulb and retainer, energize the headlamp bulb and retainer only while it is contained within the headlamp body.
    Make sure headlamp switch (11654) is in OFF position.
  1. NOTE: On some models the clamps holding the integrated relay control module (IRCM) may need to be unsnapped and the module pulled aside to gain access to the driver side bulb.
    Open hood and locate headlamp bulb through hole in upper radiator support assembly.
  1. Remove headlamp wire connector from headlamp bulb and retainer by pulling the connector and wires in a rearward direction.
  1. Remove headlamp bulb retainer (13N019) by rotating counterclockwise (when viewed from rear) about one-eighth turn and sliding headlamp bulb retainer off headlamp bulb and retainer. Keep headlamp bulb retainer as it will be used again to retain new headlamp bulb and retainer.
  1. Carefully remove headlamp bulb and retainer from opening in headlamp bulb (13007) by gently pulling straight out of opening. Do not rotate headlamp bulb and retainer during removal.
Jul 05, 2009 | 1991 Mercury Sable
I NEED TO CHANGE LIGHT BULB WHERE WATER IS DISPENSED IN DOOR OF AMANA SXD26VW. PUT IN 12V - 6 WATT & IT BLEW THE BREAKER. WHAT SIZE BULB IS NEEDED. NO MARKINGS ON OLD BULB & NO OWNERS MANUAL.
It requires a 120 volt bulb. If it is a screw-base bulb, it's the same bulb as used in plug-in nite lights. If it's not a screw-in you'll need to go to an appliance parts store to the proper bulb.
Apr 23, 2009 | Refrigerators
Artograph prism not turning on
you need to get the exact bulb.
Apr 04, 2009 | Office Equipment & Supplies
Can I change my own front light bulb in 2005 slk350
Yes you can.  The bulb number is a "D2S" if you have the HID (High Intensity Discharge) bulbs.  Most auto parts stores will need to order them but it should only take a day or two.  O'Reilly Auto Parts shows the bulb costing 89.99.  They are very expensive compared to the usual $10 bulbs on regular cars.
If you don't have the HID bulbs, yours is a halogen bulb.  The bulb number is "H755".  This one is the $10 bulb.
Double check which bulb you need before purchasing one! Most parts stores can tell you which bulb you need just by looking at the car's headlights.
Jan 31, 2009 | 2005 Mercedes-Benz Mercedes Benz SLK350
Need to replace headlight bulb in honda civic 2003
How To Install Replace Headlight and Bulb Honda Civic Sedan 01-03 1AAuto.com
Dec 31, 2008 | 2003 Honda Civic
106 people viewed this question
Top 3M VISUAL SYSTEMS DIVISION Office Equipment & Supplies Experts
jasbo
jasbo
Are you a 3M VISUAL SYSTEMS DIVISION Office Equipment and Supply Expert? Answer questions, earn points and help others
