Question about Car Audio & Video
My kicker 2500.1 Mono block amp started to smoke and smell of burnt wires. Got power still but no sound
  • 173 Answers
SOURCE: L7 wiring options
yes it should work fine i would bridge them up to 4 ohms each speaker then bridge them back bye conectin them on the amp by puting the red with the red and puting the black with the black if the amp only has 1 chanel then put both speakers red on the same positive on the amp and same with the negative now to bring the ohms up to 4 ohms conect the solid red to the black with dot with a short wire ok then the ones that are not run together will go to the amp giving offf 4 ohms and with the 2 speakers bridged together thay will reduce to 2 ohms witch means that eatch speaker will get about 600 wats of rms from the amp
Posted on Sep 14, 2008
SOURCE: how to install..........
COMTE UNA VERGA GRANDISIMA WEY Y SE CONNECTAN SOLAS IJUUUUUSU CHINGADA MARDEEEEEEEEEE
Posted on Sep 16, 2008
blueextc3221
  • 15935 Answers
SOURCE: solo x 10 dual 2 ohm smells burnt and smoke
there is no such speaker as a solo-X L5.
The Solobaric L5 is 450Watts RMS and 900 Peak.
Check your documentation, and no warranty except Massive Audio covers Burned Voicecoils as it is deemed customer abuse.
If it is a typo, and not an L5, your combination (as long as each is level matched) should be ok to run on that sub. When wiring it as you describe, the two amplifiers need to be identically matched in order for both coils to play at the same level.
Seek professional installations so your warranty is intact.
Posted on Dec 21, 2008
Shadowmaru
  • 33 Answers
SOURCE: wire my kicker
This will help you :)
Below is a link to the subwoofers manual where is clearly states how to wire it all up, it includes both the 2ohm DVC and 4 ohm DVC models.
Click Here for the L7 Solo Baric Manual
Posted on Feb 11, 2009
etirbynnor
  • 655 Answers
SOURCE: How do you wire 4 kicker cvr dual voice coil 4ohms
Hello antjobe,
According to Kicker the 1500.1 is only stable to 2ohms. So you will want your 4 CVR's to present a 2ohm or higher impedance to the amp.
The best configuration would be to wire the voice coils in series (each sub 8ohms) and then parallel all of the subs to the amp (2ohms). Here's a link to the diagram.
Hope this helps.
Posted on Jun 08, 2009
So I just bought a kicker cx 300.1 mono block amp to run my 10 inch comp d 4 ohm 300 watt sub. I ran it parallel and it smells like the coils are burning. Help
That's only normal for the burn in period. Make sure you're not running it in 2 ohm by wiring the sub wrong. That amp is not really 2 ohm stable for a sustained period
Feb 03, 2015 | Kicker Car Audio & Video
How do I wire a kicker mono amp for my subwoofer to a kicker 4 channel amp that is already hooked up to run the 4 6x8 speakers
you should have an output on the amp running the 4 6/8's connect to kicker inputs hope you got a cap(capacitor)to run this set up and a good wiring kit.if so just run all the power cables to the power block feed the amps,ground them and don't forget the remote wire and you should be fine
Sep 23, 2014 | Car Audio & Video
My amp started to smoke, and cut off,had a real loud burning smell,has not worked since.
Sounds like it was playing? If it was your voltage dropped and the mosfet power supply got toasted. These amps are notorius for burning up at low voltage. Kicker did not put a low voltage shut off on it.,
Sep 08, 2011 | Kicker ZX15001 1Channel Car Amp
How do you wire 4 kicker cvr dual voice coil 4ohms to a 1500.1 kicker mono block 1 channel amp, they sound distorted when i turn them up, how should i wire them?
Hello antjobe,
Hope this helps.
Jun 08, 2009 | Kicker CVR12 Car Subwoofer
Got a 12"kicker L74ohm sub and sony xm-D9001GTR mono amp
Hello juan_penaloz,
The Kicker L7 has an RMS power range of from 50-750 watts and a maximum power handling capability of 1,500 watts so your Sony amp will power it OK. A more powerful monoblock like the Alpine MRP-M1000 or the Kicker 08ZX750.1 would provide even more power and could operate safely at 2ohms.
You have the voice coils wired properly for the Sony amp. It's OK to have the sub impedance higher, but you definitely do not want it lower than the 4ohms the amp is rated at in bridged mode.
Hope this helps.
May 26, 2009 | Sony XM-1252GTR Car Audio Amplifier
DONT KNOW HOW TO RUN 2 OHMS
Hello storres18,
If you have the Kicker model number 06CVX122, with dual 2ohm voice coils, they can be connected to a mono amp at 2ohms. First jumper the voice coils in series, the dotted positive (+) to the undotted negative (-) (or vice versa). Each sub is now 4ohms. Then wire both of the remaining positives and negatives together on the amp terminals (in parallel). The amp sees a 2ohm load. Here's the diagram:
If you have the Kicker model number 06CVX124 with dual 4ohm voice coils, they cannot be wired to present a 2ohm load. They can only be wired as a 1ohm load (too low for the amp) or as a 4ohm load (at reduced power). Here is the diagram of the 4ohm wiring:
Hope this helps.
May 10, 2009 | Visonik V900XD Car Audio Amplifier
Solo x 10 dual 2 ohm smells burnt and smoke
Dec 21, 2008 | Kicker Solo-Baric L5 Car Subwoofer
Mono amp
well first check ur wireing next the amp is turned down or just bad amp let me no if that helps
Sep 26, 2008 | Kicker CVR12 Car Subwoofer
Power to amp
It sounds like the power supply has failed (burnt smell). Any local shop that repairs car audio should be able to repair it. If you don't know which shops repair car audio, call the local car audio dealers and ask them who they send their amps to for service.
Dec 23, 2007 | Kicker KX550.3 Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
