Question about Sony HT-CT260 - 2.1-channel sound bar system - 300 Watt Total - b
Connect HT-CT260 Connected to Samsung TV via optical. I can't get sound from TV channels.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 69 Answers
In the menu you need to set the audio sauce,, analog . digital ect
Posted on Jun 24, 2013
3 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: Hi, my tv is connected
This advice may fly in the face of the manual but it will result in the best sound and vision your gear is capable of.
You need to understand the directions audio NEEDS to go in order to manage it.
The BEST solution for watching and listening is to have the BEST electronics and the BEST devices handling the BEST sources of audio and video, respectively.
The FM & BLU-Ray are INTERNAL to the DAV so no cabling is needed for them nor will it affect them.
UNLESS your TV has superior sound to your audio equipment (unlikely), your TV is probably not going to be the absolute best AUDIO SOURCE. Many TV's (monitors) don't even have speakers so why should they be in the audio loop other than for watching news or weather?
Your Cable Box, Sat Box, any other external A/V sources will probably have facilites for presenting audio and video to separate devices. HDMI will carry digital audio and video. If THAT is the best a source has to offer, run it to the TV first as no signal ever benefits from multiple connections or 'hops'. That same high-end device probably also has a separate digital audio output. Run THAT to your best audio electronics for the same reason as above and to give it first crack at decoding the multichannel information it needs. Repeat for all other sources if you have inputs to support them everywhere. Lacking multiple digital audio outputs, opt for analog stereo to the lowliest audio device (the TV) and send the best to the Sony. That way, if you just want the TV on for company or news you can leave the Sony turned off.
Helpful hint: Coaxial digital audio cables can be joined using an RCA cable splitter so they can share a given input or distribute a given output to multiple places. You just have to remember to have only the DESIRED units turned on when sharing or there will be digital confusion on the buss and it will result in silence or horrendous noise.
Posted on Jan 14, 2011
SOURCE: I just bought a sony ht-ddwg700 home theater
Using the optical cable for the sound, first you have to configure the PS3 sound settings to output via optical. Then, the receiver must be in the "SAT" input, by pressing the according button in the remote (or the receiver itself).
Posted on Mar 07, 2010
Have Technics SA-EX500 connected to Samsung Smart TV. For tv channels the sound is perfect but when I switch to Netflix or HBOGO the sound is static/cackling.
Suggest connecting via the headphones jack or if available the RCA audio output jacks. If you connect via the headphone jack you will need to adjust the TV volume to a lower setting to avoid distortion/./ The The problem is that the optical output connection is a digital connection and depending on the digital format the Digital to Analog converter may not be a configuration that the audio stream to the stereo required for the tv/vcr in.
How does the audio sound using the Samsung Smart TV internal speakers>
Also under menus/audio/settings you may need to change the Optical output to stereo.
Netflix also has settings that will change the audio stream.
Hope This helps?
Nov 21, 2016 | Samsung Audio Players & Recorders
Have lg 55ls5700 tv trying to connect samsung hw-f450
I suspect that the TV you have does not support the ARC function that the sound bar has. What you may have to do is use the Optical In from the sound bar to the TV and you should be good to go. You may have to change the TV's settings to use the Optical In though. So you should end up with the BluRay Player connected to the TV via an HDMI cable, the sound bar connected to the TV via the Optical In using a fiber optic cable. Hope this helps.
Mar 19, 2014 | LG 55ls5700 55 Edge Led Smart Tv 120hz...
Connect with componet cables.
The only digital audio input for this TV will be via the HDMI input. Of course, even with HDMI in, you're only going to get a simple stereo output from the TV. You can use the analog L & R audio inputs for a very similar sound from the TV speakers.
The digital multi-channel audio (Dolby Digital, THX, 5.1, 7.1, etc) encoded in the program should be connected to a suitable multi-channel amplifier with either a TOSLINK (optical), RF (coaxial) or HDMI cable for theatre-like sound. This can be done by (a) cabling from the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) directly to a multi-channel amp and speakers, or (b) from the HDMI output of these devices (DVD, BluRay Disk, Set Top TV Tuner, etc.) into one or both of the TV's HDMI inputs. This will provide only stereo sound output from the TV speakers. You should connect the TV's TOSLINK optical "Digital Output" jack with an optical cable to the amplifier's TOSLINK optical input jack to obtain theatre sound.
To listen to the program shown, you would select the amplifier input assciated with the optical, RF or HDMI input that is connected to the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) if connected directly. If the TV HDMI input(s) are used, they are output to the TV optical output and should be connected to the amplifier optical input. The amp input associated with the optical input should be selected to hear the program with theatre-like sound.
Dec 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
Samsung tv to panasonic sa bt100 home theatre
it is the problem with the hdmi cable .. dont buy cheaper cables it may damage after some time
Aug 24, 2012 | Audio Players & Recorders
HI Guys. I just upgraded to DirecTV HD-DVR ( I have aHR24-200) installed which is connected via HDMI to my Samsung HD TV. I have a Samsung HT-C550 Digital Home Theater System which is now directly...
You're correct and that is exactly how I always recommend setup (contrary to what the manuals tell you). It makes no sense to me to run any signal through any electronics or interconnections that neither use it nor improve it. Hence, I have NO SOURCE VIDEO going to or through my receiver and NO high end audio going to my TV (which could just as well be a monitor with NO audio capabilities, right)?
Audio electronics should receive the BEST digital audio directly from it's root source.
The TV should receive the BEST video directly from ITS root source.
THAT is why most all high end A/V gear has separate audio and video in/outputs.
If that means you have to make some switching choices when using different sources, oh well. At least you won't have experience potential degradation from multiple hops or have to troubleshoot problems that could be anywhere in that chain.
Jul 16, 2011 | Samsung Ht-c550 5.1 Dvd Home Theater...
Try to go digital optical out to a receiver for surround sound (also Samsung) but not sound comes out. Tested it with a Samsung Blu-Ray player digital optical out, and it worked.... is this a problem with...
The digital audio outputs on televisions sometimes only work when the television is on certain inputs. It does not always work with all hdmi connected devices. I can almost guarantee you that if you connected an over the air antenna to this television and scanned for your free local television channels the digital optical out between the tv and the surround sound would work.Likewise if you have Comcast or one of the other cable carriers that has digital cable you could connect the coax cable directly between the television and the cable wall outlet without the cable box and get sound from the tv's digital audio output to the surround sound.
However there might be a digital audio output television setting you have not changed. Refer to the manual for that or call customer service if necessary.
Jun 10, 2011 | Televison & Video
I have skyhd connected to Lght-805sh via optical connection but when i turn sky over from a hd channel to normal channel there is no sound
Not sure what you mean by "optical connection" but you need to connect your SkyHD box to your TV using both HDMI and SCART cables. Your Sky HD box will then send the signal via the HDMI cable for the HD channels and the SCART cable for the SD channels.
Hope this helps
BElectric
Nov 06, 2010 | LG Televison & Video
Samsung LED UE46B7020 tv wont play sound through my HT-C5500
i know this is going to sound stupid but i couldn't get mine to work either after following every instruction to the T. I then rechecked my optical digital connections again and found that I neglected to remove one on the rubber protective endings. I took it off and plugged the end back into my TV and BINGO! THEATER SOUND from my tv!
The Ticket
May 09, 2010 | Samsung HTC550 Theater System
Cant get led tv to play sound through surround sound on blu ray
you have to have a connect going back into the player, the hdmi is only one way there should be and analog the red and white
or
an digital optical out from the tv
May 08, 2010 | Samsung HTC550 Theater System
Sony HT-CT260 - 2.1-channel sound bar system - 300 Watt Total - b Logo
293 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
