Question about Honeywell TB8220U1003 Commercial Vision PRO 8000 Thermostat, 7-day
How to unlock screen - Honeywell TB8220U1003 Commercial Vision PRO 8000 Thermostat, 7-day
  • Honeywell Master
  • 5,245 Answers
Change battery located on back of thermostat??
Go to google
Search for your model number 1234XX .pdf
Add .pdf in search parameter.
Honeywell posts most their thermostat manuals.
Open pdf file, and then Use Ctrl+F for search feature
Word-Search manual
To find model number on thermostat, remove from wall.
Model number appears on back.
Don't forget to replace battery while you have back exposed.
Dead battery can also cause lockout and malfunction
Posted on Apr 19, 2013
Off button stuck on cannot unlock it need help
There is a Allen wrench head hole on the bottom of the garbage disposal. with the right size Allen wrench turn the motor to free it up. unplug the disposal clear out any glass plug it back in then try and turn it on
Jun 21, 2015 | Water Heaters
Locked out of thermostate
From the manual:
PROGRAMMABLE KEYPAD LOCK
To prevent tampering with any of your settings or
temperatures, the front panel buttons and the rotary dial can
be locked out, requiring a four digit code to unlock them.
You may use either the default lock code of "0000", or your
own personal number combination (see "Changing The Lock
Code")
LOCKING THE THERMOSTAT: Ensure the rotary dial is in the
RUN position. Press the NEXT button for at least 2 seconds.
The words "ENTER CODE" will appear on the screen, along
with "0000". Press the NEXT button again for at least 2
seconds. A padlock should appear on the screen to confirm
that the thermostat is now locked.
UNLOCKING THE THERMOSTAT: Ensure the rotary dial is in
the RUN position. A single press of any button should cause
the words "ENTER CODE" to appear on the screen, along
with "0000". If the default code was used to lock the
thermostat, press the NEXT button for at least 2 seconds.
The padlock should disappear from the screen, and the
thermostat should now be unlocked.
If you try to unlock the thermostat by entering a code that is
not correct, a padlock and the digits "88:88" will flash on the
screen and you will have to try again. If a lock code
different from the default was used, this will need to be
entered by using the UP/DOWN buttons, and the NEXT
button to advance to the next digit. Once the correct code is
entered, press the NEXT button for at least 2 seconds and
the thermostat should now be unlocked.
CHANGING THE LOCK CODE: To create your own specific
lock code, first ensure that the rotary dial is in the RUN
position. Press the NEXT button for at least 2 seconds. The
words "ENTER CODE" will appear on the screen, along with
"0000". Now press the HOLD button again for at least 2
seconds. The words "SET CODE" will appear on the screen,
along with "0000".
IF YOU FORGOT YOUR LOCK CODE: You can still unlock the
thermostat by performing the following steps: On the back
of thermostat locate JP1, which is a row of 3 metal pins at
the right edge of the circuit board above the battery tray.
There should be a plastic jumper cap on 2 of the 3 pins
(right or left).
Move the jumper cap so that it is on the opposite 2 pins.
For this change to be recognized, move the Temperature
Mode switch to any other position than its current one.
These steps listed should have changed the lock code back
to the default of "0000". Follow the instructions already
listed in "UNLOCKING THE THERMOSTAT".
Sep 02, 2012 | Lux Tx9100e 7 Day Universal Programmable...
Gvr 40 100 will not stay lite
The Cold air screen on the bottom of the water heater is partially plugged. That is if the pilot light can be lit and stay on, but goes out when the heater should be functioning normally. This is not the removable plastic screen but a round white-yellow grid with 1/32" holes. You can try to clean it through the bottom but you may have to remove the gas line from the controller to the burner, pilot gas line, and thermocouple connection to remove that complete assembly to get access to the screen. The AO Smith booklet warns of this but they pretend the plastic screen will keep this second screen clean but it won't. After three years it was two thirds plugged.
Dec 12, 2009 | RTO W4 A.O Smith Gas Hot Water Heater...
40 gal lp locked out at gas control valve. what are steps to unlocking valve?
Try turning the off pilot on knob to off and then turnign the temperature dial to the coldest position. then turn to pilot, relight and see if that works.
Jul 12, 2009 | Rheem Water Heaters
Honeywell TB8220U1003 Commercial Vision PRO 8000 Thermostat, 7-day Logo
113 people viewed this question
Top Honeywell Water Heaters Experts
Lickzee
gbob59
Are you a Honeywell Water Heater Expert? Answer questions, earn points and help others
