When i click the overprint preview it says the following: Cannot display Overprint Preview because the document contains more than 10 spot colors. Delete some spot colors or convert them to process co
I need to click overprint preview before converting the file into a pdf, but i am having trouble following the directions it says...the only other color in the 12-page newsletter is a process color, not a spot color...and a friend said the directions i receive have nothing to do with photos...so, how do i get the overprint preview button to do what i want?
    New Friend:
    Problem Solver:
  • 5 Answers
Trruyncyhbhb
Posted on Apr 19, 2013
Mix-it-up
  • 832 Answers
SOURCE: all scanned documents have blue background.
You have to take the machine to service partner who can be found on the brother homepage of your country.(www.brother.com)
The scanner needs calibration which can only be done by service personel.
Posted on Dec 25, 2007
flopez
  • 161 Answers
SOURCE: Samsumg SCX 4521F does it pdf?
If you are using the SmartThru software, the otpion to change the scanned format is in the same screen where you state the name of the document and settings for color, resolution, and others.
Be blessed.
Posted on Sep 29, 2008
Justin9992
  • 36 Answers
SOURCE: My printer worked fine when I used it a month or
When you are on the print window at the end of the process, look for a "Preferences" or "Options", then look for tabs or other menus that say "Color" or some sort of "output" mode and see if there is a negative option you can disable.
Posted on Apr 16, 2009
  • 164 Answers
SOURCE: scan document as pdf on a Photo 926
open adobe acrobat..not reader, has no ability to create pdf's, and go to file, create pdf, from scanner
Don't forget to rank the advice!
http://www.aa1consulting.com
Posted on Jul 27, 2009
SOURCE: Okidata DP-5000 I need help narrowing
The ALPS MD5500 is capable of both making white undercoat for CMYK colors and white overcoat (more opaque than white undercoat).
MD5500 is produced mainly for the Japanese market only with a Japanese driver.
But you can get the printer here- with english driver :-)): http://www.alps-supplies.com/alps-md5500-microdry-printer-with-english-drivers-p-28.html
Posted on Oct 01, 2009
Image prints at the edge of the canvas
you should check the paper size loaded at the driver open devices and printers- choose HP DJ5500 driver - right click and open Printer properties-click the paper/sizes tab at the top-check that the paper size is set to ROLL- then set roll size ( 24"=A1--36"=A0---42"=A0/2A0)
now when you try to print make sure that the printing application ( EG paintshopPro) has the correct Page size (under document Properties)
and that your not strectching to fit or using the overprint commands within your printing application. the plotter should never be allowed to overprint as this model has no ay of clearing the excess ink that would be left on the platten
Dec 24, 2013 | HP Designjet 5500 (42 in.) InkJet Printer
Tip
Epson Printer " Unable to Print Preview"
<p>When you attempt to print to an Epson printer, the print document displays "Printing" in the Print Management window, and continues to display this until you cancel the print job; however, nothing prints. <br /> <p> <br /> <p><b>Resolution:</b><br /> loadTOCNode(1, 'resolution'); <p>To resolve this problem, you can disable the Printer Preview option: <br /> 1.<br /> In Control Panel, double-click Printers and Faxes.<br /> 2.<br /> Right-click the Epson printer, and then click Properties.<br /> 3.<br /> On the General tab, click Printing Preferences.<br /> 4.<br /> On the Main tab, click to clear Print Preview.<br /> <p>-OR- <br /> <p>If one is available, download an updated print driver for Windows XP from either of the following two Epson Web sites: <br /> <p>http://support.Epson.com/filelibrary.html<span> </span><br /> <p><a href="http://www.Epson.com">http://www.Epson.com</a><span> </span><br /> <p><span></span> <br /> <p><b>More Information:</b><br /> loadTOCNode(1, 'moreinformation'); <p>The Print Preview option is a third-party feature that is available in some Epson print drivers. This option is not related to the print preview options that are included in many programs. The third-party products that are discussed in this article are manufactured by companies that are independent of Microsoft. Microsoft makes no warranty, implied or otherwise, regarding the performance or reliability of these products.<br /><br /> <p> <br />
on Mar 10, 2011 | Office Equipment & Supplies
How to scan using hp j4580. Booklet only tells how to fax!!!!
  1. Open HP Solution Center with one of the following methods:
    • Click the Windows icon c01319360.gif , click All Programs , click the HP folder, and then click HP Solution Center.
    • Double-click the HP Solution Center icon on your desktop.
  2. If you have more than one HP device installed, click the tab or icon for the product that you are using to scan.
  3. Use one of the following methods to start the scan:
    • For photos or artwork : Click the on-screen Scan Picture "button" in HP Solution Center.
    • For a text document with or without graphics : Click the on-screen Scan Document "button" in HP Solution Center.
    A screen displays to prompt for scan settings. If a settings screen does not display before the scan starts, a preference was set to bypass the prompt. To adjust settings, follow these steps to turn the prompt back on:
    1. Cancel the scan, return to the home screen of HP Solution Center, and then click the Settings option.
    2. For the HP Solution Center "button" that you are using ("Scan Picture" or "Scan Document"), set the option to prompt for settings each time you scan, and then click OK .
    3. Start the scan again.
  4. Read through the various options for the scan settings. Make selections for at least the following items:
    • Scan to: Select your scan destination from the drop-down list.
    • File Type: Select the file type from the drop-down list.
    • ...Save Options...: (available only for certain "Scan to" destinations): For example, if you are saving to a file, click this option to select your Save Location .
    • Show preview...: Select this check box if you want to see a preview before the actual scan.
    Important : HP Solution Center software versions vary, depending on the age of your product, and whether you installed updated software after the initial setup. For specific instructions on all the settings the software offers, click the Help button on the home screen or settings screens in HP Solution Center.
  5. Click Scan . The preview screen might display, if you selected an option to show a preview. Use the options on the preview screen to make any desired adjustments before you complete the scan.
After the scan completes, it goes to the destination that you specified in the settings.
Jul 18, 2010 | HP OfficeJet J4580 All-In-One Laser...
Certain color parts previewed on computer don't print out
Depending on the software you are using to do the preview...( a word processor, photo software ..etc) the preview is just that...it simply lets you look at the document or picture to see that you have formated it correctly in the main program. You should not try to print from the preview...what you can do is exit the preview function and return to the main software. the go to the file menu and exicute the print command and or do the page setup for the picture or document.
May 31, 2009 | Office Equipment & Supplies
Cannot overprint color areas; only get knockout
Which version of QuarkXPress are you using and on which platform??
Mar 11, 2009 | QuarkXPress 6.0 for Mac
The pages in my booklet don't line up correctly---ahh help!!
Check the X coodinates in the upper left corner and make sure the art is placed or drawn to the guides or edges. A little more infomation would be extremely helpful.
Another thing to do is turn on the Overprint Preview. This is in the View menu. When you turn this on, you see how exactly things are placed/lining up instead of a low rez screen preview.
Are you converting a Publisher file to InDesign? If so, you will HAVE to fix this. Not an exact science. Even with the Utility, they are 2 totally different apps. InDesign will do it's best to maintain the look of the Publisher file, but Publisher was not created for high-end output, it has gotten better over the years... but it is still THE most problematic software for Printing.
Jul 04, 2008 | Adobe InDesign CS2
No output separation view option
Make sure "Overprint Preview" is OFF.
Mar 05, 2008 | Adobe InDesign CS2 for Mac
Scanning neg
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Jan 22, 2008 | Epson Perfection 3200 Photo Flatbed...
Epson 3490 does not find the slide I put in the correctly positioned provided frame
Dec 28, 2007 | Epson Perfection 3490 PHOTO Flatbed...
Scanner incorrectly reads frame position on film
Yes there is
Dec 10, 2007 | Epson Perfection V350 Flatbed Scanner
88 people viewed this question
jasbo
jasbo
