Question about Uniden BC796D Base Scanner
My computer does not have serial port, so I purchased a Belkin Serial to USB Adapter. I have tried setting all different speeds and I still get a communications error when trying to connect. I am using the BC796D software that Uniden provides.
2 Suggested Answers
Ironfist109
  • 3018 Answers
SOURCE: comunication error with 796d and
  • Hi, I can help.
  • This happens a lot to people just setting up a scanner like this. Try these suggestions, I think you'll be up and running in no time.
  • You have to make sure the BAUD rate is set and make sure your PC control is turned on in your scanner. A BAUD is the rate per second data is sent.. A BAUD rate of 38400 (or what ever BAUD the software is at). I think parts 3,4 and 5 in the your scanner menu cover this. If you have the FIFO buffer set then remove it from your settings > control panel > comm ports. You will get the best results if you have that software read the bank before writing to it. Relabel your comm port settings if you need to as well ie. port 1, port 2 etc.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa,
Regards, Tony
Posted on Sep 21, 2011
Need to change port number for the usb beljin adapter F5U109. Need to download driver software.
in the device manager click on (ports lpt com) double click on belkin usb adapter the properties will open then click advanced ant set the com port. you will find the driver here https://www2.belkin.com/support/product/?lid=en&pid=F5U109&scid=1
Jul 08, 2010 | Belkin USB/Serial Portable Adapter...
Lost install instructions for Hi-speed usb 2.0 5-port PCI card.
The drivers are here. You shouldn't need to do anything to install the card other than plug it into a PCI slot in your computer and install the drivers.
Hope this helps. Thanks for using Fixya!
Feb 19, 2010 | Belkin Hi-speed USB 2.0 5-Port PCI Card [...
My Belkin USB PDA Adapter Serial adapter when
In my effort to find answer I created a bigger issue. Answer to my Belkin issue was found at the Belkin website. But now due to my own failure to read all the details of acceptance of what I thought was what was necessary to get help; I am into another software 'pay-me' software program costing $10/month or $12+ for one time help of something which is simple to fix (Fix-ya). I got tired of paying Microsoft $25 each time to answer a simple question and often told to re-booth my entire system at 'possibe loss of my info'. When I found the answer and told them what I did to fix my pervious problem they did not credit me or pay me $25. And now there is Fix-ya; NO THANKS. Please remove me from your support group list. Not interested. JB
Feb 16, 2010 | Belkin USB PDA Adapter (F5U109EA) Serial...
My older hi-pro box will not work with my serial to USB adapter. It keeps saying it cannot find it on com 1,2,3,4. In the device settings it says the hipro is on port 2 and the serial/USB bridge is on port...
I just set up a serial Hi-Pro box for one of my customers on their new laptop. According to Beltone, the only usb adapter that will work with the Hi-Pro (or at least the only one they have gotten to work) is a Belkin F5U409. I know some usb serial adapters don't use true serial communications if that makes any sense, so there isn't really a baud rate. They kind of just send out the communication in bursts...
In any case, ive only tried with the belkin adapter and that worked fine with no problems. The other point here is that your Hi-Pro and Adapter are on different com ports... This is odd, the hi-pro should be on the serial adpater's com port. Also the software i was using - Noah, with a beltone module for programming hearing aids.. only looked on com ports 1-3. The computer put the serial adapter on com 8 - which would not do. I checked for available com ports and saw that 2 was unused. I set the adapter to 2 and was able to set up the program normally.
I did this on Windows 7 Professional 32 Bit. The procedure for selecting the com port is the same on earlier versions of windows.
First, open device manager, open the list titled "Ports (COM and LPT)". You should see your serial adapter in there. Double click it. In the window that opens click the "ports" tab, and hit the button labeled "Advanced" In the window that opens there will be a drop down list to select a com port. Select the desired com port and hit ok. That should fix it.
Jul 12, 2009 | Uniden Unipro PC100
The computer does not recognise the adapter
You need to isolate the problem. You may need to connect the USB-Serial adapter into different USB port of your computer or you may want to try connecting it into different computer. If you get the same problem after using different computer, you may need a driver for it. Or it could be defective.
Have a great day!
Jul 09, 2009 | Belkin USB/Serial Portable Adapter...
Tried using usb to seriel adaptor but unable to read while reading 2way radio software. pretty sure its between the usb/adaptor
make sure that both the cable and the software that you are using are set to same Com ports.
Ex. the cable set to Com4, the software must be set to Com 4
To change the Com ports of the cable you just got to Device Manager under System Properties then on the properties of the serial cable there is an option to change the Com port settings.
To change the Com port setting of the software just simply go to its settings or preferences.
Jun 16, 2009 | Belkin USB/Serial Portable Adapter...
Pfaff 7570 connection to new XP laptop
In this FAQ list (from PFAFF web) you find 100 times the same question and answer:
H402 My new computer does not have any serial COM ports, so how does it communicate with my Pfaff creative 7570?
You will need to obtain a USB Serial Adapter, which adds a serial port to your computer by plugging it into a USB port. Suitable adapters can be obtained from Belkin [http://www.belkin.com] and Keyspan [http://www.keyspan.com].
The following USB Serial Adapters are known to work with the Pfaff creative 7570:
• Belkin F5U103
• Keyspan USA-19QW
Please note that the Belkin F5U109 is listed as working with the Pfaff creative 2140/2144 (FAQ #H405), but it does not work the Pfaff creative 7570.
Jan 06, 2009 | PfaFF Creative 7570
Belkin USB/adaptor
Google Franson GPS GATE this little software utility is what you need
Mar 31, 2007 | Belkin USB/Serial Portable Adapter...
Uniden BC796D Base Scanner Logo
520 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
