Question about JVC HD-52FA97 HDTV
Where do the bulb go in the tv
Trying to replace the bulb and I am trying to figuring out where it goes
  • JVC Master
  • 3,459 Answers
If its a DLP TV on the rear of the is usually where they go..there is a small access door that you remove and behind that door is the bulb cage
Posted on Apr 19, 2013
TV turns on, hear sound but no picture. Bulb isn't coming on. TV goes off after about 2-3 minutes. Bulb was just replaced 5 months ago.
Need the model number of the set and also if any lights on the TV come on or blink when the picture goes out or not.
Feb 09, 2013 | Televison & Video
OmIm trying to figure out why my tv will not come on. I was watching it one night and it just went out . I did not think nothing else of it so . I left out the room about 30min later I started to smell...
First replace bulb to make sure it's not the bulb. If it's not the bulb it is most likely the light engine. My suggestion would be don't invest in the light engine. Goes for about $500 plus for a re-built one and warranty is only 3-6 months on it. I purchased one and it went again in 4 months.
Please don't invest in any more dlp tv's. I learned the hard way.
Jul 19, 2011 | RCA HDLP50W151 50" Rear Projection HDTV
Recently we replaced the bulb in our LG 52SX4D-UB. Once the bulb was installed we reset the hours for bulb according to the instructions that we reviewed on-line. Once the power button is pushed on the...
Tv goes off and on.It have alots of clicking noise sounds too?Yes.The board that call the Ballast board it is also dead too.The Ballast board only job it is to help to ignite the tv projection lamp.Tries websites like Partstore.com,Ebay.com to buy the Ballast board for the replacement.
Apr 03, 2011 | LG 52SX4D 52" HDTV
Changed lamp green light comes tv plays for about 1 or 2 minutes tv goes blank red flashes 3 times.
Not 100% sure but I am currently looking into this. 2 things it might be which are most probable. I replaced my lamp a few years back with no issues. This time around I figured I'd be proactive and bought a new lamp as my current one was going dim. Not unusable but I could tell. Lamp arrived and I put it in. Started up, great! Then after a few minutes it shut down and the red LED would blink 3 times. I removed the lamp and replaced it after unplugging the tv and turned it on. This time it ran about 20 minutes and same thing! Tried a third time and had the same thing. So I put the old bulb back in, and this time it didn't even turn on! I removed it and with a flashlight looked in there. There are two safety switches. The first is a very small pressure switch at the base of where the bulb interfaces to the TV. That switch ensures the bulb housing is seated. Secondly there is a switch in the rear side where the second door with the lever lock is. When you rotate it the switch is engaged. I replaced the housing carefully and made sure everything was tightly seated. The tv has been on for about an hour now no issues with the old bulb.
I have two theories and am leaning toward the second one I will suggest. One is that the bulb is somehow overheating as it is newer and brighter, or is somehow defective. The other theory is that as the bulb heats up the switch might be getting dislodged. I am leaning towards this given that it is working with the old bulb. But I am not certain. Soon I will try the new bulb again and may even attempt to slightly bend the switch out a little so that it is easier to engage.
Jan 05, 2011 | Sony KDF46E2000 46" Projection HDTV
My Toshiba 52" goes dark. what can I do to fix it.Tried to ajust the brightness but still stays dark.
U replaced the bulb yet on this tv?U used this tv alot at lest two years or more?The bulb life span it over,bulb have limitted life span.
Apr 20, 2010 | Toshiba 56HMX195 52" HDTV DLP Projection...
I had to replace the primer bulb and fuel tubing. The primer bulb just disappeared, presumably blew off. I have installed the new bulb and replaced the fuel tubing, but I need to know where the tubes...
The line with the fuel filter in the end comes out of the tank and it goes to the bottom fitting on the carburator. The other line comes out of the tank and goes to the bottom fitting on the primer bulb, and the third section goes from the top fitting on primer bulb to top fitting on carburator. Got it? lol Hope this helped and best wishes.
Aug 25, 2009 | Garden
LG DLP not turning on
well i know what the problem is... if your getting the white scroll and then the red light flashes but the fans are comming on and you got a new bulb the broblem is the ballast. i know cuz i had the same problem and a good friend of mine has a tv shop and i had him look at it but the good news is that its not that hard to change. if you try to go through LG thay wont be able to sell you the ballast if your just a coust. good news is that you can fined the ballast on ebay from s.gifeasywaylamps its about $130.00 bucks shiped. bad news about is that thay are from china(it is where i got mine) but it works great and hasent gave me a broblem yet. if any one eles has the same problem and it was something eles.... PLEASE POST IT. i hope my info has been helpful to someone.... thanks Brad Ross of East Moline Illinois... you can email me at plopit40@yahoo.com
Nov 11, 2008 | LG 52SX4D 52" HDTV
Hitachi
TV's have a circuit that monitors the high voltage and shuts down the power if it senses something amiss.
On projection types, figure on just replacing the entire board that has the flyback transformer on it.
Hope ya fix it!
Feb 04, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Bad Blub?
probably a capacitor in the tv is going bad. contact your sony repairman
Jun 05, 2006 | Sony XL-2100U Projector Lamp for...
JVC HD-52FA97 HDTV Logo
49 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
