Question about Kobalt 18-Volt 1/2" Cordless Impact Wrench K18LW-16A
I have a kobalt impact driver and the bit holder i put in will not come out. The chuck moves but the holder won't slide out. Any suggestions?
I put in a bit holder, and i want to change it out, the chuck pops up but the holder will not slide out. Any suggestions on what to do?
Screw driver bit stuck in chuck of impact driver.
a tough one If can't get hold of it you may be screwed LOL
getting that rammed in the chuck is very hard to get out even if can get a grip unfortunately you can't beat it out you would do more damage And no lubricate is going to help because it was tightened down. Hope someone can help you in this otherwise may have to replace the drill
Nov 06, 2014 | Makita TD090DW 10.8V Compact Li-Ion...
I'm looking for keyless chuck to makita btd 140
The Makita BTD140 is an impact driver that has a hex-drive anvil and bit holder assembly, it does not have a keyless chuck accessory. There are some aftermarket chucks with hex shanks on them to put into impact drivers but I've seen very few that hold up.
May 29, 2014 | Makita Drills
The chuck on the dewalt impact driver does not hold the bit holder in
If you go to dewaltservicenet.com you can enter your model number to see the parts breakdown. It can be tricky to get the retainer clip off and on but the rebuild of the bit holder is easy other than that. The spring and the steel ball are all that usually need to be repalced. Hope that helps.
Apr 20, 2014 | Dewalt DW056 18 Volt Cordless Impact...
Top chuck just clicks but won't change bit size?
It sounds as though you will have to replace the chuck. Remove the screw (l/h tread) from inside the chuck first before removing it.
Feb 02, 2013 | Drills
I,m having trouble getting the chuck off my 13618 bosch 18v hammerdrill. I have removed the screw then chucked a piece of hexed stock into it and reversed a half inch impact to it and it won't bre
Make sure it is in low gear on drill mode. try with just a bar in the socket and hit the end to shock it. This is sometimes better than a constant force.
Nov 21, 2012 | Bosch 13618 - 2G 18V Brute Tough Cordless...
I have a Hitachi 12V Cordless Impact Driver that won't spin at the chuck housing. Not sure what the problem is?
Make sure it's all the way in gear. It sounds like it's not all the way in first or second gear. Yes it sounds dumb, but it's one of the most common problems we see in our shop.
Apr 26, 2012 | Hitachi 12V Cordless Impact Driver
Remove the chuck dc970
I'm assuming you have a DCD970 as DeWalt doesn't have a DC970 and the DW970 is an impact driver. The chuck on your drill is a new design that doesn't have a lock screw inside the chuck, they are put on very tight with lock-tite to hold them on. They are made to be taken off with a special chuck holder and vice jig that only service centers have. The allen wrench method used on older chucks won't work as the chuck will just loosen when you hit the allen wrench. I have on occasion removed one by doing the following: Turn the chuck fully open then secure it in a vice with the drill straight up. Holding the drill body and using the handle for leverage, turn the drill counterclockwise, as you are looking down on it, with steady, strong pressure. If the chuck breaks free it will spin off easily. If you are at all afraid you may break the handle you may have to take or send it to a service center to have it removed.
Mar 07, 2012 | Dewalt Drills
New Black and Decker, 18 volt, cordless drill. I can't tighen the bit
I oil mine up to help the jaws move . also check the screw at the base of the chuck inside its a standard head. shine flash lite where you put the bit it holders the Jacobs chuck to the shaft.
Jul 07, 2011 | Black & Decker & Cordless Drill
Kobalt 18-Volt 1/2" Cordless Impact Wrench K18LW-16A Logo
44 people viewed this question
Top Kobalt Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Kobalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
