Question about IBM ThinkPad T43 Notebook
My IBM ThinkPad t43 does not boot regularly. According to the technician, there's something wrong with the SATA controller and I need to buy a new motherboard. Where can I buy a new motherboard fo
myob247
  • 1342 Answers
SOURCE: IBM ThinkPad T20 - Won't boot windows
Click HERE for info on IBM passwords
Posted on May 24, 2008
SOURCE: wireless radio control problem
Try going into the Device Manager and making sure the Wireless Adapter is enabled. Click Start > Control Panel > System. Click the Hardware tab then click the Device Manager button. Now click the Plus [+] next to Network adapters then double-click the wireless adapter which is probably the Intel(R) PRO/Wireless 2915ABG Network Connection which will open the Properties dialog. Ensure the Device status reads, "This device is working properly" and Device usage shows "Use this device (enable)." If either the Device status or Device usage shows anything other than what is shown above, first try to change the Device usage, which should change the Device status. Now try again to use your wireless adapter. You might need to press Fn + F5 to turn the device on.
Posted on Nov 29, 2008
ItWillBoK
  • 108 Answers
SOURCE: Is there a way to master reset the IBM T43 Thinkpad
No it's not possible to do it with just a button or replace it to factory settings.
The T43 Comes with WinXP or OS/2 Warp or Windows 2000 Pro.
If you wanted to reset it you basically would have to format the harddrive.
You can get a older version of WinXP which is still supported by microsoft or either that you can format it and sell it without a operating system.
Or you can add/remove items you installed and remove personal info delete pretty items much within windows itself.
Happy Holidays
Posted on Dec 25, 2008
  • 68 Answers
SOURCE: No Sound on my IBM t43 Thinkpad
all hardware requires a driver
driver is an information file that tells the operating system how device works
without the driver the device cant work
when you reformatted you must not have installed sound drivers
here is a link to Windows XP version of the sound drivers of your laptop
http://www-307.ibm.com/pc/support/site.wss/license.do?filename=mobiles/1ya210ww.exe
download it
install it
reboot
and you will have sound
if you have a different operating system than windows XP, tell me and i will give you link for that
Posted on Sep 30, 2009
bobfreengel
  • 37 Answers
SOURCE: IBM THINKPAD T43. I can find the switch for my ibm thinkpad T43
Are you sure you have a wire card installed? If so, then try this:
  1. Right-click the My Computer icon and select Properties.
  2. Click the Hardware tab and press the Device Manager button. The network card should appear under Network Adapters.
    Note: If the card has a exclamation mark over a yellow background, then this is an indication that the card is experiencing a problem. Go to Driver download step 5.
  1. Verify that the radio is enabled.
    It is possible to disable the transmitter of the wireless card without Device Manager showing any problems.
    Note: Follow the instructions provided to enable wireless card.
    • Most wireless cards will put an icon in the system tray (the line of icons in the lower right corner of your screen). Right click this icon and it may have a menu option to enable/turn on the wireless radio.
    • Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.
  2. Check for association to an Access Point.
    If you double-click the previously mentioned system tray icon, the configuration utility of the wireless card will appear. This utility will be able to show the status of the wireless card, showing what channel the card is using and what signal strength is being received. It may be difficult to maintain a connection if signal strength is low due to either interference or distance. For example, interference can be caused by 2.4GHz cordless phones, other Access Points in the area, and physical structures such as load bearing walls or metal partitions.
    Note:
    The utility can be used to configure the wireless card settings, but if using Windows XP Zero Configuration or Access Connections, you will need to use those programs to actually configure the wireless card as they will overwrite the setting of the utility.
Posted on Oct 12, 2009
Ibm t43 thinkpad cant change bios setup up utility to modify in user consult system supervisor
Boot the computer, when the first sign of life appears, tap f12. Go to boot order, then select cd drive as primary boot device.
Apr 10, 2014 | IBM ThinkPad T43 Notebook
How the change ethernet port on my t43 thinkpad
To change the Ethernet port you need you open up everything and tell some technician who can repair mother board.
But still i'll not suggest you to do that because after repairing mother board you never know when you might get some other problem too.
So i'll suggest you to buy and use USB to Ethernet converter which is Cheap and easy to use also.
Aug 02, 2012 | IBM ThinkPad T43p Notebook
How to boot ibm thinkpad t43
Press the power button and it will start booting.
Mar 28, 2012 | IBM ThinkPad T43 Notebook
Won't boot in safe mode
Starting an IBM Thinkpad T43 in safe mode allows you to troubleshoot technical issues that you otherwise couldn't. Often when a system has a virus or other type of malicious program, safe mode is the only way to locate and delete the problem. In safe mode, only the computer's essential programs are enabled, and only the files necessary to running the system are in use. Learn how to start an IBM Thinkpad T43 in safe mode using a few fairly easy steps.
1.Close all programs and restart the IBM Thinkpad T43.
2.Press "F8" repeatedly after the IBM logo appears, but before the operating system logo appears. If the "F8" key doesn't work, restart the computer and try pressing the "F11" key repeatedly.
3.Press the "down arrow" key to select "Safe Mode."
4.Press the "Enter" key. The computer will boot up in safe mode.
Sep 16, 2011 | IBM ThinkPad T43 Notebook
My IBM thinkpad t43 freezes even before POST and stays that way without continuing boot process. we confirmed the screens are working normal. please help
The RAM module/s may be faulty or just need reseating.
Reseat the RAM module/s and see if the laptop boots normally, if not remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Jul 16, 2011 | IBM ThinkPad T43 Notebook
I have an IBM Thinkpad T43. A good piece of hardware, very dependable and durable. Until now. I cannot boot the t43. when i press the power on switch, the num lock and key lock lights up together with the...
something is definitely faulty.. could be damage on the motherboard.. may be water.. first have it opened and checked then try to power it in adapter minus battery.
Regards
Jan 31, 2011 | IBM ThinkPad T43 Notebook
Ask for Ibm Thinkpad T43 battery Price?
go to : Canada battery on-line shop,sell Laptop battery, Digital Camera Battery (DC ...... Welcome to buy ThinkPad T42, replacement laptop battery for IBM ThinkPad ...
https://www.linkme.com.au/groups/public
Jul 20, 2010 | IBM ThinkPad T42 Notebook
Ibm thinkpad t43 windows xp it has ad-block from
Hi, During the boot at the THINKPAD SCREEN press the Thinkvantage key ( Blue button ) it will launch rescue and recovery and allow you to reboot factory. This only works if you did not corrupted/deleted the rescue and recovery hidden partition on the HDD. Otherwise you will need the rescue and recovery CD to proceed. IBM/Lenovo support should be able to provide you the CD. Might be a defective hdd aswell, in this case to make sure you can run a DFT test, www.google.com -> Look up for " Test DFT " ( Drive fitness tool from hitachi, will make an hardware diag if hdd failure - error code 0x00 = everything fine, other code = Issue - You can look up for accurate code explanation on hitachi website ) thanks and have a nice day J-
Jan 21, 2010 | IBM ThinkPad T43 Notebook
IBM ThinkPad T43 Notebook Logo
61 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
