Question about Kodak EasyShare M550 Digital Camera
When I turn the camera on the lens sticks. How do I fix it. WD40?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
Posted on Apr 19, 2013
No image through view finder
Take the lens off, is the mirror stuck up? If it is then thats why you cant see through the view finder. It should come down after you take a photo.You can try to gently push the mirror down. This is caused by the mirror box warping due to heat or being dropped. Try it a few times and if it still sticks, more expensive to get fixed than the camera is worth so look for a 'new' camera on ebay. do not spray anything like CRC or WD40 into it, makes things worse.
Feb 03, 2014 | Pentax ME Super 35mm SLR Camera
The lens cover does not open all the way. I have to use my fingernail to do it.
It is either bent or has grit and dirt in between the slides. Try using canned compressed air, such as you use to clean a computer keyboard with, to blow air between the slides. If that does not work, even though you will have to be very careful, while the lens cover is closed put a single drop of WD40 on the cover and spread it with a Qtip over the entire cover surface. Holding the camera, front facing down, try turning it on and off several times. If that frees the lens cover, turn the camera off and wipe the surface of the closed lens cover with a soft tissue to clean the WD40 from the surface. Make sure then that your lens is clean before using the camera. If the lens cover is bent, then none of this will work.
Mar 24, 2010 | Nikon Coolpix 775 Digital Camera
When i turn my camera on i get a lens error 113,0,0,0 what is that and how do i fix it?
The lens/zoom has tendency to stick. Try newest batteries and try several times to turn on and off. If all else fails, Kodak will fix it for $50
Jul 02, 2009 | Kodak Easyshare M753 Digital Camera
In the screen says lens error
Hi I had the same problem with a codak C743. I cleaned the lens casing from out outside as much as I could and sprayed a tiny bit of WD40 making sure not to get it on the lens itself.
Then I kept turning it on, and zooming in and out until I got the lens error message, switched it off, the on again, wipe, new WD40, zoom etc. repeated this s number of times until the lens was freed.
I think I had some sand/ dirt around the casing.
Worth a try I guess.
Dec 20, 2008 | Casio Exilim EXS10BK Digital Camera
Lens stuck
Knocking the camera sounds like it works but may create another problem. I have had this problem with p-100 , p-200 and now the w50, I have found a small drop, of wd40 placed on both sides ,two opposing sides,of the lens ring where it extends from the body will work also. Don't spray, its a bit too hard to control amount deposited. Use a toothpick or a stick to dip and then drop the oil.
Mar 16, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Lens is sticking, error122,1,0,0
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 18, 2008 | Kodak Easyshare M753 Digital Camera
Samsung digimax D73 not turning on
i had the same problem, but it appeared, when my rechargeable batteries died.. it just friezed  while the lens was coming out. it came out abaout a half of it's length.. tried connecting to pc, different batteries, until pressed the lens a bit towards camera and then tried to pull it out a bit - and it came back again. It started to work. So I gues all of your problems has something to do with the lens.
Sep 11, 2007 | Samsung Digimax S600 Digital Camera
Lens cover stuck
If you're careful this problem is a relatively easy fix for many digital cameras. The design of the lens cover mechanism is usually simple and very similar throughout camera brands. Here's an example fix for a Canon A400 with similar problems:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Apr 05, 2006 | Pentax Optio S Digital Camera
Kodak EasyShare M550 Digital Camera Logo
35 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
