Question about Garden
Homelite 33CC 2 Stroke 40cm Bar Petrol Chainsaw slipping clutch
SOURCE: Homelite CSP 3314 Chainsaw
starts no prob will not rev , just stalls when you try
Posted on Feb 14, 2010
SOURCE: my homelite ranger 33cc chainsaw won't start,one
Well depending on how long he ran it for, i suspect, it has seized, in the Bore, this is what happens if there is no oil in the mix, it scours out the cylinder and eventually, gets too hot, and quite quickly, will melt and jam up inside the bore of the engine, you must hone the bore and replace with an over size piston, to repair. If it wasn't used for long, and it has just stopped going, then that's a little strange, as apart from the oil, the gas would still make it go fine....it's just missing a tiny, amount of oil, and as such burn leaner too, but should still run. You will have to troubleshoot, the gas, the spark, as usual in that case to see why. It maybe mixture, or spark plush maybe burnt out from the heat too, or instead of?.
Posted on May 12, 2010
duane_wong
  • 6826 Answers
SOURCE: Can i get instructions to download on how to
Got to homelite.com and input your model number.
WARNING:
When servicing, use only identical Homelite
replacement parts. Use of any other parts may
create a hazard or cause product damage.
WARNING:
Always wear safety goggles or safety glasses
with side shields during power tool operation or
when blowing dust. If operation is dusty, also
wear a dust mask.
GENERAL MAINTENANCE
Avoid using solvents when cleaning plastic parts.
Most plastics are susceptible to damage from
various types of commercial solvents and may be
damaged by their use. Use clean cloths to remove
dirt, dust, lubricant, grease, etc.
WARNING:
Do not at any time let brake fluids, gasoline,
petroleum-based products, penetrating
oils, etc., come in contact with
plastic parts. Chemicals can damage, weaken or
destroy plastic which may result in serious
personal injury.
LUBRICATION
All of the bearings in this product are lubricated with
a sufficient amount of high grade lubricant for the
life of the unit under normal operating conditions.
Therefore, no further lubrication is required.
REPLACING THE guide BAR AND
CHAIN
See Figures 34 - 43.
DANGER:
Never start the engine before installing the
guide bar, chain, clutch cover, and clutch drum.
Without all these parts in place, the clutch can
fly off or explode, exposing the user to possible
serious injury.
maintenance
Fig. 34
Fig. 35
Fig. 36
WARNING:
To avoid serious personal injury, read and
understand all the safety instructions in this
section.
n Always place the switch in the stop “ ” position
before you work on the saw.
clutch
cover
Run
Position
sprocket
Page 26 — English
cutters
bar
groove
chain drive links
Fig. 38
maintenance
chain rotation
chain drive links
Fig. 37
n Make sure the chain brake is not set by pulling
the chain brake lever/hand guard towards the
front handle to the run position.
NOTE: When replacing the guide bar and chain,
always use the specified bar and chain listed in
the Bar and Chain Combinations section later
in this manual.
n Wear gloves when handling the chain and bar.
These components are sharp and may contain
burrs.
n Press in on the clutch cover lock knob and rotate
counterclockwise until the clutch cover can be
removed.
n Remove the bar and chain from the mounting
surface.
n Remove the old chain from the bar.
n Lay out the new saw chain in a loop and
straighten any kinks. The cutters should face
in the direction of chain rotation. If they face
backwards, turn the loop over.
n Place the chain drive links into the bar groove
as shown.
n Position the chain so there is a loop at the back
of the bar.
n Hold the chain in position on the bar and place
the loop around the sprocket.
n Fit the bar flush against the mounting surface
so that the bar studs are in the long slot of the
bar.
n Replace the clutch cover ensuring that the
adjusting pin in the clutch cover is in the bar
chain tensioning pin hole and that both bar
studs are securely in their respective holes in
the clutch cover.
NOTE: The adjusting pin may need to be slightly
repositioned with the chain tensioning dial so
that it is aligned with the position of the bar chain
tensioning pin hole.
n Replace the clutch cover and rotate clutch
cover lock knob just enough to hold the cover
in position.
NOTE: The bar must be free to move for chain
tension adjustment.
n Lift the tip of the guide bar up to check for sag.
n Remove all slack from the chain by rotating the
chain tensioning dial clockwise until the chain
seats snugly against the bar with the drive links
in the bar groove.
n Release the tip of the guide bar and, if the chain
sags, turn the chain tensioning dial clockwise.
Repeat this process until sag does not exist.
n Hold the tip of the guide bar up and tighten the
clutch cover lock knob securely.
Posted on Jul 08, 2010
  • 4088 Answers
SOURCE: my Homelite chainsaw 33cc zr10926
Remove the starter mechanism from the engine and examine the 'dogs' which engage the flywheel. They either damaged or their pivots are frozen with dirt and other debris. Hope this helps!
Posted on Oct 16, 2010
  • 4088 Answers
SOURCE: What is the mix for my Homelite 16" 33cc chainsaw?
50:1 is the fuel to oil ratio. Never use petroleum oil (engine or boat motor oil). Always use a synthetic saw oil available from home centers, hardware stores and saw dealers. The bottles are usually graduated to various ratios for a gallon of fresh gas. Always premix in it's own container and shake the container thoroughly each time just before filling the tank to prevent oil starvation. Be sure to use bar/chain oil for the chain as well, and keep the chain sharp and well adjusted. Hope this helps!
Posted on Nov 15, 2010
I need to know fule oil ratio for homelite super2 chainsaw
Generally small tool 2 stroke engines run on a ratio of 50:1
That's 100ml of oil in 5L of petrol
Apr 03, 2016 | Homelite Garden
Need replacement part
Google Homelite PN# 310508001 and you will find it at many locations
May 09, 2013 | Homelite 33cc 38cc 45cc Chainsaw Oil Pump...
Homelike chainsaw carb settings high/low
Hi, most chainsaws start with carb settings at 1&1/4 turns out( hi+lo) usually once the chainsaw has been run in, the 'hi' screw can be turned in an eighth, tickover set low enough not to cut out but high enough not to engage the clutch, cheers Billy
Feb 15, 2013 | Homelite Garden
Manual for 330 homolite chainsaw
losen the nuts for the clutch cover and tighten the screw on the side of the bar
Mar 23, 2012 | Homelite 33cc 38cc 45cc Chainsaw Oil Pump...
Nov 14, 2010 | Poulan Pro 14" Gas Chainsaw 33CC P3314
PETROL ENGINE WORKS FINE BUT SAW CHAIN DOES NOT FU DOES NOT DRIVE
It is possible that the clutch has froze, could try taking the side pannel of and seeing if it spins freely with out the chain bar on. If it does, it could be a problem with the chain, make sure its not tightened up too tight and that the chain can move freely over the bar.
Jan 10, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Chain not moving
Perhaps. The chain and bar get very hot, sometimes causing the chain to bind, there is a reason for the bar oil reservoir. You may have burned out your clutch. Your chain may be excessively tight. I suggest you find a neighborhood chainsaw seller/mechanic and pay for a quick inspection. While there ask for a 10 minute instruction on how to use your saw. Purchase of a complete set of personal protective gear sounds like a good idea too. HTH
Lou
Sep 17, 2009 | Homelite Garden
Feb 11, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
