Question about Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television
I have a toshiba 52hm84 I just recenlty put in a new bulb and it has been working great. today I turned on the television and would get a good picture for about 1-2 seconds and then the screen would go black. I would change the channel and onlly get sound. Any ideas on what the problem might be?
  • Toshiba Master
  • 3,459 Answers
Make sure the bulb door is secure..if not it will shut down the bulb
Posted on Apr 19, 2013
premtech
  • 934 Answers
SOURCE: Toshiba 52hm84
It's either signal board or light engine and unless you're really pretty good at electronics neither one is something you should tackle. I do have the service manual for this unit and I would be glad to send it.. Just drop me an email premtech@willapabay.org and make sure you include the model number as well as what it is you need.. I get almost 650 emails a day so it's really hard to remember who's email goes with what problem. :) Good Luck Bill
Posted on Jun 11, 2007
  • 375 Answers
SOURCE: Toshiba 46HM84 DLP Black and white pattern..
contact your dealer for service flashfor this symptom.(light tunnel)
Posted on Sep 05, 2007
techman
  • 3130 Answers
SOURCE: Toshiba 52hm84 DLP buzzing sound after replace bulb?? no pic
You have bad capacitors in the power supply that took out the regulator, or the ballast circuit is defective. Not really a repair for the novice. Good Luck
Posted on Nov 07, 2007
electronick
  • 505 Answers
SOURCE: Toshiba 52HM84 DLP TV with new bulb but the lights keep blinking
They exact way the lights blink are telling you what the failure is. If the tv is firing the lamp and the lamp is bad, you will hear a buzz sound for about 1 second. The tv tries 8 times before it gives up and spits out the lamp error. Check the user manual for led diagnostics. If you put in a new lamp but still have issues, you've likely got a bad ballast (most common on this model) or colorwheel (less common). Both are part of the optical block (light engine) and I don't believe they're available as individual components from toshiba.
Posted on Dec 06, 2008
  • 630 Answers
SOURCE: My Toshiba 52HM84 blows bulbs
Ensure that you don't handle the bulb with bare fingers. wipe the bulb with meths and hold the buld with a lint free cloth when you're putting it in. If it's still blowing it's probably over heating so check the fan
Posted on Aug 22, 2009
My toshiba tv 52hm84 is turning off by itself how do i fix it. i replaced the bulb. but it still turns off about 15 to 20 minutes after its on. the picture will start cracking before it turns off
you have not corrected the problem by replacing the bulb you have to probe more deeper into the tv.check your regulator in the power supply it is a ic maybe it is damaged also check to horizontal output transisitor Q405 IT CAN BE DAMAGE.Good luck.
Feb 21, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
Aug 22, 2009 | Toshiba 56HM66 56" Projection HDTV
Changed bulb and still no picture or sound
hello i think when you put a new bulb in you have reset the bulb counter good luck
shaun
May 30, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
Apr 10, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Nov 28, 2008 | Toshiba 52HM95 52" HDTV Projection...
I have a 52" Toshiba
the ballast isnt keeping the bulb lit.
Mar 16, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Nov 06, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television Logo
71 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
