Question about Kenmore 24032\24036 Top Load Washer
How do I remove agitor to clean the filter. Our clean clothes have a much lint on them when they come out of the washer
    Sergeant:
  • 330 Answers
Most agitators in top load washers are push on and hold on tight that way. There is space for you to insert fingers under the base of the agitator. Put fingers of each hand under opposite sides under the bottom, grab tightly, and pull up under control. The agitator should come out. Hope this helps. Unless you have the written instructions in your book that says otherwise. Good luck and let me know if it helps!!!
Posted on Apr 18, 2013
jsrock516
  • 5911 Answers
SOURCE: Washer leaves too much lint on clothes
There are many things that cause lint. Some are easy to figure out, some aren't. Here are some of the most common things: 1. Separate clothes that are lint givers from lint takers (i.e., sweaters are lint givers and should not be washed with cotton which attracts lint). 2. Check clothes pockets for tissues or paper. 3. Don't overload the machine. 4. Use enough detergent to hold the lint in suspension. Read the recommended usage on the detergent bottle. 5. Use enough water to rinse the lint away. Washing large loads on a water saver mode is not a good idea. 6. Use fabric softener to reduce static attraction of lint. 7. Washing clothes on too long of a cycle, too often can cause premature wearing of the the fabrics. I hope some of this may help you. PS Adding a cup of plain white vinegar to the rinse cycle has also been known as a "cure" for controlling lint.
Posted on May 22, 2007
  • 1314 Answers
SOURCE: kenmore washer always makes lint on clothes
yeah check my four boxes and send me an e mail at b4829@yahoo.com ref lint on clothes
Posted on May 22, 2008
erpaalai
  • 999 Answers
SOURCE: washing machine lint trap
There is no trap per say. The lint catcher is self cleaning when the water is pumped out. It sounds like you are overloading it and the clothes are hitting the agitator. Operation should be agitation by water movement not beat by the plastic fins, run a wash cycle hot water no clothes to flush things out and try smaller loads.
Eric
Posted on Mar 14, 2010
  • 1937 Answers
SOURCE: Clothes come out covered in lint after washing
Sears top load / direct drive washers don't have specific Lint Filters.
See the Use and Care manual for these washers for hints.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0705087.pdf
Posted on Apr 13, 2010
Testimonial: "The answer was sent back quickly. The information was very helpful."
  • 10 Answers
SOURCE: Does this washer supposed to have a lint filter
No Lint Filter sorry you have a basic design washing machine, Dont replace it though it wont do u any justice just pocketbook pain
Posted on Jul 23, 2010
I wash all my darks together. No fuzzy stuff either with the black items. Don't overload as I am only person doing laundry. Why the lint left on the clothes. Kenmore Elite Series 600. Please help.
Your Kenmore washer does not have a lint filter. Washers manufactured today and in the past few years are not designed with lint filters. The engineers rely on the dryer to remove any lint left on the clothes that doesn't get flushed down the drain.
overload the washer? The wash load must be balanced and not overloaded. Clothes should move freely.
Lint can be trapped in the load if overloaded. Wash smaller loads.
Use the correct water level? The water level should be correct for the load size. Clothes should move freely in the water.
Alsp liquid detergent works better in cold water and has modifiers to keep lint in the water not on the cloths.
Do you line dry your clothing? If so, you can expect some lint on the clothing.
Check the following too
Was paper or tissue left in the pockets?
Use the proper cycle time for the load? Reducing wash time (duration) is another way to reduce lint.
these should help in reducing the amount of lint left on your clothes.
Thank the wonderful engineers for this problem.
There is one other thing you can do. Micro fiber cloths attract lint like nothing else. Inexpensive ones added to a wash load will catch almost all the lint.
found this out the hard way by trying to clean some that I used in auto body seminars for removing polish and waxes when doing detailing demos. they came out full of lint when washed in a mixed load,..looked worse than they did dirty. well sort of..they were still good for what i wanted them to do but looked like heck. :) if rewashed alone they cleaned up.
hope I helped a little.
Dec 31, 2017 | Kenmore Washing Machines
Dryer is taking a longer time than normal to dry unless we switch it to timer. Replace sensors?
  • Remove and clean the lint filter each time it is used. The filter can be washed with warm soapy water to remove fabric softener residue from the screen.
  • Check the household fuses and circuit breakers. Most household dryers use two fuses or circuit breakers. It is possible for only one of them to trip and the dryer still tumble, but not heat.
  • The washer controls may have been improperly set. If the clothes are wetter than normal, coming from the washer, this could be the difficulty. If the gentle speed is selected for a normal load the washer will not spin adequately. High speed or extended spin removes more water from clothing decreasing drying time
A lint filter that is full of lint will restrict airflow and lengthen dry times. To keep your dryer working correctly, clean out the lint folder after each and every use. Check the lint filter for any buildup of fabric softener that will restrict airflow and wash with soapy water to clean. If the filter is damaged then replace it.
Nov 09, 2017 | Dryers
Admiral washer atw4470tq0 lint issues on clothes
clean the lint filter in the machine
remove any tissues and papers from pockets before washing
Nov 07, 2017 | Admiral Washing Machines
All cycles work but clothes come out wet, top loader model# AAV7000AWW is there a lint trap that needs cleaning?
Lint traps are in dryers, not washers If clothes still come out wet then perhaps the water pump is not working properly and/or the drum is not spinning fast enough to allow centrifugal force to remove water from clothes.
Feb 07, 2016 | Washing Machines
Csn you remove trap where lint filter goes
How To Clean Your Dryer's Lint Trap, Screen And Vent ...
greenlivingideas.com/2014/08/14/clean-dryers-lint-trap-duct-screen/
Aug 14, 2014 - Cleaning your dryer's lint trap, screen and vent is a great way to keep it using energy efficiently. ... (Of course, if you can hang your clothes to dry, you'll not have to go ... Now use the vacuum to remove any lint from the lint trap.
Stackable Dryer-Lint Screen-Where is it? - YouTube
? 3:09
https://www.youtube.com/watch?v=-qu0OF9V2vA
Dec 27, 2011 - Uploaded by OcRefrigeration & H.v.a.c.
This Video Shows Where a " Lint Screen " is in a Stackable Washer Dryer and How to Remove it. Clean it ...
How to Clean a Dryer Lint Screen ' Cleaning Guides
www.howtocleanstuff.net > Cleaning Guides
Jan 11, 2016 | LG DLE5001W Dryer
Prblems with Kemore washer
Clean your washing machine before your next wash load to be sure there is no lint trapped anywhere in the machine. Fill the tub about half full of water then add a couple of cups of white vinegar to the wash water. Allow it to agitate and then sit there and soak for at least an hour before you empty the machine.
Lint is small fibers from clothing that have come loose from natural wear or laundering. They can build up in washers and wreak havoc on your clothing. The dryer will remove the lint. But with clothing, like dress shirts that are air-dried, this can be a real problem; often requiring multiple washings to remove the lint. Older washers came standard with removable lint traps that could be cleaned. Some would filter the water as it recycled through the washer, while others would require the removal of the center tub support for cleaning.
Newer washers have a self cleaning system that uses a filter to trap the lint and the spin cycle to flush it away. It saves the inconvenience of having to manually clean the filter.
If you have a lint problem, here are a few tips to try:
1) Low water pressure can impede the flushing action of the washer during the spin cycle. Look for pressure variations during filling of both hot and cold water. A kinked or blocked hose can cause this. Check for sediment in the hose as well.
2) Verify that the all of the water is being pumped out of tub and that no restriction in the drain hose exists.
3) Don't wash high lint producing items like socks and towels with your dress shirts.
4) Use a name brand detergent. They have higher quality cleaners and soften the water better, which helps release the bond between lint and clothing, allowing it be flushed away.
5) Don't overload the washer. Your washer needs water and room to remove the lint.
6) Run a wash cycle with a cup of regular white vinegar added. This will help rid your washer of any accumulated lint.
A washer doesn't produce enough lint to have any effect on a septic system, so a separate washer filter is not necessary.
Add a cup of either white or cider vinegar to your washing machine along with the detergent before loading in your clothes to keep lint off.
Sort out all towels and washcloths since they create lint. Put them through a separate wash cycle to keep them from transferring lint to your clothes.
Check the labels on all your clothing to be sure you sort them correctly. Cotton clothing produces lint in the washing machine while polyester clothing picks it up. Wash them at different times to keep the lint off those that are likely to pick it up.
Turn your clothes inside out before putting them into the washing machine to keep them from collecting lint as they go through the wash cycle
Jun 18, 2010 | Kenmore 24032\24036 Top Load Washer
We have a Whirlpool top loading washing machine that leaves the clothes covered with lint after each load. Delicate clothes that have elastic bands are covered with pieces of lint on the bands that are...
Your service man is right, the lint is filtered through the filter plugs on the bottom of the tub, and backflushed out during the spin cycle. This does not do a great job of filtering out the lint that came out of the clothes. So why is there so much lint? Three reasons: 1. Clothes being beaten against the agitator, tub, each other. The Whirlpool washer has a pretty decent way of agitating the clothes without too much damage, as long as there is plenty of water for the clothes to move through. As long as you make sure your load size and water level are correct, this shouldn't cause a lot of lint. I always have a larger water level than the load size calls for. 2. Lower quality material in the clothes. We definitely see this a lot, especially in the cheaper towels, rugs, sweaters, ect. Some of these have such cheaply made fibers, that they put out a lot of lint. 3. Laundry soaps. Most soaps are very caustic detergents and eat the fibers right out of the linens. There are some brands of washers that still use a type of metal in them that this soap eats right up, so in a few years the machine is junk. All of the washer manufacturers went to plastic outer tubs, as the soap was literally eating holes in the outer tubs in 2 to 3 years on some brands. This is one of the reasons we have so much of the micro lint that is so fine, it goes right through your dryer lint filter and causes lint build up in the venting itself. Years ago, at our shop in Hawaii, we tested naturopathic soaps for 12 years before we settled on the Melaleuca brand for our laundry soaps. Ph neutral, cleans the clothes better than any brand we have tested before or since, does not leave the sludge in the outer tub that most brands do, does not leave a hard aggregate in the tubs like some other brands do, is cheap and does not cause the allergys, athsma, skin rashes, ect. that most of the caustic brands are doing. We have used it for over 10 years now and see very little lint in our Whirlpool washer. Look it up online, join it, and buy the soap directly from the company. It sounds like you have done everything else correctly to the washer, that you could have. I am impressed, most people could not have done what you did. Hope this helps. Good Luck, Appliance Specialists
Jan 22, 2010 | Washing Machines
How do I removethe lint? Clothes are coming out with fluff...
Sorry for the obvious.....
Fluff on the cloths is from the lint trap not capturing it from the air flow.
Air is passed into the clothes from the laundry room. It is heated and then passed over the clothes... then filtered air is forwarded to the outside exhaust.
If you are seeing lint on your clothes, then the air coming in from your laundry area is not lint free.
1. check the back/bottom of the dryer for lint accumulation.
2. Remove the lint trap and clean out the duct work.
3. Inspect all the flooring and areas around the dryer for dust/lint - and clean any that you find.
I believe that you will then have a clean and dry load.
The proceedure of cleaning described above should be repeated every 6 months or so....
-Jim
Nov 05, 2009 | Roper RAX4232KQ Top Load Washer
GE top load washer w/no lint trap leaves excessive lint
Most US-sold washers made after the mid 1980s don't have lint filters. The manufacturers weasel-word around it by saying that the lint "goes down the drain", leading people to optimistically assume that there is a self-cleaning filter in there somewhere. There usually isn't and whatever lint doesn't go down the drain is filtered by your cloths (but whatever does might clog your septic system). As a result of this scam, it's much harder to hang-dry or iron-dry clothes that haven't been hand washed. And, if you think spending $2000 on a pair of matched "front-load" style machines will solve this, you might be wrong; many of those washers still have no lint filter.
Jan 08, 2009 | GE WBSR3140DW Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
42 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
