Question about John Deere Riding Lawn Mower. EZtrak Z245 48 in. 23 HP V-twin Zero-
Front of deck will not raise up on john deere z245
When raising and lower deck front of deck just stay on ground you can move it freely with hand
5 Suggested Answers
  • 21 Answers
SOURCE: john deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
Posted on Jul 14, 2009
nova2nv
  • 197 Answers
SOURCE: my john deere 214 won't start
The deck lift lever normally wont start lifting until you pull back at least half way.Ther are 2 sets of wires that go under the fender deck,one set goes to the seat switch and the other set goes to the neutral start switch next to the shift lever,just in front of the seat.The neutral start switch wires more than likley came loose when you pulled fender deck off.The micro switch is on the back side of plate that surrounds shift lever.
Posted on Nov 16, 2009
SOURCE: Three point hitch on 2020 Jogn Deere Tractor will not raise.
In the worst scenario, the follower, or the piece that senses load on the control shaft , may have broken. Several causes could be the culprit, but happened on my 2520 . Fix requires total disassembly of final drive and differential to remove control arm and repair the follower. Good luck.
Posted on Jun 27, 2012
SOURCE: how dow you fix a 240 john deere skid steer hand control where the rod broke inside the arm so you can't lift or lower the bucket
If memory serve's it's a whole new control lever.
Posted on Jul 12, 2014
Just bought a John Deere 325 mower. Deck will not raise or lower. Center knob is locked up will nor turn either direction. Lever that raises deck does nothing. I got no manual with it. Used
Study the mechanism and linkage for moving the deck and then take appropriate action. If you see how it works and familiarize yourself with it you will know what to do in such times. You might also consider getting a service manual or Googling the issue.
Aug 28, 2017 | John Deere Garden
My rider craftsman model 917280083 the deck sits too low it drags the ground even at the highest settting
most craftsman have a bar that goes from the deck to the front of the frame that raises or lowers the deck in your case you will want to tighten it up to make the deck higher.
May 02, 2017 | Craftsman Garden
Johns Deere 725 front mount lawnmower won't raise deck or steer. But does move.
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Oct 03, 2016 | John Deere Garden
Mower deck will not raise or lower.
Did you examine the linkage provided to move the deck up and down?
You do that and I guarantee that you will find out what the problem is so you can make the fix.
Aug 29, 2016 | John Deere Garden
I have a John Deere LX178 lawn tractor and the mower deck will not raise/lower. It is all the way down and pushing in the button is how i've ALWAYS adjusted the height. It will not budge
1) NEVER adjust to where the deck wheels touch the ground. The wheels are to ride 1/4" off the ground. 2) The long lever to your left which raises & lowers the deck has 3 settings. 1- Fully back toward you which has the deck raised (called transport mode). 2- Halfway down which is the normal mowing mode (called float mode) 3- Fully away from you which sets the deck fully on the ground. This mode is ONLY used for VERY rough terrain where the deck risks getting pushed into "transport" or "full up" mode & getting stuck there. 3) On front-to-back tilt, the front should be 1/2inch lower than the back for least damage to the grass. Ok-now to adjust "cutting" height. 1) Park on a level, flat surface. 2) Pull the deck lever fully back toward you to put the deck into "transport" mode. 3) twist the "cutting" height knob (just below your seat) to the height you want the grass cut. Has choices by 1/2" increments from 1" to 3.5". The deck in "transport" mode is 4". 4) Lower the deck lever to the midway/"floating" mode point. 5) Adjust each deck wheel with its own peg & pin to have at least 1/4" clearance from ground. Thats it for "cutting height" adjustments
call your deere dealer,
Troubleshooting
Service Mower
cant find info for you,call dealer
Jun 03, 2015 | Garden
How do I remove mower deck on Toro riding mower 1986
First put the front on a jack stand on high. then lower the deck all the way down. Look at the three places on each side to remove the pins that hold the deck on Then there should be two in the front of the deck, remove them. Remove the belt from the motor pully. Lower the mower to the ground and release the peices the pins were in. Remove the clip from the tension cable and remove the cable from the deck. Raise the mover to pull out the deck. Reverse to instal
I hope I helped you
Oct 04, 2014 | Toro Garden
Matrix scooter
check brakes. raise front wheel and spin should spin freely. if so lower front wheel back to ground and raise rear wheel. turn wheel by hand and listen for brake drag/binding should turn easy. loosen axle nut see if that helps . loosen nut no more than half a turn.
Jul 14, 2013 | Motorcycles
2000 craftman lawn tractor 917.270822 blades will not engage
If your blades won't engage when you raise the lever to engage them AND that lever moves freely without the normally expected resistance, then you've lost the cotter pin that connects the lever rod to the mower deck assembly. Very easy fix! Using the mower deck raise/lower lever, lower the mower deck to "down" position. Now, lay on your side along the right side of the mower and look up (use a flashlight) under the mower at the top of the mower deck while moving the blade engagement lever "up" (which pushes the connected rod down). At the end of the rod, you will see a hole where the mower deck and rod connect. Align the hole at the end of the rod with the matching "pin" on the mower deck (you'll see it) and insert a new cotter pin to secure them together. Use a nail if you don't have a cotter pin. Voila! you are done. The blade engagement lever will now engage/disengage your mower blades successfully. Just remember that mower deck must be down, or lowered, before you engage the blades!
Jun 22, 2012 | Garden
John Deere Riding Lawn Mower. EZtrak Z245 48 in. 23 HP V-twin Zero- Logo
167 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
