Question about Toyotomi OM-148 Water Heater w/ Chimney Kit
I ran out of kerosene for my Toyotomi OM-148, I now have fuel and cannot get it to re-fire. It takes approx. 17 seconds once I restart to get a warning light. Please advise where I live I am looking at a 100 dollar service call just to show up. I did remove the fel bowl to try and get it to bleed but nothing came out?
    Problem Solver:
  • 15 Answers
If it worked fine before you ran out of gas then you have air in the fuel line. You need to open the fuel line just enough to get fuel to weep at the fitting in back of the unit. Press the red bleed button twice, and no more, to prime the unit. It may take half an hour before you finally get fuel throughout the system again. It's a pain but you've got air in your line still.
Posted on Jun 08, 2014
  • zayden campbell
    zayden campbell Mar 26, 2016
    where is button located
Where is the flame sensor?
it will be close to the fire ring and is a photo electric cell
it registers flame light and cuts off the fuel supply with in seconds if the flame doesn't appear
Feb 15, 2014 | Rheem EcoSense by 7.4 GPM Tankless Water...
GX90-715A wont stay fired
1) Product manual has burner info page 11, maintenance 12, and troubleshoot flow charts starting page 17
Otherwise, Rheem does not post service manuals.
http://bostonheatingsupply.com/Rheem/Rheem%20Commerical%20Gas/Rheem_CommGas_Extreme_Use%20and%20Care%20Manual.pdf
2) Post question on pro water heater forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
3) Is air intake clear? Is the burner sooted? Is the flame large and clear blue? Is the vent obstructed? Does air draft when blower activates?
Feb 14, 2013 | Rheem RUUD GX90-715A Water Heater,gas,90...
Replace thermocouple gas water heater
Thank you for the brand. Approx how old is water heater? 2nd and 3rd digit of serial number are year of manufacture.
For general instructions:
http://waterheatertimer.org/How-to-replace-thermocouple.html
Reliance is AO Smith, and air intake is located on bottom of tank.
Inspect and Clean intake.
Do NOT underestimate need to keep air intake clean because the arrestor screen is fine mesh and once clogged will cause heater to fail. Older models might need full replacement and at least parts.
http://waterheatertimer.org/images/Flame-trap-inspection-325.jpg
Product manual?
These gas water heaters are changing quickly today. The Reliance site shows the 909 but not 805
http://www.reliancewaterheaters.com/lit/om.html
The older designs are different, but instructions shown above will help.
Sep 22, 2012 | Reliance Water Heaters
Trying to find temp dail
You posted under Reliance point of use electric water heater.
Open following link to access manuals:
http://www.reliancewaterheaters.com/lit/om/e100.html
Thermostat has adjustment screw.
Open access door on side of water heater
See diagram of thermostat and approx settings:
All water heater temperature settings are approximate.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#Reliance
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 19, 2011 | Reliance & Electric Water Heater
Paloma (Rheem) tankless water heater 7.4 gpm 199,000 btu outdoor unit. Red light is blinking on pc board. unit fires up for approx 2 seconds then shuts off, then cycles once more for 2 seconds and shuts...
i think your flame sensor is bad but you will need to confirm that with rheem i am unsure what the c7 is for but code 12 is flame failure and there could be carbon build up on the flame rod...
Aug 06, 2010 | Rheem Tankless Hot Water Heater...
Burner fires but goes out after a few minutes.
Are you 100% sure there is water in it, try opening the pressure relief valve slightly to verify tank is full. If it is full check that by-pass valves at rear of tank are in normal operation position. When you say won't run very long, how long would that be approx.?
Jul 30, 2010 | RTO Atwood Water Heater - 6 Gal LP
How do i reset my boiler after having oil delivered, it ran out 2 days aggo just had 1000 litres delivered how do i getr the boiler up and running again????
While standing in front of the oil burner, on the left side you will see the fuel pump. On the bottom corner towards you, you will see a bleeder screw. If you put a cup or other vessel under this screw, loosen the screw, then hit the reset button it will start to push oil out the bleeder. Once the oil comes out a clear red liquid, close the bleeder screw and the unit should fire up. Hope this helps
May 13, 2010 | Water Heaters
I have a vokera unica 28 which pulses when firing
your fan may need attension fan runs after boiler shuts down is normal on some Vokera,s too clear fumes out the flue 2mins approx
Oct 04, 2009 | Water Heaters
Toyotomi OM-148 Water Heater w/ Chimney Kit Logo
242 people viewed this question
Top Toyotomi Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Toyotomi Water Heater Expert? Answer questions, earn points and help others
