Question about Toyotomi OM-148 Water Heater w/ Chimney Kit
Toyotomi OM-148 trouble shooting - Toyotomi OM-148 Water Heater w/ Chimney Kit
Is there trouble shooting instruction for a R75LS Rianni
I would contact the manufacturer to see if they can enlighten you as to what it might be .
Oct 09, 2016 | Rinnai R75LSe Natural Gas Tankless Water...
How do I trouble shoot a residential water heater
Hi Michael:
First off you have to determine what the SYMPTOM is that you are experiencing.
Example:
- water too hot
- puddle under tank
- very little hot water.
Then you can ask the FIXYA gang for help with the problem, or
You can research it yourself.
Jul 18, 2015 | Water Water Heaters
I ran out of kerosene for my Toyotomi OM-148, I now have fuel and cannot get it to re-fire. It takes approx. 17 seconds once I restart to get a warning light. Please advise where I live I am looking at a...
If it worked fine before you ran out of gas then you have air in the fuel line. You need to open the fuel line just enough to get fuel to weep at the fitting in back of the unit. Press the red bleed button twice, and no more, to prime the unit. It may take half an hour before you finally get fuel throughout the system again. It's a pain but you've got air in your line still.
Apr 18, 2013 | Toyotomi OM-148 Water Heater w/ Chimney...
Can't light pilot light on hot water service. Gas to property is connected as the gas stove works.
There should be a trouble shoot guide on the hot water tank. I have had to do this many times. You just need to read the trouble shooting guide & be very careful. I hope this works for you.
D :)
Feb 01, 2013 | Water Heaters
Have an LP gas water heater with White Rogers control that cycles on and off 3 times before remaining on. Water heater is 5 years old with forced exhaust. Heats water fine once it remains on. Do you...
From what you say, I would CLEAN the thermocoupler with either steel wool or a green scouring pad (dry) and then wipe off the residue with a clean cloth. If you still have trouble then it could be a gas valve that is sticking.
Jul 01, 2011 | White Rodgers Water Heaters
How to trouble shoot a thermostat : Model # K04A110844
disconnect the wires to check for 220v to the therm. same for the elements disconnect the wires to check continuity that the elements arnt shot. make sure reset is pushed in on upper element
Jan 14, 2011 | Reliance & 50gal Electric Water Heater
Water is too cool for shower. Is there a thermostat?
I do not believe there is a separate thermostat. However the installation guide: http://www.eemaxinc.com/assets/files/FLOCO-install.pdf gives some trouble-shooting steps. More detailed trouble-shooting is here: http://www.eemaxinc.com/assets/files/floco-trouble.pdf
If the indicator light is off when the hot water valve is open: check your circuit breaker and the flow rate of water into the water heater (it must be over 1/2 gallon per minute). If those are okay, check the resistance of the element with a multimeter - 20 Ohms or less is good, 10,000 Ohms or so indicates a bad element. The trouble-shooting guide indicates the proper points to test.
If the indicator light is on, then check the flow rate at the shower head or faucet (reduce the flow until the water comes out hot), check that the unit is installed to the correct voltage supply and the resistance of the element.
If those are okay, then check that the printed circuit board is correctly installed and that the inlet filter isn't clogged.
After that, it's call the company for their technical support.
Dec 18, 2009 | Eemax EX95 "Flow Controlled" Electric...
Toyotomi OM-148 Water Heater w/ Chimney Kit Logo
175 people viewed this question
Top Toyotomi Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Toyotomi Water Heater Expert? Answer questions, earn points and help others
