Question about Rubbermaid Marine Series Ice Chest, 102qt, White
Rubbermaid 96 quart cooler latch broke
106 qt
My handle broke on my 18 qt roaster.
Rival may have a web site that carries part information. Try going to Rival.com for replacement parts.
Nov 27, 2015 | Rival RO180 18-Quart Roaster Oven, White
How much oil in a 2012 fat boy low ?
2013 Softail
a. Use 3.5 quarts (3.31 liters) of engine oil for a wet
capacity refill.
b. Use 4.0 quarts (3.79 liters) for a dry capacity refill.
NOTE
Use wet capacity values for engines that have just had
the oil drained. Use dry capacity values for engines that
have been disassembled, cleaned in solvent and dried.
2013 DYNA
a. Use 2.5 qt (2.4 L) of engine oil for a wet capacity refill.
b. Use 3.0 qt (2.7 L) for a dry capacity refill.
2013 Touring
Initially add 3.0 quarts (2.8 liters) of engine oil
2013 VRSC
Oil capacity with filter 5.0 qt 4.7 L
2013 SPORTSTER
Oil tank with filter 2.8 qt 2.6 L 2.8 qt 2.6 L 2.8 qt 2.6 L
Sep 04, 2014 | Motorcycles
How to cook pinto beans in my 22 quart roaster oven
I cook 140 lbs of beans every year at church for a ham & bean dinner. I soak them overnight in 4 large rubbermaid containers (about 35 lbs in each covered all the way to the top with cold water). In the morning I drain the water, rinse beans and divide between about 14 cookers (several of them are the 22 qt roasters). You can put beans in to about 1 1/2 to 2" of the top rim. Put a ham bone in (I pre-cook about 12 10 lb bone-in hams two to a roaster sitting in about 1" water several days before, chop the meat, save the juice and the bones) and a cupped palm full of salt (3/4 to 1 T ?) and cover with water. Cook on about 350 degrees. When they start going dry add the leftover ham drippings that were saved (I usually have it heating in a crockpot nearby so that it doesn't slow the cooking of the beans down).
Aug 10, 2011 | Rival 18 Qt Roaster Oven with Buffet...
I broke the rubber band for my 4.5 quart over crockpot. Does anyone sella replacement? The rubberband is used to secure the lid when transporting the crockpot.
Marbeck.com has lids and the latch band... It is hamilton beach, but it will work for nearly all crocks.
http://www.marbeck.com/hamilton-beach-slow-cooker-replacement-lid-latch-band/
Dec 10, 2010 | GE 106661 4.5-Quart
We need a drain plug for a Rubbermaid 48qt cooler, where can we purcahse this part?
You should get the number from the bottom of the cooler and then call Rubbermaid at 888-295-2110 and ask for the replacement part. I'm looking for the same thing, but am away from the product for the number so I was told to call back.
May 25, 2010 | Bass Pro Boating
One of the red, plastic, front latches has broken on the Rubbermaid tool box 7717. I need a replacement.
I have the same problem.I have 4 of these boxes in several sizes.Great toolboxes except for the latches.I rigged the ones with broken latches by getting the smallest aluminum clip (the fake climbing type) that would fit in the lock hole.I drilled small hole in the fin right over the hole and tied the clip to the box with a small piece of string.Works great and better than buying a new box
Feb 16, 2010 | Tool Box Grill Charcoal
Broke the 12v DC plug on our Rubbermaid/Vector Thermoelectric cooler. Can't find a specific replacement plug. Any specific specs I need to look for in a replacement?
A generic plug should work...just be sure to size the fuse correctly to protect the unit. Most thermoelectric units draw about 4 to 5 amps...so a 10 amp fuse usually works.
Dec 09, 2009 | Refrigerators
Rubbermaid Shed: Broken Latch (Part # HIP-046H)
Got to Rubbermaid's replacement part link below and fill out the form. Let them know that you need to replace an HIP-046H latch.
http://www.rubbermaid.com/SupportCenter/Pages/ContactInformationForm.aspx?ContId=72&Id=4
I filled out this form and received a better, metallic replacement latch in about 10 days. Hope this helps.
Dan A.
Sep 06, 2009 | Elite Rubbermaid Frameworks Outdoor...
Thermoelectic cooler not cooling properly
I think you've actually diagnosed your problem. Get that fan moving and you'll probably make this go away. Rubbermaid has a website and decent customer service. If you're in warranty...go there first.
Mar 08, 2008 | Refrigerators
Rubbermaid Marine Series Ice Chest, 102qt, White Logo
130 people viewed this question
Top Rubbermaid Home Experts
Donni Steen
Tom Chichester
Are you a Rubbermaid Home Expert? Answer questions, earn points and help others
