Question about Poulan Garden
Will not crank over seems dead
When i try to start using the key nothing happens no lights,no hour meter no nothing.
  • Tim Davis Apr 18, 2013
    ?? This is a riding mower
  • 81 Answers
Check all conections from the battery to the fuse to the ignition key to the starter motor
Posted on Jun 02, 2013
I have got toyota land cruiser 2009 with manual transmission last night i had replace transfer case oil seal and then i took short trail every think seems to be ok but next morning i start my land cruiser...
wont start
wont crank
or just smart key dead.
what is same, please say what fails, now.
are the RKE dead, both keys,? dead. car came with 2, never have less, or that be big error, and huge costs.
is car with Immobilizer,
what fails, cranking, or just not starting
or IMMO lamp glows, telling you (dash light) cranking will never start ever.
Jan 31, 2015 | Toyota Land Cruiser Cars & Trucks
Kohler cv491
check your fuel filter. Is it dry? Mine was and found the vent in the fuel cap was plugged and it didn't allow fuel to flow through the filter to the carb
Sep 06, 2014 | John Deere L100 Series
05 deville no start turn key on dose nothing
hello Allen. Deville leaks in to my Toyota, forum section, oddly?
but
Engine size not stated.
nor if it cranks robustly
if key is dead, and dash dead, and or head lights dead
check all fuses first in the cab and in the engine bay.
always check fuses first. the battery voltage.
bam 10v bad battery ,dead, or discharged, (i charge it and ./...???)_
battery is good and jumper starts fail.
you turn the key to on, the check engine light glows, (and othere)
that is something
then you move key to crank position (start) i will wiggle the shiftlever.
boom is cranks
no it dont so i try starting in neutral. bam , it cranks. over. bad PRNDL switch.
no it dont, so i hit the starter with a hammer, not crazy just tap tap.
no it dont start.
I hot wire the starter solenoid. it cranks (wont start , key in pockets)
hot wire fails,battery good, starter is toast.
hot wire test passes ,cranks nice.
i then grab my trusty DMM and flip dial to Volts.
i then find why my KEY line is dead.
if you get this far, ask how to fix a dead Key line.,
the starter ST key line,
Dec 12, 2013 | Vehicle Parts & Accessories
Suzuki wont start got power head lights turn key and nothing
I had this happen last month. It was my starter. My previous cars would miss and catch, letting me know the starter was finished, but this one just totally died, I had power for lights and gages moved, but would not start.
Mar 27, 2013 | Suzuki X-90 Cars & Trucks
Car won't start, seems to have power, all lights working. when I turn the key nothing happens. this only happens sometimes
Could be a bad alternator.. It may not be holding charge. Or your starter could have failed.
Though I've had the same problem and it was a dead battery in my vehicle. Had enough power, but to keep the car on..
Oct 22, 2012 | 1997 Saturn SL
2006 Chev Cobalt won't crank...no lights, no sounds nothing. When tried to get the key out it won't go past the ACC position? Any ideas on the problem?
Is the battery dead? Check your battery condition and connections. Check your starter fuse from there. Check the connection to the starter then progress to the ignition side of the concern
Sep 10, 2012 | 2006 Chevrolet Cobalt
2007 Mitsubishi Endeavor won't start. I turn the key and nothing happens. The interior lights are dim and headlights are normal. Had it jumped and same thing happens. Where is the problem? thanks.
I had the same problem too..My battery was stone dead..My lights were on but their probably isnt enough cranking amps to start the truck...I would take the battery out and charge it overnight and then try to crank it in the morning...i just changed the battery and the truck started right up
Aug 12, 2010 | 2007 Mitsubishi Endeavor
1989 ford truck f350 diesel. head lights,hazard lights, and horn have power and work, batteries are charged but truck will not crank. when i put key in and turn the key over nothing happens....no buzzer,...
1989 f250 4x4 lighting problems. i replaced the floor mounted dimmer switch ,the lights worked fine for an hour untill i turned them off.Now the lights will not turn back on but i have park lights.
Aug 09, 2010 | 1989 Ford F 350
My 2002 Explorer starts, but then won't re-start...
Try changing your Fuel pump Relay. When was the last time you had your trans serviced? is their any exsessive furl smell when you exit the Cab?
May 27, 2010 | 2002 Ford Explorer
Husqvarna Ride Lawn Mower does not want to start, which theres about 1/2-tank of gas. My Husqvarna Ride Lawn Mower is only a few years old which I have done some routine maintenace. The lawnmower has set...
I've discovered that if you leave key on battery will be drained to dead. Checking battery with meter shows +12v. When key is turned to start position nothing happens. When you connect meter to battery terminals and put key to start position the meter reads about .250 VDC. Even after taking battery to Advance Auto and have it checked it still does same thing. Eventually I jumped my mower with another battery that was being used in my scooter. Bingo! all worked well with jump. You would probably be able to jump with car battery with no problem.
Mar 25, 2009 | Husqvarna Garden
Garden Logo
112 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
