Question about Garden
Cub cadet string trimmer cc3075 clutch replacement
Inner shaft broke. ive changed these before. but I cant get inner shaft out of bell.
  • 48 Answers
SOURCE: I cant start my cub cadet cc989
sounds like a plugged high speed jet
Posted on Oct 24, 2008
joboo1
  • 257 Answers
SOURCE: transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
Posted on Mar 23, 2009
panilling9
  • 284 Answers
SOURCE: engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
Posted on May 26, 2009
  • 376 Answers
SOURCE: finding the oil plug on Cub Cadet LT 1050 with Cohler engine
It is probably on the right side in the middle of the engine. It should have a yellow cap on the end of the drain. Take the cape off and slide about a 12" piece of 5/8" x 1/2" clear vinyl tubing (available at Home Depot, Lowe's, etc.) on the end, turn the plastic body to the left (about 1/4") and pull out about a 1/4". Oil will flow. Reverse to shut off.
Posted on Jun 12, 2009
  • 4 Answers
SOURCE: I have a Cub Cadet lawn tractor that just stop
CHECK THE FUSE
Posted on Jul 02, 2010
Cub cadet just dropped dead?
like a car engine broken rod--piston ring--wrist pin --blown gaskets
May 18, 2017 | Cub Cadet Garden
When i take it off choke it go's dead
The Idle air mixture is off or the main jet is clogged. The carburetor needs to be removed and cleaned and replaced.
Jul 04, 2016 | Cub Cadet BC210 18" 27cc 2-Cycle Gas...
Cant keep running and it wont throttle up just purchased fall 2013. Hard to get started and wont stay running
Was it like this when you first got it ? If not then if you ran it with the choke on and also using the throttle the mixture would be all to pot.
Try applying throttle gradually.
hope this helps :)
Apr 27, 2014 | Cub Cadet BC509 18" 29cc 4-Cycle Gas...
Trimmer string will not stop comming out
Hi sounds like the cord is wrapped on the wrong way or the bump feed is engaged in the on position.
Apr 14, 2014 | Cub Cadet ST228 17" 27cc 2-Cycle Gas...
Trimmer wont run
David check the spark plug first and then the air filter. If both of these are clean and the spark plug is sparking put some fuel into the block.see if it runs then.
Oct 02, 2013 | Cub Cadet ST228 17" 27cc 2-Cycle Gas...
My cub cadet tractor starts but the pto clutch stays engeged and i cant shut it off(pto)
The clutch has it's own brearings in it. You have to replace the hole PTO.Sometimes you can find a Aftermarket PTO clutch. There usually A little cheaper.
Jul 10, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Cub cadet 4 cycle weedeater
undo the bolts at the rear of machine first then access inner bolts holding engine to remove then work forward
Aug 21, 2009 | Garden
Garden Logo
119 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
