Toner Problem the toner is brand new but it still says ''Toner is almost empty'' add a new one ?
    Problem Solver:
  • 5 Answers
Check for obstuction of the toner level sensor, (ie: dust, dirt, toner spillage). Be sure to go into control panel settings to tell the unit a new cart has been installed if there is no auto-sensor. Check the eletrical contacts inside cavity and contact points on cartridge for oxidation.
Posted on Mar 11, 2009
3 Suggested Answers
  • 214 Answers
SOURCE: Toner Empty Message won't go off
check that the toner is inserted correctly, reboot print.
Posted on Dec 07, 2007
  • 360 Answers
SOURCE: toner empty after replacing new toner of samsung s...
press menu# 1934 then display tech mode
press left arrow key and enter twice
then its ok
to go normal display continue previous simulation.
Posted on Jun 21, 2010
Sharp Ar-5516 toner light problem continue blinking
If the toner light has a line under it your waste toner container is full and needs to be emptied.
May 04, 2016 | Sharp Office Equipment & Supplies
Add toner problem
toner is empty replace new toner
Jul 14, 2014 | Ricoh Aficio Mp2500 Mp2000 Mp1600 3030...
Add black toner but still empty
Is it a genuine Ricoh Toner or a equivalent refill, if it is the latter then my machine would say empty when actually full. Just keep on using the machine, and have another toner on stand by.
If its a genuine Ricoh toner suggest the machine needs a clean around where the built in (toner) chip is located.
Jun 03, 2014 | Ricoh Aficio SP C820DN Laser Printer
Toner dumping straight into toner bag
use original toner OR reset toner indication
Sep 12, 2012 | Toshiba 2860 Copier
Just refilled a nearly new Brother DR2000 and
Who knows what you did wrong? - maybe nothing. But one of the following is the most likely reason:
- You simply topped up the cartridge with toner without completely emptying the the remaining toner out. There is always toner left-over inside, and different brands don't mix well.
- You used a brand of toner not designed for that cartridge.
- It's simply a crappy compatible brand - I've run across all kinds. All toner IS NOT created equal.
Jun 08, 2009 | Ricoh FT3713 Copier
Studio 230 added a new toner cartridge
When adding toner to the developer unit, it will load from the toner. So, if toner is empty, it will ask for replacement. Normally u can hear noise from the toner when loading.
Mar 19, 2009 | Office Equipment & Supplies
Add Toner stuck on & Replace Photo Conductor Unit (PCU)
I suspect that it is the PCU causing the problem, and the message should clear once the PCU is installed and it (automatically) runs it's calibration cycle. Likely the toner auger gear has seized on the PCU, and broken. If the light does not go off after installing the PCU, then you may need a technician, as the toner motor may not be working, or there is a blockage within the toner hopper itself.....but again it is likely the PCU, especially if the toner bottle was empty when it needed replacement. Was it empty?? Did the machine work for a few days, or at least for a while? If so, it seems like too much of a coincidence that this problem would come up at this time.
Good Luck :)
Mar 18, 2009 | Office Equipment & Supplies
I don't know how to remove and install toner for my sharp ar-337
If you go here:
http://www.sharpusa.com/files/cop_man_ar287_337_407.pdf
You can download the operation manual for that machine, on page 4-5 they explain how to replace the toner and have pictures showing how.
here is the text on how to replace.
Adding Toner
1 Open the front cover.
2 Pull down the toner hopper lock lever and pull the toner
hopper out slowly until it stops.
3 Tap on the top of the toner cartridge 5 times. Hold the
new toner cartridge vertically and vigorously shake it
up and down about 20 times, then invert the cartridge
and again shake it up and down about 20 times. This will
loosen the toner and allow it to flow more easily into the
toner hopper.
4 Place the new toner cartridge with the tabs in the
notches as shown.
5 Slide the toner cartridge along the guides over the toner
hopper.
6 Hold the toner cartridge with one hand while pulling on
the sealing tape to remove it.
7 Tap on the top of the toner cartridge 5 times to start the
flow of toner into the toner hopper.
l If the toner cartridge was sufficiently shaken as described in step
3, it will take about 50 seconds for the cartridge to empty. Do not
remove the cartridge until it is empty. If not empty, tap on the top
of the cartridge again until empty.
8 Slide the empty toner cartridge back along the guides
and remove it.
l The cartridge opening will be closed as it is moved back along
the guides.
9 Slide the toner hopper into the copier and return the
toner hopper lock lever into place.
10 Close the front cover.
NOTE:
Add only one cartridge of toner.
Jun 19, 2008 | Sharp Office Equipment & Supplies
Aug 27, 2007 | Konica Minolta magicolor 2430 DL Laser...
380 people viewed this question
k24674
jasbo
jasbo
