Question about Refrigerators
Amana refridgerator, model number is TZ21Q2L . The freezer is working ( has to be kept up high though or it doesn't freeze properly) but not the refrigerator. Everything is warm. Cleaned out under
2 Suggested Answers
  • 2699 Answers
SOURCE: the model number is TZ21Q2L
all the machine does is blow cold air from the freezer to the fridge so when you open the freezer do you hear the fan blowing?if not you have a bad evap. fan motor.also is ther any water leaking into the fridge section?pull out the bottom draws and if water is there you most likely have a blocked drain and it's freezing up the air ducts,one more thing to check,put your hand on the back inside wall of the freezer,if there's like snow or ice on the wall you have a defrost problem.let me know what you find.
Posted on Apr 18, 2011
Why does my freezer keep defrosting
GE refridgerators have what they call a main dome control board. This is located on the back of the machine, usually closer to one side or the other and about halfway up the machine. This board really controls everything, even as far as the dispenser in the door. I personally think this is a poor design, even though they look awesome cosmetically. Locate your model number, usually in the refridgerator side somewhere, and go to www.repairclinic.com to order the part. This is becuase they have a return policy that no one can beat. If you install the part and it doesn't work they will take it back and refund you, where as any other part distributor have a no return policy on electronic parts. Good Luck, but you won't need it. This is an easy repair.
Apr 29, 2012 | GE Refrigerators
The model number is TZ21Q2L . The freezer is working ( has to be kept up high though or it doesn't freeze properly) but not the refrigerator. Everything is warm. Cleaned out underneath but still isn't...
Apr 18, 2011 | Amana Refrigerators
Amana Refridgerator freezes in the refridgerated cavity.
Many Amana refrigerators have something called an auto damper. It has a thermostat coil on the side of it and as the temps get colder the damper door closes. If the thermostat on the side becomes defective then the damper door will remain open or shut. If it remains open the food in the fresh food compartment will get so cold that sections will freeze. If you could send the model number of your Amana I may find a service manual with instructions that tell you how to test by removing and dipping the thermostat into warm or cold water to see if it is working properly. I will be here in and out to my other websites but would be happy to assist you and resolve this problem. Thanks Sea Breeze
Jan 21, 2010 | Refrigerators
Refridgerator door sags
Its a two person job. One person has to looses up the two hidges holding the door just slightly while the other person holds the door in place. Once in place tighten the screw/bolts for the hidges back up and check. If not aligned, redo it again until it is aligned and seals properly..
Good Luck!
Sep 15, 2009 | Amana ATB1832AR Top Freezer Refrigerator
I have a Maytag plus side by side refridgerator-freezer. The freezer works properly, but the refridgerator temperature is to high.
While you look into the back of the freezer compartment to look for ice or snow collecting on the back panel of the freezer. Let me know what model you have and I will be able to help you with part numbers what you need to do next. Let me know the model number listed most likely in these places, Thanks Sea Breeze
Jul 20, 2009 | Refrigerators
Freezer only getting down to 20 degrees
it is one of two things low gas or thermostat
May 12, 2009 | Refrigerators
Whirlpool Freezer doesn't freeze?
insulated or not, garages are generally too cold for new energy efficient frigs to operate. ambient temp needs to be above 60 to work efficiently.
Mar 07, 2008 | Refrigerators
Amana 8 yr old side-by-side refridgerator/freezer
sound like you said a sealed system problem if compressor is running check the black coil under ref by the fan and see if it is warm if not you have lost freon just trash it then if it is see if fan in freezer is running if so pull back cover in freezer and see if coil starts to freeze if you have a ice block on coil then it is a defrost problem good luck
Dec 04, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
