Question about Samsung SELECT HLR6168W Rear Projection Television Replacement Lamp RPTV
How do you change a t-con board
How do I change the t-con board
  • Samsung Master
  • 3,459 Answers
Locate one from sited like ShopJimmy or TvRepairKits....if will come with basic instructions on how to find and swap it out...not had to do...
Posted on Apr 19, 2013
Samsung 46" lcd tv changed t-con brd 5-mnths ago worked fine. started showing up/dwn pixel lines the went white. sound is great pic is white. what board would I chang now? mdl:ln46a530p1f
It sounds like your T-Con board went out again. You might re-seat your ribbon cables just in case you didn;t get them in good from the last repair. If that doesn't help I would say that your T-con board went out again.
May 05, 2016 | Samsung LN46A530 46 in. LCD HDTV
How do I fix the picture?
there is a T con error please replace the T con in this condition
Feb 15, 2016 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
My LCD TV bravia model kdl-37v4000 is shown picture nagatively, which part of componend to be changed. If can be to fixed without service man. Where I can buy and how much the cost will come.
You have to change the t con board of the tv. Even after replacing the t con (added image of the t con )board the problem exist the you have to change the lcd panel. What ever it is you have to change the t con board to confirm.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Tcon
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
Nov 19, 2015 | Televison & Video
Screen show a lot of green ghosting throughout
I had the same problem and removing and replacing the T-Con Board fixed it. I purchased the board from ShopJimmy.com for $59.16. P/N 6871L-4550A T-Con
Apr 04, 2013 | Vizio VF552XVT 55" inch Class XVT Series...
T-Con Board for Samsung TV
Here's a place where you can purchase a T-Con board. TV Parts Universal TV Stands DLP Chips ShopJimmy
May 04, 2017 | Televison & Video
Hannspree 28 Inch Lcd Tv Model Number HSG1075
Check its Chroma section circuit for fault. Most possible cause is damaged chroma IC.
Aug 09, 2012 | Hannspree Televison & Video
Sharp Lc-26sb24u white screen with sound
You will get a white screen when you unplug the t-con from the main board. Doing so removes power to the LCD panel. Verify that all of your voltages from the power supply are correct. If they are, I'd look at the t-con board. It sounds like there is a problem with the t-con that is pulling down the main board.
May 11, 2012 | Sharp LC Televison & Video
I have a Samsung LN37550A LCD TV (full HD 1080) that is 2 years old. 2 days back the images got washed out. All I see is mostly very bright images and negative images. I am told that the TCON card needs to...
U can't buy the T-CON board in any stores in anywhere in the world because this T-CON board it is not buy able it new u only can buy it as a salvage tv PCB board only.This T-CON board u can buy it as refurbish board only.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Sep 22, 2011 | Samsung LN37A550P LCD TV
I have a Toshuiba Regza 46 in screen that has a number of thin lines on the right handside of the screen and a thick black line on the left side after 20 minutes the right disappear but the left remains....
Lines can be cause by your T-con board or by the screen itself. The only way to know is by replacing the T-con board. If they go away then it was the T-con board if they do not it's your screen that is bad. When changing the T-con board it is also a good idea to change the ribbons that connect it to the screen. You can get parts from www.interliquidparts.com
Jun 03, 2011 | Toshiba REGZA 47WLG66 47 in. HD-Ready LCD...
The l950t tv is power on and the screen is white totaly. Audio ok and channel change is ok
Check the connection between the logic board and the T-CON board on the LCD panel assembly, check the fuse on the T-CON board for 5vdc on the fuse of the T-CON board.
Look at LCD panel album to see what T-CON board looks like.
http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Jul 27, 2010 | Daewoo Lucoms L950T 19 inch LCD Monitor
Samsung SELECT HLR6168W Rear Projection Television Replacement Lamp RPTV Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
