Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
John deere 2010 tractor. pto grinds and wont engage
Pto grinds badly and wont engage. where do i start? pull back end apart?
  • 13 more comments
  • wadeostar Mar 13, 2009
    thanx. where do i adjust the pto clutch?
  • Anonymous Mar 13, 2014
    tractor massey 399 its grinding if i try to engage the pto not sure whats the matter?
    Tractor nearly new PTO never been used want to attach slasher can't work out how to get shaft engaged
    What a **** site
    my john deere will crank but wont start. why?
  • Anonymous Mar 14, 2014
    when cold the pto when not engaged keeps spinning dont have tractor that long to know if its stops when hot it spins fast not slow
  • Anonymous Mar 15, 2014
    pto when engaged tends to bog tractor down
  • Anonymous Mar 17, 2014
    How do you get a pto shaft out of a John Deere 4010 tractor
  • Anonymous Mar 18, 2014
    The starter engages starts to turn engine abruptly stops rotate engine back 180 degrees then engine will start
  • Anonymous Mar 19, 2014
    On my ford 8n tractor when I try to push the pto lever it only move a little bit but makes a grinding sound what could be the problem
    On my ford 8n tractor i push in the clutch and I try to push the pto lever it only move a little bit but makes a grinding sound what could be the problem
    PTO won't quit turning when disengaged on Ford 5000 Diesel
  • Anonymous Mar 29, 2014
    the pto button keeps flashing and wont engage .Its not a code that's its flashing it just does it continiously
    pto button continually flashes on deutz fahr agrotron 90 mk3 and wont engage
  • Anonymous Mar 30, 2014
    I have a case 2594 and I'm trying to remove the transmission pto in the rear of the tractor how do I pull that plate off????
    Problem Solver:
  • 11 Answers
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
  • Esmagamus Mar 13, 2009
    That I don't know. I own a (Swiss) Hürlimann, not a John Deere. Look in the instruction manual, it might be in there.
  • gator3011 Dec 19, 2014
    If adjusting the shift lever doesn't work, you will have to split the tractor, just behind the shifter levers. It's not that hard. Just support the front half, put a floor jack under the transmission. It can be done in 1 1/2 hrs. You will probably have to replace the clutch. Don't buy it off JD. Go to a transmission shop and buy the clutch discs and plates. They will coust about $30. JD wants over $300. To slide it back together, grind the heads off 6" bolts, and use them as guides.
The pto grinds, and will not stay engaged on my Mahindra 475 DI. Is there a simple fix?
No you will need to pull it apart and see what is broken.
Jul 05, 2017 | Garden
Why wont my john deere d140 move when I ngage the double foot pedal
The drive belt may be broken, or it may have slipped off a pulley.
Aug 03, 2014 | John Deere Garden
Cant get the switch to acctavate the mower deck on a cub cadet lawnmower
Check the fuse, tan/blue wire coming off ig switch or tan coming off PTO sw.
If it keeps blowing, check wire going to PTO unit for shorts or defective connection to PTO.
Apr 16, 2014 | Cub Cadet Garden
My gears grind when i try and engage the pto
try engaging at a slower engine speed or engine off, if off engage then try, if grinding now take it apart and change worm and gear
Nov 25, 2013 | Troy-Bilt Pony Garden Tiller
Scotts L2048 lawn tractor deck wont engage
You need to check the wires from the clutch, with the ignition on pull the pto switch out there should be a 12 volt supply at the wires if not replace the pto switch, if you have 12 volts then it is the clutch itself, they are not realy repairable, so may need a replacment.
Jul 16, 2013 | Garden
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
X595 john deere pto wont kick in
These John Deere Garden Tractors have a RIO (Reverse Implement Option) on the PTO. If your PTO is engaged and you back up, the PTO will automatically stop. To reset it, depress your PTO engagement switch to the OFF position. Take your foot off the reverse pedal. Pull up on the PTO engagement switch. The PTO should restart. To use the RIO feature, pull up on the PTO switch for a second or two just before you step on the reverse hydrostatic pedal. The yellow RIO indicator light should come on your dashboard and you can now back up with the PTO still running. Works great for snow blowing when I don't want to keep resetting my electric PTO clutch to keep restarting my snow blower.
If your PTO will not restart, you may have a PTO switch starting to fail, or a likely logic problem in your electric PTO control module, or one of your forward/reverse indicator switches, which is linked to your PTO control module along with the overtemp circuit, is stuck/faulty.
Feb 20, 2013 | John Deere 26HP Hydrostatic 54" Riding...
Blade will not engage but all saftey features works
With the pto switch pulled out check with a multi meter that you have a 12 volt supply the the clutch, pull the connector apart at the clutch end to do this, if there is no supply it is a switch or wireing issue, if there is a supply, you shouls have an audible click when the pto switch is pulled out, this is the elecro magnetic clutch engaging, if the click is present, check the belt from the clutch to the deck.
Mar 06, 2012 | Husqvarna 20HP Hydrostatic 42" Cut Riding...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
3,996 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
