Question about Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger
Poulan pro 033 fuel line diagram - Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger
3 Suggested Answers
rycgl
  • 1545 Answers
SOURCE: need a diagram of fuel gas lines on a 131 poulan
Lots of research has shown a lack of diagrams on fuel line routing. Your carburetor has the purge/primer bulb on top of it. Just to help you understand how it works....the bulb uses a vacuum effect to pull fuel from the tank directly into the carburetor and the check valves in the plate under the bulb (known as the primer base assembly) push any air and old fuel inside the carb back into the fuel tank. On your model, the line inside the tank with the fuel filter on it will come out and go to the carburetor body BELOW the base assembly. The other line coming out of the tank (fuel return line) will go TO the nipple on the base assembly. The lines should be nice and soft and so should the bulb. They all have to be replaced periodically as alcohol, heat and age deteriorate them. Please post back if needed.
Posted on Nov 06, 2010
Testimonial: "somewhat usful. would have liked a diagram. Bob"
rycgl
  • 1545 Answers
SOURCE: diagram fuel lines tank primer carbutor poulan pro
I have no diagram but here are the instructions on how it goes.
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Posted on May 28, 2011
Need fuel lines diagram for poulan pro ppb1838 chain saw
How to ... Poulan Chainsaw - replace fuel lines - YouTube
? 5:05
www.youtube.com/watch?v=jZqCNiYgF3g
Mar 27, 2012 - Uploaded by minthillbilly ... and demonstrates how to diagnosis and repair a Poulan 2700Chainsaw. ... I have a brand new Poulan Pro, the hose went bad
Jul 31, 2015 | Poulan Garden
Need the routing diagram for a Poulan 295 pro of the fuel and throttle lines
It appears there is only one "fuel line" from your fuel tank to the carb. Not sure what you mean by "throttle lines"....linkage, maybe? Anyway, here is a diagram of the parts; http://www.poulanpro.com/ddoc/POUI/POUI2000_USen/POUI2000_USen__530088792.pdf
Dec 07, 2014 | Garden
Diagram of fuel lines poulan pro blower
Put your model number into goggle and search for a fuel line diagram and you should be able to find what you are looking for. Hope this helps.
Oct 03, 2014 | Poulan Pro 25CC 2Cycle Gas Blower
How is the fuel line diagram for 446T poulan pro weedeater?
Go to the following link where they have almost all diagrams for Poulan
http://www.jackssmallengines.com/jacks-parts-lookup/manufacturer/poulan/hedge-trimmers/pp2822-966513101-2011-03/engine
Jul 15, 2014 | Poulan Garden
Gas line
What little fuel system detail ther is can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
Find a model number that matches your saw.
Fuel lines run from the tank to the carburetor to the purge pump and back to the tank. Take extensive notes and a few digital photos as you go are a good idea.
Fuel Line Replacement
SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
HTH
Lou
Oct 04, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Need a diagram of the fuel lines on a poulan 2150. what lines go where?
You can View a Diagram of the Chainsaw here http://hayward.arinet.com/scripts/EmpartISAPI.dll?MF&app=ASP⟨=EN&TF=Mainfram...
Select the Catalog Poulan/Weed Eater. Then Select Poulan. Then Select Gas. Then Select Saw. Then Scroll Down to your Model Saw i.e 2150.
Regards
Marc
Apr 17, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a poulan pro 38cc 16"chainsaw about 5 yrs. old. It ran fine until I let it sit too long and when I went to use it,discovered the fuel lines had disentegrated. Replaced the lines,drained the fuel and...
SOUNDS LIKE YOU FOLLOWED ALL THE CORRECT PROCEDURES. TRY TO GOOGLE SEARCH YOUR POULAN PRO MODEL #, I'VE HAD ALOT OF LUCK GETTING MANUALS AND DIAGRAMS FROM THERE. GOOD LUCK!!!
Jan 24, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Logo
73 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
