Question about Radio Communications
I have a pro 2023scanner and I can not get any frequincies on it.
When I turn it on, all frequencies are lost and when I try to re-set it I get nothing. What is the problem? All I hear is squelch and I can not turn that off. I think it has lost all memory. Please help.
  • Rick Studniski Apr 21, 2013
    When I turn it on, the window that shows frequencies , lights up but that is about all. I hear noise, but can see no frequencies and I cannot turn the noise off using the squelch knoob. I can not get any frequencies programmed in to this scanner.
  • 3 Answers
Try wwwdream-machine.myzen.co.uk/ iprogramed my scanner by this site
Posted on Apr 20, 2013
SOURCE: Pro-95 scanner has stopped scanning
Shit I don't know.
Posted on Jan 26, 2008
SOURCE: Won't scan frequencies.
Check the ATT settings ... when att is showing I don't believe the scanner is as "sensitive" as it is when ATT is showing  this is explained in the manual.... if I remember correctly it is toward the back of the manual Good luck
Posted on Aug 12, 2008
SOURCE: NO SQUELCH
I have a Radio Shack Pro 97 Scanner that I received as a present 1-1/2 years ago. It was working just fine and then suddenly there was no squelch or volume. The keys make noise when pushed, but there is no sound for the squelch or volume. The scanner scans the frequencies but does not stop and play. I went on line and found that other people were having the same problems. I went back to the store that the unit was purchased from and received no help what so ever, they said it’ s off warranty and I was out of luck, nice way to do business??. I think that something that cost as much as this should not be junk after a short period of time. I hope you can help me with this problem I do like radio shack, but I can’t afford to buy items that don’t stand up.
Sincerely
Greg Stevens
e-mail
fooyun@sbcglobal.net
Posted on Aug 28, 2008
SOURCE: scanner problem
If your situation is such that the frequencies display, but there is nothing but the hiss, it could be a
loose solder joint or broken lead from the antenna connector to the board. I have had mine break loose several times and had to replace the lead and solder it into the board.
Check it very closely
Ollie
Posted on Oct 23, 2008
  • 5603 Answers
SOURCE: I HAVE A RADIO SHACK PRO 97 SCANNER WAS WORKING
Check if one of the batteries MIGHT be in backwards.
NEXT check EACH cell as occassionally you get a bad one brand new.
Posted on Nov 14, 2009
HOW TO PROGRAM LOCAL EMERGENCY FREQUINCIES?
To check your area for what frequencies you need please go to www.radioreference.com. Click on Database, choose frequency database. Then click on your state, and then your county. When you scroll down the page it will show your frequencies and systems.
May 25, 2015 | Uniden Bearcat Nascar - Hand Held Scanner...
Galaxy 94h no frequincy counter
hook up a frequency counter and adjust L14 and L15.
Jan 05, 2013 | Radio Communications
Frequincy changing
press and hold the + button untill the frequency changes then move up and down to the one you want.
Apr 25, 2010 | Motorola Talkabout T5800 (22 Channels)...
Free police frequincies
For a comprehensive database aO active frequencies and systems in your area, along with a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
Apr 14, 2010 | Radio Shack Pro-96 Scanner
Two diffrent units with two diffrent frequincys . i wantto change
I hate to be the bearer of bad news but those units are fixed frequencies and cannot be changed. You either have to find a mic that matches your receiver or vice-versa. The freeway 200 series comes in 3 freqs. two of witch you have with the addition of 170.245. Maybe you can find someone who has a damaged mic but still has the receiver with the freq. that you need for your mic.
Apr 11, 2009 | Audio Technica Audio-Technica ATW-T202...
Not hearing certain frequincies
not all scanners will pick up the same, the hand held can't pick up frequency as far as the other one.
Mar 11, 2009 | Radio Shack Pro-97 Handheld Scanner
162.550 NOAA weather frequency
If your still having the problem, it could be that the transmitter for that freq lost some of it's power, so your scanner cannot pick up a clear signal. If everything else is working ok, that's my guess. Hope this helps,,, Mechanic
Nov 15, 2007 | Radio Shack Pro-94 Scanner
EasyCam Pro (HO98064)
Try a different driver if your not happy, remove cam and uninstall driver again through add/remove programmes. When you re connect use a different USB port if available. http://www.jascoproducts.com/cgi-local/SoftCart.exe/online-store/scstore/pro/computer_software_cams.html?L+scstore+gjlg2202ff442544 Sometimes the frequency needs to be set at 50HZ, the same as an Eye toy when it's used as a web cam, as the drivers are usually multi country.
Dec 09, 2006 | GE EasyCam Plus Webcam
Radio Communications Logo
49 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
